Old 06-01-2010, 11:32 AM   #1
scottjal
Member#: 177809
2008 WRX hatch
Default How do I diagnose 2008 5MT viscous coupling?
With one tire in the air and the trans in neutral I was sort of assuming that I should not be able to turn the tire by hand or even by a wrench given the torque the engine can put on the wheel? Right? What about cold verses hot?
I read a bunch of posts about the viscous coupling binding and locking up in turns and I definitely don't have that, I am thinking mine is wide open and offering no resistance. Last winter there were some instances where I had lots of rear wheel spin and nothing really pulling from the front. Was never stuck with wheel spin or towed or tracked or anything that I can think that would kill it.
scottjal is offline   Reply With Quote
Old 06-01-2010, 01:41 PM   #2
wrxsubaru
Member#: 65133
The stock viscous unit on WRXs is pretty weak. I believe it is a 2kg/100 rpm, which means the center diff will transfer around 7 ft pounds of torque for every 100 rpm difference between the rear and front axle. I am not sure what is required to cause the center diff to lock the diff or if it is possible. To get the most torque transfer from the diff you have to be cause a large speed difference between the rear and front axles. If you’re spinning your rear tires at 10 MPH and not moving the diff should be transferring around 65 ft pounds of torque to the front. My experience with a 2k/100 center diff is that they are very weak and can barley pull you around unless you’re trying to beat the hell out of it. The viscous units will degrade over time and use so unless it’s a new I would bet that the amount of torque transfer is a fair amount less than 2k/100 rpm. I have been able to back up a hill while on three wheels but I had the tire in the air spinning at probably 20 + MPH to do it and that was with a 220,000 miles 1st gen legacy. It’s kind of backwards from most other cars but viscous units will transfer more power the more you spin the tires.
wrxsubaru is offline   Reply With Quote
Old 06-01-2010, 03:15 PM   #3
scottjal
Member#: 177809
2008 WRX hatch
Thanks, I just thought there would be a lot more initial bite than that. This link helped me understand a bit too.
http://www.mrtrally.com.au/performan...s_coupling.htm
On another thought I guess these cars don't have any sort of active traction control either then? In my land rover if I had as much wheel spin as I had in the winter it would be clamping the brakes down on spinning wheels, same with your one wheel up situation.
Old 06-01-2010, 07:27 PM   #4
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Yes, the 08+ have traction and stability control. The 08+ WRX does not have any type of LSD in the rear. Only the center diff is limited-slip.
sniper1rfa is offline   Reply With Quote
How do you diagnose sticking/stuck caliper pistons? (Front end vibration problems) udelslayer Brakes, Steering & Suspension 1 09-11-2009 04:45 PM
How do I Diagnose Cross-Camber? williaty Brakes, Steering & Suspension 12 03-20-2008 07:46 AM
how do i diagnose this problem? speaker turning on and off. Poe Car Audio, Video & Security 4 02-23-2008 02:23 PM
I can't figure out how to remove my viscous coupling mk2jettavr6 Transmission (AT/MT) & Driveline 3 01-15-2008 09:58 AM
How do I diagnose/fix a weedeater? -=C=- Off-Topic 13 05-21-2007 11:13 AM
