Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 06-01-2010, 02:08 PM   #1
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
Default Tell me what happened to my A/C...I'll tell you what I ate for breakfast
That's the rules.
Scenario:
I come home the other day to find that it is 85 degrees (F for those of you that will be dumbasses) and wonder WTH?
A/C won't turn on, fan won't kick on...etc. Upstairs separate unit works great.
This has happened before so I went outside to see if the condenser had ice on it...nope.
I go upstairs into the attic and the a/c has a big puddle of stagnant water in the overflow reservoir. I pull open the cover and the thing immediately kicks on and has been running ever since.
So, what gives? What happened to my A/C?
-=C=- is offline   Reply With Quote
Old 06-01-2010, 02:09 PM   #2
gramicci101
Member#: 64763
The cake is a lie.
There's a loose wire and pulling on the cover wiggled it back into place. For now.
gramicci101 is offline   Reply With Quote
Old 06-01-2010, 02:10 PM   #3
vwzealot
Member#: 162696
06 Cooper S
07 Turbo
Sounds like you shouldn't close that cover.
vwzealot is offline   Reply With Quote
Old 06-01-2010, 02:11 PM   #4
Black_Rain
Member#: 29932
2005 LGT Ltd
Womp
zombies
Black_Rain is offline   Reply With Quote
Old 06-01-2010, 02:14 PM   #5
The Motel Fella
Member#: 140147
02 '13 Sienna
I make minivans look hot
I assume you mean the drip pan beneath the unit?
If your unit ~ my unit then your primary drain line might be clogged.
As to why it started and has been running since, got no ideas.
Mine has a pressure switch that shuts the thing off if you open it while running...not sure why yours would do the reverse.
The Motel Fella is offline   Reply With Quote
Old 06-01-2010, 02:15 PM   #6
Tgui
Member#: 44771
Was the float switch turning off the A/C because of the pool of water, acting as it should? Did pulling the cover remove some of the water some how? Ya got a plug in the drain tube?
Tgui is offline   Reply With Quote
Old 06-01-2010, 02:15 PM   #7
Brad Pittiful
Member#: 34931
bad fetzer valve
Brad Pittiful is offline   Reply With Quote
Old 06-01-2010, 02:16 PM   #8
Vostok 7
Member#: 30209
Do you need to
read this in Braille?
CN: Unit functions as it should. WHAT UP WITH THAT?!?
Vostok 7 is offline   Reply With Quote
Old 06-01-2010, 02:17 PM   #9
UberWilhelm
Member#: 80937
You got sperm in the cratzenjanger valve. RUN!!
UberWilhelm is offline   Reply With Quote
Old 06-01-2010, 02:18 PM   #10
Tgui
Member#: 44771
If thats the case he better post a vid of him drinking that water as punishment.
Old 06-01-2010, 02:23 PM   #11
-=C=-
Member#: 7719
99 F-150 crew cab
Hmm...now I wonder if I go back in the attic if I'll find a swimming pool of water at this point. I'll check it tonight and see if it was clogged.
Oh and I had a Oatmeal Breakfast cookie...
Old 06-01-2010, 02:38 PM   #12
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
you can get 'pan tabs' (basically chlorine tablets) that will help with unclogging primary and emergency drains on the unit. I try to throw a couple in at least once or twice a year.
You might have a service guy check the unit for low refrigerent. It may be icing up, shutting down due to some fancy sensor, melting off - but not restarting for some reason.
1 Lucky Texan is offline   Reply With Quote
Old 06-01-2010, 02:52 PM   #13
-=C=-
Member#: 7719
99 F-150 crew cab
righto...it's a new unit (house built in 05) and we've already replaced a coil, I think.
Old 06-01-2010, 02:57 PM   #14
Garandman
Member#: 101117
2009 WRX, 06 OBW 3.0
Tiger 1050, WR250R, TW200
If it is the type that has the slinger ring around the fan, the water may have caused it to trip an overload sensor.
This is a window unit, right? Is it pitched back at a small angle?
Most of them don't have a drain hole now - they use the water to help cool the evaporator, slung on by the fan.
Never seen one with a switch on the cover, but I don't get out much anymore [was an A/C mechanic in college].
Garandman is offline   Reply With Quote
Old 06-01-2010, 02:58 PM   #15
wawawrx
Member#: 200730
'08 E92 M3
'95 GC ZJ
A/C came back from T/O
wawawrx is offline   Reply With Quote
Old 06-01-2010, 03:18 PM   #16
-=C=-
Member#: 7719
99 F-150 crew cab
Not a window unit...full system.
Ot Golfers, you will never believe what happened to my club today JewPac42 Off-Topic 38 04-21-2006 08:28 AM
Help me guess what happened to my broken engine!! (long) Daveish Normally Aspirated Powertrain 12 04-14-2004 10:05 AM
('93-'01) What happened to my brakes? Roquet Impreza Forum 1 05-23-2001 08:17 PM
what happened to my bass? sjt Car Audio, Video & Security 7 04-14-2001 05:03 PM
Ho NOOO!!! what happen to my CAR ChAi North West Impreza Club Forum -- NWIC 65 01-18-2001 11:53 AM
