Old 06-01-2010, 11:50 AM   #1
janthenat
Member#: 53580
1996 Outback Sport
Blue/Titanium
Default Will not (won't) start - 96 OBS
My 96 OBS will not start. When I turn the key I can hear the fuel pump run, then the starter works fine but still no start (no coughing or sputtering at all, just the sound of the starter attempting to do its thing). I have a CEL showing but can't check it. No apparent power problems, no recent repairs.
OK, walk me through the troubleshooting process in ascending order of repair price. ;^)
Thanks!
janthenat is offline   Reply With Quote
Old 06-01-2010, 02:40 PM   #2
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
coil pack, have you checked to see if you have fire?
I guess you have since you said you have power
dstan is offline   Reply With Quote
Old 06-01-2010, 04:16 PM   #3
janthenat
Member#: 53580
1996 Outback Sport
Blue/Titanium
Default fixed (my wife is awesome!)...
First my wife lets me drive her car (read "the good car") to work when mine won't start, then later she fixes mine. ;^)
I called her up at lunchtime and she pulled all the SBF fuses and reseated them. One had a dead spider fried to the plug, wierd and possibly the cause but who knows. After that it started right up.
That's my girl!
Old 06-01-2010, 07:38 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
wife fixing your car, eh? Turn in your man card...
Old 06-01-2010, 10:20 PM   #5
dstan
Member#: 120386
Glad it turned out well, Your Wife should have an account here for sure
Old 06-02-2010, 12:34 PM   #6
janthenat
Member#: 53580
1996 Outback Sport
Blue/Titanium
Default not fixed...
OK, so maybe she's not "all that" after all... No start today.
Plugs are decent and connections are good. I did notice, though, that it has rained significantly overnight before the starting problem.
Any ideas? Thanks.
Old 06-02-2010, 05:06 PM   #7
janthenat
Member#: 53580
1996 Outback Sport
Blue/Titanium
Default update...
Replaced plugs, no change. Not that I expected there to be... its just been a while (plugs were dry).
Rented an OBD II tool and read the codes...
P0325 - Knock Sensor
P0335 - Crankshaft Position Sensor A
I cleared the codes and tried starting again a couple of times and the P0335 code came back. Is there any possibility that this sensor could keep it from starting? I suppose it is possible, since the P03xx range of codes is related to ignition.
Thanks for any help.
Old 06-02-2010, 08:32 PM   #8
zze86
Member#: 194014
yes. a bad crank and/or cam sensor will stop the car from firing up.
zze86 is offline   Reply With Quote
Engine will not stay start/stay running akira02rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-25-2008 08:16 AM
Car will not start!?! Bryan C Electrical & Lighting 6 08-01-2003 10:27 PM
car will not start after installing CAI? Solomon Legacy Forum 25 07-30-2003 10:38 AM
96 OBS, Where do I start? balrog Brakes, Steering & Suspension 20 11-10-2002 01:35 AM
Car will not start, at Evanston for Repair Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 14 01-23-2001 11:34 AM
