Old 06-01-2010, 08:34 PM   #1
iluvdrt
Member#: 46248
82 Brat
Tan
Default P0130 O2 malfunction bank 1 sensor 1
I have been getting this code for awhile now. I bought a new O2 sensor (front one) and the car wouldn't even run. Turns out the O2 heater had a short to ground. I took it back and got another one. The car runs now, but it is still throwing the same code. Could it be I got another bad sensor, or is there an underlying problem?
Things I have checked:
Engine Vacume-about 22" at idle
Fuel pressure-35-40psi
changed crank and cam sensors
cleaned O2 connector
checked for exhaust leak pre-sensor
Any ideas about how to check this out or t-shoot it?
iluvdrt is offline   Reply With Quote
Old 06-01-2010, 11:24 PM   #2
GrundleJuice
Member#: 165749
i assume you have reset the ECU since installing the new sensor? if not, it will take some time for the ECU to experience the conditions necessary for it to re evaluate the data that is/was out of limits.
To troubleshoot with any usefulness you will need to log.
What vehicle is this on, anyway?
Old 06-02-2010, 06:12 AM   #3
iluvdrt
Member#: 46248
82 Brat
Tan
Computer has been reset multiple times to rid the rid the code. It has been set with a scanner and by unplugging the battery.
Vehicle is a 98 Legacy GT wagon. Usually after resetting it takes about 10-15 min of driving before the CEL comes back.
Old 06-02-2010, 10:02 AM   #4
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
could there possibly be a short in the engine side of the harness? my 0131 code was resolved with a new sensor, but part of the diagnostic problem was making sure resistance in the engine side harness was over a certain reading.
This was the trouble tree provided to me by a friend with access to snap-on shopkey5
Diagnostic trouble tree P0131
1- Check front O2/afr sensor connector and coupling for water intrusion
yes - completely dry out and pack with dielectric grease
no- go to step 2
2- Check harness between ECM and Front oxygen/AF ratio sensor.
-Turn ignition switch off.
-Disconnect harness from ecm and A/F sensor.
-Measure resistance between ecm plug pins #8 & #9 to chaise ground
-Is the resistance greater them 1M ohms ?
no - repair short in circuit
yes- go to step3
3-Check Poor Contact in A/f sensor plug
-Is there poor contact in the connector?
with a fine paper clip check to see if the female side terminals have drag on the paper clip.
no poor contact- repair terminals
yes good contact- replace a/f sensor
Sir-Knight is offline   Reply With Quote
Old 06-02-2010, 11:14 AM   #5
iluvdrt
Member#: 46248
82 Brat
Tan
OK, Ill check these out when I get home. Thanks!!
Old 06-02-2010, 06:08 PM   #6
iluvdrt
Member#: 46248
82 Brat
Tan
Here is the data log from the freeze frame data when the latest code hit:
Fuel sys- OL
Fuel sys 2-NA
calc load-17%
ECT-183.4
STFT-0.00
LTFT-0.00
MAP-(KPA) 43
RPM-2562
Veh spd-33MPH
wtb bank 1 sensor 1 o2 sensor 03wrx05rscouple Tri-State Area Private Classifieds 1 08-03-2008 06:54 PM
P0134... Where is Bank 1 Sensor 1? j.reed Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-08-2008 01:19 AM
Bank 1 Sensor 1 on a 98 GT....... VOLTIS5 Legacy Forum 3 05-02-2006 02:43 PM
P0130 code, O2 malfunction, now what? dingo dave Normally Aspirated Powertrain 12 02-28-2003 04:44 PM
I just got P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) tmat3 Normally Aspirated Powertrain 18 03-03-2002 03:25 PM
