Old 05-23-2010, 07:30 PM   #1
norcalwrx816
Member#: 203489
03 wrx wagon
flat4/Mayhem Tuning!
Default i wanna run e85
ok so my last thread got locked so here i am trying again..
I would like to run e85 with the new setup im going to get but i cant decide on what turbo to get but i narrowed them down to a evo 3 16g big 16g,18g,and ill have a walbro 255 intank,and have been told the min of 850cc i would need to run so is it true or not true.what size do i need?
norcalwrx816 is offline   Reply With Quote
Old 05-23-2010, 07:40 PM   #2
xsnapshot
Member#: 170973
2004 WRX 4EAT
850 cc will be fine.
xsnapshot is offline   Reply With Quote
Old 05-23-2010, 07:58 PM   #3
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Wirelessly posted (Phallic Tractor: BlackBerry9630/5.0.0.497 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
With a 16g, 850cc should be fine. An 18g, MAYBE. Not a 20g.
XanRules is offline   Reply With Quote
Old 05-23-2010, 08:02 PM   #4
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
PS: this thread is much better than the last one.
Old 05-23-2010, 08:20 PM   #5
norcalwrx816
Member#: 203489
03 wrx wagon
alright thanks for that info guys,now what if i decide not to run those turbos and go with a vf,34,43,something in the vf series what size would i need to have, then im trying to cut the cost down in injectors because the higher you go the more they cost..?
Old 05-23-2010, 08:21 PM   #6
norcalwrx816
Member#: 203489
03 wrx wagon
thank you and sorry if i came off like a dick
Old 05-23-2010, 08:39 PM   #7
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
I've got thick skin. No worries.
Again, the range of turbos is so broad that you've listed that it entirely depends. 850cc is a safe bet for most smaller turbos, in my limited experience.
Old 05-23-2010, 08:59 PM   #8
norcalwrx816
Member#: 203489
03 wrx wagon
alright cool. so 850cc would be the min for the turbos i listed or is there anyway i can bring the cc down and still e85?
Old 05-23-2010, 09:34 PM   #9
pimpUall
Member#: 55424
2005 380hp LGT Wagon
I have run my 20g with e85 sometime. I have a '05 LGT (2.5L same as a STi motor) and I make about 340whp on 91 cali pump gas at 20psi and at the same boost level I hit 370whp. I have modd 830cc stock injectors. I hold 20 psi at 7000 rpms and I hit about 94% IDC.
pimpUall is offline   Reply With Quote
Old 05-23-2010, 10:01 PM   #10
norcalwrx816
Member#: 203489
03 wrx wagon
thanks alot but you have a 2.5 and i have a 2.0 im trying to get info for injector size..i think its different for injectors
Old 05-23-2010, 10:12 PM   #11
mattminer
Member#: 90642
WKD Everything
why not just run modded stockers / 850cc. there is no good reason to run a smaller injector, and the injector size is based on your power level and fuel type only.
mattminer is offline   Reply With Quote
Old 05-23-2010, 11:43 PM   #12
pimpUall
Member#: 55424
I know you have a a 2.0. I was just letting you know that a larger engine with a 20g with 830 injectors is fine. Your engine won't move as much air as my 2.5L. So your IDC will be even lower then mine. So you will be fine with 850cc. I was just giving you real numbers for a comparison from my logs.
Old 05-24-2010, 12:23 AM   #13
norcalwrx816
Member#: 203489
03 wrx wagon
thanks bro i wish i had a 2.5 too move more air but i will later when the time comes...and like ^i thought about getting modded stockers
Old 05-24-2010, 01:56 AM   #14
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Is your motor stock?
Byzantium is offline   Reply With Quote
Old 05-24-2010, 07:08 AM   #15
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You need to talk to your tuner. There is little difference between the EVOIII and an 18G so pick one of the damn things. As to the injectors, that's a question for your tuner as if I steer you wrong you can't punch me in the face, but if your tuner runs you wrong, you can punch him in the face.
Old 05-24-2010, 08:38 AM   #16
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
Go big or go home and remember be nice to your tranny.
scoobystas is offline   Reply With Quote
Old 05-24-2010, 09:01 AM   #17
Crimeboss
Member#: 232043
2005 WRX
FWIW: I ran out of injector on my 2.0 with a 68HTA and 820's.
Crimeboss is offline   Reply With Quote
Old 05-24-2010, 09:09 AM   #18
pimpUall
Member#: 55424
How much boost were you running? and what was your redline?
Old 05-24-2010, 01:12 PM   #19
Crimeboss
Member#: 232043
2005 WRX
Boost was 21 psi. Redline was around 6800 if I remember. I'm not running it. I didn't have anything to gain over my pump tune except for a decrease in MPG. My tuner said about 1000's would be what I'd need.
Old 05-24-2010, 01:55 PM   #20
norcalwrx816
Member#: 203489
03 wrx wagon
yes my motor is stock..i will have to talk to my tuner and something goes wrong ill hit him in the throat and punch in the face haha...i just wanted to get some sort of numbers from people
Old 05-24-2010, 02:25 PM   #21
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
In most instances it doesn't matter what boost he was running unless that 21lbs was at redline. You run out injectors at topend. With 18g n up id try to source 1000cc.
Old 05-24-2010, 02:27 PM   #22
norcalwrx816
Member#: 203489
03 wrx wagon
alright everyone thanks for the help but im not going to be running e85 due to the high mileage my car has so im just gonna find an evo3 16g or big 16g and call it aday...thanks alot
Old 06-01-2010, 03:47 PM   #23
anxiouz
Member#: 235268
2010 Cadillac CTS-V
You shouldn't let high mileage hold you back. As long as you don't crank boost up through the roof, E85 should be just fine for you.
In my 03 Evo 8 I'm running E85 on a 20G...at 107k miles. My boost is extremely conservative (same as my 91 octane tune) but the car feels amazing on the corn. Evo's gotta run 1000cc injectors to use E85 though, mandatory.
anxiouz is offline   Reply With Quote
Old 06-01-2010, 04:05 PM   #24
mattminer
Member#: 90642
WKD Everything
i would just snag a set of id1000's minimally to run E85 and not have to worry about it
wanna run e85 all the time but how is the mileage? djc1827 Newbies & FAQs 17 03-17-2010 02:51 AM
'05 STi considering running e85 RSquared Newbies & FAQs 20 05-02-2008 08:14 PM
Who's running E85 in their Wrx and Sti's? wuuusaa Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-23-2007 08:06 PM
Wanna run on a field during an NFL game? Not if you wanna see the superbowl 2k2 Off-Topic 13 01-17-2006 11:13 PM
Can I run E85??? X4 SRT General Community 30 08-14-2005 02:13 PM
