Old 06-01-2010, 12:44 PM   #1
imprezin0813
Member#: 246356
2010 Impreza 2.5i
Default Short Throw Shifter Install
Hey guys,
So today i installed a Agency Power short throw shifter in my 2010 impreza. After the install i took it for a test drive and shifting gears is now really stiff and sometimes have difficulty getting into gears. Any ideas why this could be? Thanks.
imprezin0813 is offline   Reply With Quote
Old 06-01-2010, 01:00 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i think its because its a vivid racing shifter
maybe you tighten up the piviot point to much.
PARANOID56 is offline   Reply With Quote
Old 06-01-2010, 01:12 PM   #3
scottjal
Member#: 177809
2008 WRX hatch
Yeah, check for binding. Otherwise it is normal, shorter shifter is less mechanical advantage in a shorter lever = harder effort to do the same task.
scottjal is offline   Reply With Quote
Old 06-01-2010, 04:08 PM   #4
simonella_virus
Member#: 183875
2007 WRX STi Stg2
i've noticed the same thing when going stock to karboy shorthrow shifter. agreed with mechanical (dis)advantage comment above. you'll either get used to it, or you'll just go back to stock. if you're really lazy, just extend the short shifter (via latheworks) and leave it in there
also, did you install the front/ rear shift bushings?
simonella_virus is offline   Reply With Quote
Old 06-01-2010, 11:35 PM   #5
imprezin0813
Member#: 246356
2010 Impreza 2.5i
I purchased the shifter bushing but have no put them in yet. And what do you mean by tighten up the pivot point to much? Thanks.
Old 06-02-2010, 04:45 AM   #6
cartoonlife
Member#: 204291
07 UGM STi Ltd
2012 Prius
By tightening the nut & bolt that hold the shifter and linkage together you can vary shifter feel... stiff, less stiff. Peeps tend to over tighten this and end up with a stiff as hell/hard to shift feel.
try loosening the nut a bit and test
cartoonlife is offline   Reply With Quote
Old 06-02-2010, 11:52 AM   #7
imprezin0813
Member#: 246356
2010 Impreza 2.5i
Ill have to try that . Thanks. Does anyone know if they sell aftermarket bushings for between the shifter linage and shifter itself and if so will they help my problem?
Old 06-02-2010, 12:00 PM   #8
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Shifter handle pivot bushings: http://turninconcepts.com/product_in...products_id=89
Linkage bushings: http://turninconcepts.com/product_in...products_id=81
Front & rear stay bushings: http://turninconcepts.com/product_in...products_id=34
Shifter lever mounting bolt: 8.7Lb/ft
Old 06-02-2010, 07:42 PM   #9
cartoonlife
Member#: 204291
07 UGM STi Ltd
2012 Prius
Good info
OP seriously. The bushings are worth it, a bit of a PITA to install but really... once you drive your car w/ a fully decked out shifter & bushings, and try a stock shifter...you WILL say omg wtf
Old 06-04-2010, 08:13 PM   #10
imprezin0813
Member#: 246356
2010 Impreza 2.5i
Will the shifter handle pivot bushings alone somewhat fix my problem?
Help! Urgent: Short throw shifter install woes mattjb North West Impreza Club Forum -- NWIC 9 10-19-2002 02:10 AM
SOA Short Throw Shifter Install Timmay Transmission (AT/MT) & Driveline 1 03-22-2002 01:41 PM
COBB Short Throw Shifter installed... TFW Transmission (AT/MT) & Driveline 12 12-04-2001 11:18 PM
BPM twister and short throw shifter installed at ISR Chewyguru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-10-2001 07:44 PM
SPT short throw shifter install Arch Technical Forum Archive 4 08-28-2000 06:26 PM
