Old 06-01-2010, 09:09 AM   #1
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Default Help with Cylinder Roughness!!!!
Car: 06 sti
Injectors: PE 850cc
I was having cold startup issues during the winter months and i tought it was due to colder plugs. I reaplced the colder plugs with stock heat range plugs and the issue didn't go away. I then replce the coil pack in cylinder 1 since it was showing roughness (miss fire) at cold start up and even after it warmed up but only at idle but the miss fire didn't go away. I then swap injectors 1 and 2 hoping it was an injector issue in cylinder 1 and it was going to show up now in cylinder 2 but it didn't. Cylinder 1 still has miss fire issues at idle. I did a compression check when i replaced the colder plugs and all cylinders were within 1 or 2 psi from each other. I can feel the missfire now at idle almost 100% of the time. I've logged the roughness while cruising and it stays at 0 for all cylinders.
What can cause missfires at idle?
What else can i do to trouble shoot this issue?
Any input is greatly appreciatted.
Thanks,
Wil
wil06STI is offline   Reply With Quote
Old 06-01-2010, 01:47 PM   #2
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
what other mods do u have? are there any vacuum leaks? is the cel on?
romanlynch is offline   Reply With Quote
Old 06-01-2010, 02:09 PM   #3
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
There are no vacuum leaks and the cell is on but not for a missfire for a sensor i deleted.
I just did a compression test on that cylinder and it has 110 psi. I think that explains the missfire at idle or not?
Old 06-01-2010, 02:17 PM   #4
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
need to scale injectors/maf or look for leaks!
renosubby is offline   Reply With Quote
Old 06-01-2010, 10:23 PM   #5
wil06STI
Member#: 153228
02 WRX Fully Built
Sedona Red
Default Update!
Engine blew on my way back from work. Rod #1 went through the block. Let see if i can find the culprit after i take it apart.
Wil
Old 06-07-2016, 09:50 AM   #6
KevSmu
Member#: 279340
What was it?
KevSmu is offline   Reply With Quote
Cylinder Roughness (Misfire) Prior to Being Broken In? STIBungy Built Motor Discussion 2 04-03-2009 01:48 PM
PRoN Project Car #2: Running on 3 cylinders, rough idle. eurojax Normally Aspirated Powertrain 73 06-11-2008 02:06 AM
Need some help with my wrx rough idle. kccobra Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 08-22-2005 05:31 PM
saint_foo needs help with rough idle saint_foo Mid Atlantic Impreza Club -- MAIC 5 11-17-2004 05:55 PM
Need your help with my master cylinder swap Legacy777 Brakes, Steering & Suspension 8 11-21-2002 10:39 AM
