Old 05-31-2010, 12:26 AM   #1
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Default 1.8 to 2.2 Intake Manifold Question
I've read several threads for the 1.8-2.2L swap, but I'm unclear on the photos below. The car is a '93 Wagon with a 1.8L and the donor 2.2L is from a '93 dual port Legacy (at least that's what I was told). The car will be used for an Lemons race, so going no frills, just need to get everything bolted up.
I know the IAC setup is completely different between the two IMs, but how have folks handled blocking off the EGR inlet tubing to the IM (on the 1.8L manifold) since my 2.2 does not have this setup?
beaviscih is offline   Reply With Quote
Old 05-31-2010, 10:25 AM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
You can use a bolt to plug the EGR Port, it's a straight thread, not tapered. If you're cheap and lazy for a lemons car, cut the tube and crimp it shut with vice grips.
Really if you unhook the vacuum line to the egr valve, it should in theory never open, so you wouldn't have to plug the hole. But I would anyway.
Old 05-31-2010, 08:59 PM   #3
beaviscih
Member#: 123362
'93 Crapcan, '98L
Thanks. I opted to cut the tubing and tapped the ferrel(sic) fitting with a M12x1.75 bolt I had lying around, so Now the Im is plugged.
I planned on unhooking the EGR as well.
1.8 to a 2.2 swap? notasubyguy Normally Aspirated Powertrain 26 01-31-2009 11:57 PM
95 1.8 to 98 2.2 swap jahwarrior007 Subaru Conversions 2 10-24-2008 08:34 PM
1.8 to a 2.2 NA ej25turbo Subaru Conversions 19 08-11-2005 09:27 AM
1.8 to rebuilt 2.2 drewdogg Subaru Conversions 34 07-11-2005 10:41 PM
Quick questions for those that have swapped from a 1.8 to a 2.5. EcksJay Subaru Conversions 16 05-06-2005 05:47 AM
