Old 05-31-2010, 01:35 PM   #1
zigzag801
Member#: 225784
2005 RS AW
Kawa Ninja
Default Exhaust Hanger Question
I've been doing some searching on this and can't really find a definite answer. I recently purchased Borla headers, track pipe, and a type XA-stromung cat back which has a 3inch tip on it. Does anyone know what size hangers I should use for this setup? Should I just use 12mm all around? or will that cause the tip to rub against the bumper? Or could I do all 12mm except by the cat and do a 12mm XL or a 15mm? Thanks for the help just a little lost and confused
<<<O ya and my car specs are over here<<<
zigzag801 is offline   Reply With Quote
Old 05-31-2010, 01:48 PM   #2
piker28
Member#: 22664
The regular sized hangers will work fine, I always say just upgrade them to stiffer ones like Kartboys
piker28 is offline   Reply With Quote
Old 05-31-2010, 01:56 PM   #3
nairbmik
Member#: 220259
09 2.5i
SSM
Shoot kartboy a PM, I'm sure he'll take care of you
nairbmik is offline   Reply With Quote
Old 05-31-2010, 02:17 PM   #4
jaytech
Member#: 192553
'04 sti
aw
you'll need the 15mm hole diameter (if i'm not mistakin 15mm is for '07 below and 12mm is for '08 up) and you'll probably fine with standard hanger, since your tip is only 3".. but i pm [email protected] just to be 100% sure
jaytech is offline   Reply With Quote
Apexi N1 exhaust hanger question Jiggyiroc Normally Aspirated Powertrain 2 10-02-2005 01:31 PM
exhaust hangers question kimwk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-05-2005 07:51 PM
Exhaust Hanger Question...(STi + NurSpec) trey2s Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-18-2004 11:48 AM
exhaust hanger question dcgear Normally Aspirated Powertrain 1 01-09-2004 11:50 AM
Stupid exhaust hanger question SJwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-14-2003 05:59 PM
