Old 06-01-2010, 11:29 AM   #1
GoneSingle
Member#: 247936
05 Subaru STi
Default Window will roll down but not up!?
So my rear passenger window will roll down but not up when i use the master control switch from the drivers side door. However, everything works completely fine if you try to roll it down or up from the actual switch on the door. any clue what this is?
GoneSingle is offline   Reply With Quote
Old 06-01-2010, 11:58 AM   #2
ruckus racing
Member#: 196844
1997 Impreza L
flat black/green
worn out switch/loose connection
ruckus racing is offline   Reply With Quote
Old 08-04-2010, 12:50 PM   #3
bigdsti
Member#: 72830
2013 BRZ Premium
I'm also having this problem, but both passenger windows don't roll up. Using the passenger door switches they work great. I know the switches can't possibly be worn out, it's only a 2005 WRX wagon with a mere 36k miles and the windows aren't rolled down very frequently..
I'm going to pull the switches to see if I can check the connections and test the wire continuity between the two doors.
bigdsti is offline   Reply With Quote
Power Window goes down, but not up JC1981 Electrical & Lighting 9 03-05-2010 11:17 AM
driver side window rolls down but not up fontaracing Electrical & Lighting 2 07-06-2009 12:41 PM
Adding extra window auto roll down buttons? druxboyz Interior & Exterior Modification 33 03-20-2009 05:09 PM
Passanger and rear Windows won't roll down BigClunke Service & Maintenance 3 04-25-2006 02:38 AM
2000 OB: driver's side window will go down, won't come back up Klestrob44 Normally Aspirated Powertrain 3 02-14-2006 04:18 PM
