Old 06-01-2010, 06:15 PM   #1
maruksai
Member#: 233276
2009 2.5i Hatch
Default Response from SOA on Center Differential
So I asked SOA if my 2009 2.5i MT has a center differential. I also asked about service interval because the center differential isn't mentioned in the owners manual at all.
Thank you for taking the time to contact us.
Your 2009 Impreza 2.5i with manual transmission does have a center differential. The details of the AWD system as noted in the 2009 Impreza brochure is: Models equipped with 5-speed manual transmission utilize a viscous-type locking center differential with torque distribution normally configured at a 50/50 split front-to-rear.
As for maintenance recommendations, the information on manual transmission oil is found starting on page 11-20 in the owner's manual and for the rear differential gear oil, the information is found starting on page 11-24. There is no maintenance recommendation for the center differential.
Thank you for the opportunity to be of service. If you need any future assistance, please let us know. Have a great day!
Sincerely,
John J. Mergen
Subaru of America, Inc.
Customer/Dealer Services Department
1-800-SUBARU3 (1-800-782-2783)
Service Request #1-867900205
Should I change the oil in the Center differential? I did the rear differential and the actual tranny. If so, does anyone have a pic of what the center differential looks like and if it's hard or easy to change? How mush oil? 0.8qt like the rear dif?
maruksai is offline   Reply With Quote
Old 06-01-2010, 06:33 PM   #2
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
You can't get to the center differential fluid without taking apart the back section of the transmission. It (the center diff) is sealed with the viscous fluid in it.
jay25RS is offline   Reply With Quote
Old 06-01-2010, 06:48 PM   #3
maruksai
Member#: 233276
2009 2.5i Hatch
I just changed my MTF, so does that mean that the new fluid is flowing through the center differential?
Old 06-01-2010, 06:51 PM   #4
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Yes.
And why did you ask if you had a center diff? How did you expect to have AWD without a center diff? Transfer case or something?
Old 06-01-2010, 06:58 PM   #5
cowboy_Rob
Member#: 194062
2003 Impreza WRX
+1 for what jay25 said
the center diff shares oil with the trans. the actual viscous fluid is internal to the viscous coupling and cant be changed other then replacing the whole coupling.
cowboy_Rob is offline   Reply With Quote
Old 06-01-2010, 07:19 PM   #6
maruksai
Member#: 233276
2009 2.5i Hatch
Originally Posted by kpluiten View Post
Yes.
I asked because the center differential isn't mention in the owners manual at all. I was looking for another case type of compartment where the driveline intersects with the rear wheels. However I didn't see any other areas that could house fluid.
Old 06-01-2010, 07:26 PM   #7
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Center and front diffs share oil with the transmission. The viscous coupling unit is buried in the diff and not use-serviceable.
sniper1rfa is offline   Reply With Quote
How much play or "lash" is normal on center differential? Clunk noticed. BBBsti LTD Transmission (AT/MT) & Driveline 8 05-21-2009 09:11 PM
FYI: response from Redline on 75W90 & motor oil ripvw Transmission (AT/MT) & Driveline 3 11-03-2005 11:22 PM
Response from Subaru on my clutch complaints Alldidasmc Transmission (AT/MT) & Driveline 8 10-21-2004 09:45 AM
got my response from SOA RaceCarRiot Warranty Issues & SOA Problems 13 10-19-2001 06:24 PM
The mystery of the TD04L goes on.....response from SOA..... D-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-27-2001 12:28 AM
