Old 06-01-2010, 11:24 AM   #1
GoneSingle
Member#: 247936
05 Subaru STi
Default Suspension that will ride more comfortable than stock!
I have a daily driven 05 sti. i would like to invest into suspension that will ride better than stock. Right now i have the clunk issue on my 05 and felt this is a good time to upgrade. I don't track my car, just occasional spirited runs so obviously i would want something without too much body roll, but something that will be more forgiving on the streets of los angeles.
currently, im considering the feal suspension revalve service. also, i am not looking to lower the ride height, but i wouldnt mind lowering it a tad bit if it doesnt cost me too much.
GoneSingle is offline   Reply With Quote
Old 06-01-2010, 01:26 PM   #2
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
The Feal revalve should take a bit of the harshness out of your daily drive. A lot of the harshness of the stock STi suspension is the valving in the dampers. Another option would be Koni inserts. A little more expensive, but also adjustable.
Scooby921 is offline   Reply With Quote
Old 06-01-2010, 07:06 PM   #3
GoneSingle
Member#: 247936
05 Subaru STi
hmm im lookin between the feal revalve and the BC BR coilovers. is there anything between the 2 price ranges ($400-1000) that will fit my needs? as for the koni inserts, i'd rather pay a few hundred more and get coilovers
i feel the BC BR's are a bit overkill for what i want (a good daily driver) with more comfort than stock.
as for the feal revalve, i wish they'd have a core exchange as this is my DD
Old 06-01-2010, 07:09 PM   #4
Badler
Member#: 133597
Get springs with the rates you want. Send your struts to FEAL with the specs. Get a WAAAAAAAYYYYYYYY better setup for half the price.
Comfortable and cheap coilovers do not go hand in hand.
Badler is offline   Reply With Quote
Old 06-01-2010, 08:08 PM   #5
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
If you want a better ride, you want avoid any $1000 coilovers. If you want coilovers that offer a good ride, look at something like the KW V3's or Bilstein PSS9's. If you can't spend that much, do what was suggested and get some good springs and revalved struts.
Old 06-01-2010, 08:36 PM   #6
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
Koni inserts > any cheap $1500 coilovers
happs subi is offline   Reply With Quote
Old 06-01-2010, 08:37 PM   #7
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
They also don't fit into STi strut housings without pretty significant modifications. The Feal revalve service is the "koni insert" for STi struts.
Concillian is offline   Reply With Quote
Old 06-01-2010, 10:30 PM   #8
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
^ I know, sorry. Didn't realize he had a 05 (lack of reading). But still, a good damper with his stock springs would feel way better than some cheap coilovers.
Old 06-02-2010, 09:50 AM   #9
simonella_virus
Member#: 183875
2007 WRX STi Stg2
i've been thinking the same question [as the OP], for when my stock struts go kaput.
from my reading, it looks like the OE STi struts are overdamped. so on that note: is there some quantitative measure of the damper fluid viscosity/ valve cross-sectional area (i.e. overall damping characteristics) so that one can compare one strut against another? sort of akin to spring rates.
i've walked this path before and usually the results are only marginally better or horrifically worse. i think it's especially true as most STi after-market parts are usually biased toward track applications, with nary a thought to how bad our roads are. not to mention the fact that some people on this forum enjoy being shaken, not stirred.
simonella_virus is offline   Reply With Quote
Old 06-02-2010, 11:08 AM   #10
GoneSingle
Member#: 247936
05 Subaru STi
i've decided to go with Feal. I spoke with someone there yesterday and they are willing to work with me on the downtime issue (they are local to me). I will post a review once its done. cant wait to get rid of this clunk and improve ride quality
Old 06-02-2010, 12:28 PM   #11
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
There are shock dyno plots, but the only struts you'll find them for are Koni and Feal.
Consequently, these are also some of the highest regarded strut replacements in terms of comfort + performance.
If you find the Feal thread on development of the re-valve, they have dyno plots of the STi struts and Feal struts showing how they are different. Takes some time to figure out how to read a shock dyno if you never have. It's not totally obvious.
Dog toys that will last more than 6minutes? SQ3.0dotJP Off-Topic 77 06-29-2009 02:03 PM
1st step to make my ride more comfortable? Brian Broz Brakes, Steering & Suspension 6 10-06-2005 09:16 PM
225/45/17 more comfortable than 215/45/17 ? paulatwork Tire & Wheel 2 05-26-2003 04:11 PM
suspension that lowers car more than 1.25" ? erice1984 Brakes, Steering & Suspension 18 02-24-2003 10:22 AM
Has anyone noticed that RE92s are MORE expensive than the new Kumhos??? Joe Lee Technical Forum Archive 1 05-17-2000 05:43 PM
