Old 06-01-2010, 12:36 PM   #1
manjambles
Member#: 205643
2005 forged goodness
Default mismatched turbo, what to do 07 sti
ok so im running an OTS map for my saabaru 07 STI and for somereason only getting 14.1 psi which i feel is really low.
when i bought the motor it didnt come with a turbo so i went with the vf34 so it makes me think that the tune is looking for the 43 and not producing the boost it needs for my 34. already went threw looking for a boost leak and found nothing. so what next, before going pro tune
manjambles is offline   Reply With Quote
Old 06-01-2010, 09:23 PM   #2
Cobb Tuning
Member#: 4803
What map are you running? What injectors, turbo, ecu etc do you have installed? That could be a dangerous combination of parts you have! You cannot use STI maps on the Saabaru ECU, keep in mind!
Travis
COBB Tuning
Old 06-02-2010, 04:58 PM   #3
manjambles
Member#: 205643
ive swapped over the motor and ecu from an 07 sti, everything but the drivetrain is there from an sti. but the turbo is the vf34 and not the 39, so thats where i think im having boost problems.
Old 06-03-2010, 12:36 AM   #4
manjambles
Member#: 205643
i found out what i need my waste gate isnt staying shut long enough. i need the wastegate duty map. where can i find it
Old 06-03-2010, 05:37 PM   #5
Cobb Tuning
Member#: 4803
I would strongly consider a protune for your vehicle. You the VF39 maps made for the 2.0-liter ECU were not created with a 2.5 swap and AVCS etc in mind. Simply increasing boost pressure could be a bad thing. Get a protune, you will be much happier. At the very least, an E-tune if you are strapped budget wise.
Travis
COBB Tuning
Old 06-03-2010, 06:54 PM   #6
manjambles
Member#: 205643
i also figured out that i was running the restricter pill from my 2.0 wrx motor so that might have alot to do with it and it will be here tomorow
Old 06-04-2010, 03:46 PM   #7
manjambles
Member#: 205643
ok so changed the restricter pill and now getting 15.7 psi with my wastgate duty cycles at 79 at the highest. what should i do now protune or high wastegate duty map. or try reloading the stage 2 93 oct map? please help me cobb
Old 06-09-2010, 04:16 AM   #8
manjambles
Member#: 205643
cobb?? anything else i can try cuz im bout to go opensource if i cant find the map to fix this
Old 06-09-2010, 07:38 PM   #9
Cobb Tuning
Member#: 4803
The issue is not your engine management, it is the fact that you need a tune for what you are trying to do. You are trying to use the wrong map on the parts that you have. The maps for the SAABaru are made for a 2.0-liter engine, you are running a 2.5-liter swap with a larger turbo and AVCS if you have done a complete STI swap. What heads are you running? We do not have a map to fix this issue as you have a rather specialized setup.
Travis
COBB Tuning
Old 06-10-2010, 02:36 AM   #10
manjambles
Member#: 205643
Ok look forget the fact that i have a saabaru. everything from an 07 STI is in the saabaru shell like i said before... show me where i can find the high wastegate duty map for the 07 sti.... its an 07 sti!!!!
Old 06-10-2010, 05:00 AM   #11
Anub1s
Member#: 81106
2014 Baby Mobile
Whitey White
Something I don't think you're getting is that you should not be running a map made specifically for a certain turbo and using a different one. They all behave differently, and no WGDC map is going to work for two different turbos.
Incidentally, there is no HWG version of the Stage 2 map for the 07 STi.
You need a custom tune. No if's and's or but's about it. If you continue to use a Cobb OTS map for this setup, you're going to continue having problems. You have to have it tailored to your needs.
Anub1s is offline   Reply With Quote
Old 06-10-2010, 06:03 PM   #12
van_dutch
Member#: 198633
2004 WRX
What map are you trying to run? What model AP do you have?
van_dutch is offline   Reply With Quote
Old 06-10-2010, 11:04 PM   #13
Nuke209
Member#: 108089
2003 WRX
NF Performance
Travis
COBB Tuning
Lol, he said already that he has the ecu and all
The STI maps wouldn't flash over the 16bit
You're better off downloading AccessTune Race and edit the maps yourself.
Nuke209 is offline   Reply With Quote
What to do? 07 Legacy GT for 08 STI Awadd09 Newbies & FAQs 3 02-02-2010 10:03 PM
Styrofoam peanut inside my turbo, what to do? lateralus1082 General Community 14 06-07-2008 03:29 PM
cracked turbo...what to do? ted dibiase Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-23-2006 05:45 PM
broke a bolt off of turbo , what to do ? billy boi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-04-2004 11:42 AM
what to do with sti grill hole skimmilk68 Interior & Exterior Modification 5 04-12-2004 12:37 AM
