Old 06-14-2010, 06:00 PM   #101
02ej20wrx
Member#: 245333
psm
i totally agree i only have drilled and slotted rotors because i got them on sale and were only $20 dollars more than stock.. they do have a better initial bite but no better stopping distance..
02ej20wrx is offline   Reply With Quote
Old 06-14-2010, 06:06 PM   #102
down_for_the_scooby
Member#: 78314
04 PSM WRX
Audi mask the right way
Noob question. Dave explains away the drilled rotors but how about the slotted rotors, billed as slicing the pad down to give a new surface with each brake. Do these actually improve stopping performance or are they also just bling?
down_for_the_scooby is offline   Reply With Quote
Old 06-14-2010, 07:25 PM   #103
rexman2002
Member#: 140244
02 bugeye
"stare ale jare"
That's because you're using better pads, with more initial grab than oem.
rexman2002 is offline   Reply With Quote
Old 06-14-2010, 07:31 PM   #104
andrew3776
Member#: 172133
2003 vfdirty wrx
rotten banana
Hey, I went from sunny tires to re70's and I can confirm that this is true. For all you haters, piss off because your a moron.
Have a nice day.
andrew3776 is offline   Reply With Quote
Old 06-14-2010, 10:42 PM   #105
Deserted1
Member#: 110902
2010 Toyota Tacoma
Super White
Originally Posted by lgbcb View Post
Adding to OP before mentioned mechanical (e.g fade) and external factors (e.g. friction) of stopping a car:
Braking capability which depends on factors such as;
  • the type of braking system,
  • brake pad material,
  • brake alignment,
  • tire pressures,
  • tire tread and grip,
  • vehicle weight,
  • suspension system,
  • the co-efficient of friction of the road surface,
  • wind speed,
  • slope of road,
  • surface smoothness
  • the braking technique applied by the driver.
To truly discuss braking one must consider the following:
  • Human Perception Time
  • Human Reaction Time
  • Vehicle Reaction Time
  • Vehicle Braking Capability
The human perception time; is how long the driver takes to see the hazard, and the brain realize it is a hazard requiring an immediate reaction. This perception time can be as long as to a second. Add to this human reaction time vary from - of a second. There two components of stopping distance are human factors and as such can be effected by tiredness, alcohol, fatigue and concentration levels. A perception and reaction time of 3 or 4 seconds is possible. A driver perhaps 1 second late in applying the brakes @ 60 mph the car would require about 100 feet further to stop.
Hmm something tells me you drive something bigger than a car for a living... I have heard all this before while getting my CDL.
And its all true, I just want to throw a tid bit more info into this whole mess.
Remember your not stopping HP just weight and momentum. Brake systems are designed on vehicles for their weight, sometimes stripping away that weight can cost you stopping distance if you no longer have enough friction, sometimes adding weight can also help you in stopping. All depends on how the brake system was designed for that vehicle.
I know stopping my Semi that weighs in closer to 80k is alot easier than stopping it when it ways in at 30k. Its how the brakes were designed, to hold that weight, when I have less weight I have less friction to the ground, takes me longer to stop.
Deserted1 is offline   Reply With Quote
Old 06-15-2010, 10:54 AM   #106
TurboNinja
Member#: 249463
Default Example
New to the site, and impressed. This is totally solid and true, but if I hadn't experienced it I may not believe it.
Take it from me as an this is an extreme example, I bought a MY95 jdm impreza, fresh from Japan running approx 400whp, IT HAD STOCK CLAW CALIPERS, not even a one pot. Despite initial reservations they worked fine, only changing them as the car is to be used as a show & go car.
Crazy!
TurboNinja is offline   Reply With Quote
Old 06-15-2010, 11:02 AM   #107
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
This man (OP) speakith the truth.
I am very happy with my stock brembos, Hawk HP+ pads, RE11 tires, and 8ft 30-0 stop distances.
And I've driven vehicles with visually less sophisticated brakes (1 or 2 piston conventional calipers) that stopped even better than my STi with a firmer pedal feel as well.
Dirty25RS is offline   Reply With Quote
Old 06-15-2010, 01:02 PM   #108
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Sigh... this will all end in tears.
The OP oversimplified the problem. He neglected to explain that brakes have a fixed rate at which they can dissipate thermal energy. Adding more power to the engine gives you the ability to ask the braking system to dissipate the same thermal energy in a shorter time because you can ask them to stop a second (or 3rd, 4th, etc) time much sooner. Think about it this way, you can rip off 10 0-60-0mph speed runs in a much shorter time with 300hp than you can with 30hp. That drives your braking system up to a much higher temperature. Hell, you can feel this dramatically if you go out to bed new brakes in an RS vs WRX.
The OP is absolutely right, you don't upgrade the brakes when you make more power to stop in a shorter distance. You don't upgrade the brakes when you make more power to make sure you can still stop from 130mph when a deer runs into the road. The OP misses, however, that you upgrade the brakes when you make more power so that, after 30 minutes of yo-yoing between 20 and 70mph when you and your buddies go play in the hills, you stop at all.
Now, I also think the point that we should encourage people who add weight to their cars (stereos, whatever) to upgrade their brakes (again, for thermal reasons) is a damned good one.
Old 06-15-2010, 01:59 PM   #109
Noek
Member#: 206316
2009 STI StageII
this is mostly true for class A vehicles equipped with air brakes. I'm not sure this is as detrimental in hydraulic brakes as it is in air brakes. For hydraulic or mechanical, I was always under the impression that you get better braking by lightening up the vehicle whereas the opposite is true for air.
Noek is offline   Reply With Quote
Old 06-15-2010, 06:33 PM   #110
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
stoping faster/shorter is = faster reaction time
^Lines which dont baloon when you push the brake
brake pads that bite harder.
wrxsubiemod is offline   Reply With Quote
Old 06-17-2010, 10:17 PM   #111
06WrXChad
Member#: 220282
2006 WRX Wagon LTD
So what would be the best rake for the buck?
06WrXChad is offline   Reply With Quote
Old 06-17-2010, 10:18 PM   #112
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Define "best".
Old 06-17-2010, 10:29 PM   #113
LIQUIDSK8S
Member#: 22605
2002 JDM STI/WRX
I prefer this one
http://www.homedepot.com/webapp/wcs/...5&marketID=373
LIQUIDSK8S is offline   Reply With Quote
Old 06-18-2010, 12:37 PM   #114
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I heard of a lot Home depo mods but this one takes the cake^ or should I say rake? lol
Old 06-18-2010, 05:15 PM   #115
lovin' it
Member#: 236710
2010 WRX Five Door
WRB!
OP, Very helpful thread, TY!
lovin' it is offline   Reply With Quote
Old 06-18-2010, 09:15 PM   #116
resipsawrx
Member#: 227941
OP:
Good post, but caveat emptor to anyone totally "buying" this advice.
Take the original post in its proper context.
Stock WRX brakes, with HPS pads, and "ghetto" fluid WILL NOT NECCESSARILY hold up on a track day OR on spirited mountain twisties. I live on a mountain and my daily commute can evolve into spirited driving. On my first track day in my relatively recently acquired '07 WRX Wagon (converted to "STI" over the winter) (previous ride - SM/Track Day/DD MINI Cooper S). Track day resulted in nearly 0 pedal (near the end of a 15 minute run) after just a couple of 15 minute sessions, 45 minute cool down between sessions. Boiling fluid, overheated brakes = dangerous situation. Spirited street driving can also induce brake fade.
Manner of driving is a critical factor in considering what, if any, brake upgrades may be beneficial.
Len
resipsawrx is offline   Reply With Quote
Old 06-20-2010, 03:29 PM   #117
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Originally Posted by rexman2002 View Post
Can anyone recommend any good blank rotors besides oem/brembo? I had oem rotors for 30k/oem pads, and started getting shakes in the steering wheel. Now have autozone blanks with about 5k miles w/stoptech pads, and same thing, steering wheels vibrates/shakes when I brake. I'm not looking for slotted/drilled, just looking for good blank rotor.
THat is likely due to pad material unevenly distributed on the rotors. You can remove that material with some fine sand paper or brillo pad and quit replacing rotors so often.
Or you can do what I used to do. Take the car up to 60-70mph and brake hard down to 20mph 3-4 times in a row to remove it. THen drive around without braking or braking hard to let them cool down and don't hold the brakes on when stopped unless your car is going to roll.
silver arrow is offline   Reply With Quote
Old 06-20-2010, 03:37 PM   #118
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
What are you going to do with the car?
For spirited driving a good set of pads and good brake fluid will be your best upgrade for the bucks.
Track, a set of Brembos off of a parted out STI with good pads, fluid, proper brake ducting would be best bang for the buck.
Old 06-20-2010, 11:59 PM   #119
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
I just deleted 17 useless, immature posts from this thread. If people wanna argue and act a fool and can't be civil about it, I'll be more than happy to remove that individual's right to post for a little while.
Don't make me turn this bus around
Audiosavvy is offline   Reply With Quote
Old 06-21-2010, 12:02 AM   #120
Yo Yo
Member#: 249857
2007 WRX TR
Satin White Pearl
That is funny shtuff. I really do love canadians though
Yo Yo is offline   Reply With Quote
Old 06-21-2010, 12:04 AM   #121
TiredGXP
Member#: 245040
2010 Legacy GT
Well, this used to be a good thread before the pissing match broke out.
I think the OP made some good points.
Are there situations where upgraded brakes are required? Yes.
Will some people spend the money to upgrade brakes even where it's not really required? Yes.
Should anyone else care? Probably not, it's their money.
TiredGXP is offline   Reply With Quote
Old 06-21-2010, 12:07 AM   #122
Yo Yo
Member#: 249857
2007 WRX TR
Satin White Pearl
That is what I tried to say from the begining. I don't know why it is a big deal. This mod is up to the person that wants to do it. I am just not as good with words as you are.
Old 06-21-2010, 09:49 AM   #123
resipsawrx
Member#: 227941
In my earlier post (#116), I wanted to share not just an opinion, but my personal experience, as even a limited amount of track driving, with significant cool down between runs, still overwhelmed my brakes, even with HPS pads. This created a potentially dangerous situation.
I felt compelled to post in this thread because I did not want people to get too secure in their stock brake system by taking the OP's (and others) comments out of context, and find themselves in a spot of bother on the track, or on a "spirited" drive somewhere, as the stockers are not but so good. Even better fluid alone is not a bad idea.
While some MAY never need any brake upgrade, our (proud to be a new complete convert to the Subaru platform) cars are so good that it is kind of sad to think that there are those who won't drive this car to its potential - and if you do drive the car to its potential, you are going to have issues with the stock brakes.
On the Subaru, to say the stock brakes are plenty sufficient for some sort of "vast majority" of owners, is in my opinion an overstatement, or at least a statement that might lead to the "wrong" kind of owner/driver having a misplaced level of comfort in the stockers.
Len
Old 06-21-2010, 11:01 AM   #124
WrXLoLiS
Member#: 248336
Turn it around!!! I wanna go back home
Nah but seriously amusing to say the least, now as far as my opinion on the OP goes I concur they are not that much of a DIRE necessity... but then again it's YOUR money use it when YOU need it, call J.G. Went... mmmm yeah
WrXLoLiS is offline   Reply With Quote
Old 06-21-2010, 01:15 PM   #125
rexruther
Member#: 249045
07 WRX
good write up but where can i get superbuttseks increditanium lines?
rexruther is offline   Reply With Quote
Creepy cat is going to get you. aod Off-Topic 32 10-26-2011 03:00 AM
this is going to break a lot of hearts brentyloke General Community 5 10-25-2008 12:36 AM
this thing is going to get me fired dr_wheel Off-Topic 9 12-09-2004 06:43 PM
Do you think this is going to cause problems? AustinSTi Normally Aspirated Powertrain 7 11-27-2003 09:08 PM
