Old 06-01-2010, 09:28 AM   #1
240addiction
Member#: 195663
Default 2004 outback timing belt replacement
Hi,
I am doing my mom's timing belt on her 2004 outback with the h4 and I want to make sure I am getting everything done at once and correctly while she is in town with her car. I was going to replace the parts using only oem parts. Can I use this link as a guide http://www.scoobymods.com/my01-rs-ti...light=cam+belt
I have done the belt on my 92 legacy with the 2.2 and it looks similar as far a a quick glance goes.
I am going to replace the belt, pump, thermostat, all idler pulleys, tensioner, and the crank seal. I think that is all. Is there anything that I am missing? thanks for the help.
Paul
240addiction is offline   Reply With Quote
Old 06-01-2010, 10:26 AM   #2
vrusso
Member#: 207074
2001 Impreza Outback
Silver -180k and counting
Humm this link used to have a good walk through for the timing replacement but its not working for me and I am not sure if its because I am at work.
http://endwrench.com/images/pdfs/2.5Timing.pdf does not work
give it a shot it may or may not work for you.
Ahh here are the replacement links:
http://endwrench.com/pdf/engine/FtTi...ReplaceF00.pdf for 2.5ltr engine
http://endwrench.com/pdf/engine/FtCamBeltReplaceW01.pdf for 2.2ltr engine
vrusso is offline   Reply With Quote
Old 06-01-2010, 10:28 AM   #3
240addiction
Member#: 195663
that did not work.
Old 06-01-2010, 10:31 AM   #4
vrusso
Member#: 207074
Originally Posted by 240addiction View Post
that did not work.
Try the edited links
Old 06-01-2010, 02:34 PM   #5
S&R
Member#: 247405
You are doing the right parts. The install itself is fairly straight forward and really not very different from what you've done in the past. Take your time, if you want more room, pull the radiator since you're going to replace the coolant anyway.
good luck, man.
S&R is offline   Reply With Quote
Old 06-02-2010, 04:50 PM   #6
quikcobra
Member#: 175246
This was helpful kind of. My issue is when putting tension on the tensioner it moves and causes everything to be out of time.
quikcobra is offline   Reply With Quote
Old 06-02-2010, 06:31 PM   #7
vrusso
Member#: 207074
Tensioner probably needs to be replaced.
Old 06-02-2010, 10:13 PM   #8
quikcobra
Member#: 175246
No when it tightens everything moved I just did it, I havent cranked it but rotated it a few times seems all good. Well ill find out soon.
1997 Outback Timing Belt? Neurorelay Service & Maintenance 4 09-26-2009 08:08 AM
Water pump replacement at second timing belt replacement? doobie Service & Maintenance 1 10-19-2007 12:12 PM
01 outback timing belt 02wrbrex Outback Forum 4 06-16-2007 11:35 AM
What else to replace while doing timing belt replacement? the_glassman Normally Aspirated Powertrain 3 04-16-2006 11:58 AM
Looking for Outback timing belt service manual el rayo-x Canada Region Forum 1 02-10-2004 03:33 PM
Message Board Statistics All times are GMT -4. The time now is 12:00 PM.
