Old 06-01-2010, 12:18 PM   #1
acssa
Member#: 184023
Default fuel smell in oil
I think I smell fuel in my oil...is that normal?
I am running relative AFR's
Dont want to stuff up a engine...
acssa is offline   Reply With Quote
Old 06-01-2010, 01:14 PM   #2
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
I would say your running too rich, but you say its ok. Whats your set up? You have some sort of wide band? Are you running a very large Maf housing and fuel injectors? Does your car ever stall out when you push the clutch in and it doesnt catch the idle?
If so you may be soaking the CC with fuel when you start it back up.
If this is happening, Floor the gas 100% before and while turning the key to start it. As soon as it starts you have to get OFF the gas asap so you dont rev teh crap out of it. Flooring the gas when starting puts the car in a safety mode and it doesnt inject any fuel. The engine just starts on the unburned fuel in the combustion chamber. If there is too much fuel it will wash all teh fuel off the cylinder walls and the pistons will polish the crosshatch, your rings will go and you will loose compression.
Change your oil asap. If you cant figure out whats going on Id change the oil much sooner then normal. oil and fuel dont work well together.
rexworx is offline   Reply With Quote
Old 06-01-2010, 03:51 PM   #3
acssa
Member#: 184023
I am running E50 and 1000cc injectors....no MAF and HYDRA EMS.
Old 06-01-2010, 04:14 PM   #4
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
possible O-ring goin bad?
Fuel smell in oil fl4tsc Newbies & FAQs 12 04-22-2010 08:28 PM
TSB-fuel smell in cold weather freeze Mid West Subaru Owners Club Forum -- MWSOC 20 02-19-2004 03:40 PM
fuel smell in the passenger compartment poll byrdman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-25-2003 08:19 PM
need help - fuel smell in cabin and engine bay nhluhr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-06-2002 07:38 PM
