Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Closed Thread
Old 06-01-2010, 07:52 PM   #1
flat4motorsports1
Vendor
Vendor Sales Rating: (1)
Member#: 246331
Default new to nasioc but not new to subaru
hello eveybody my name is Carlos im one of the subaru experts at http://flat4motorsports.net i would like to invite you to come check out all the new parts in our store. new parts are added daily.we have a huge line of parts for any budget. we carry a huge selection of turbo upgrades, power packages, intercooler upgrades,blow off valves clutch upgrades suspension packages and much much more. we have a large selection of subaru parts everything from 2002 - 2008 subaru impreza wrx sti as well as early model subaru and forester. we also carry a few parts for honda and mitsibishi.we have shopped the competition in order to offer you the highest quality product at the lowest price any where!!
FLAT 4 MOTORSPORTS
6401 BROADWAY UNIT D
DENVER COLORADO
80221
(720)-540-8888
hey kids good news we are getting a special order of dc shoes just for the grand opening - Ken Block spartans ,subaru dc pure's and more.
if you dont see it in our store email at [email protected]
we are official skunk2 racing,perrin and agency-power dealers
do you auto cross ?? do you rally cross?? want to get closer to the cones with more control?? want to huh huh huh huh ?????
we also carry the perrin posative steering response and anti lift kit
this kit will not only make steering easier but it will stiffen your launch . the front end stays locked down like the rear with the subframe lock down kit
add a set of perrin enlinks and sway bars for the finishing touch
get everything you need to make your car faster at
http://www.flat4motorsports.net
we now have these little babies they are going fast
our little turbos need no modification they have been ground polished and oiled at the manufacturer so they spin super smooth.
real spinning turbo keychains
For the real SERIOUS racer, tuner, import, or domestic boost enthusiast! This is THE most intense turbocharger keychain available! The KCT-11RS is a full 3D model cast of high-grade polished metal alloy composed of three primary pieces just like a real turbo (backplate, spinning impeller, and housing). Each turbo keychain also includes a compressor performance specification card! we are authorized turbo keychain dealers so we can offer the lowest price!!
GRILLCRAFT GRILLS FOR EVERY IMPREZA
2002-003 subaru impreza
2004-2005 subaru impreza wrx sti
2006 - 2007 subaru wrx sti
08 09 subaru impreza wrx sti
we also have he hood scoop grills too
just to name a few.these are the tough grilles you see on all the rally cars . they are welded and reinforced.no cutting needed for install just bolt in.
GrillCraft MX-Series Grilles are made from our exclusive steel mesh pattern design along with our micro-frame design. All MX-Series grilles are zinc plated then finished with a 3Stage baked on powder coating in either Aluminum Silver (Shines like polished aluminum in sun light) or Gloss Black finish. GrillCraft is committed to ensuring that every MX-Series Grille we produce will exceed your expectations, guaranteed.
we have grilles for every rally car just ask at
[email protected]
perrin perrin we have lots and lots of perrin- lowest prices and fastest shipping anywhere.
end links
up pipes and down pipes
oil catch tanks
intakes and blow off valves
we have everything in stock and ready to ship today!!
dont miss out on the lowest prices on perrin any where free shipping on almost everything in our store.
if you see it on the perrinperformance.com and we dont have it listed let me know and we will get it for you at and save you $$$$$
we have parts for every rally car just ask at
[email protected]
KEN BLOCK SUBARU WORLD RALLY TEAM MONSTER T SHIRTS EVERY SIZE
we are almost out of the subaru ken block 43 rally team jacket size m and L .we only have a couple left .after this they will no longer be available. just look at the quality
we have them all in stock and ready to ship today!!
flat4motorsports1 is offline
Old 06-02-2010, 05:27 PM   #2
flat4motorsports1
Vendor
Member#: 246331
want to kick the old lady out of your subaru? does your car have the subframe lock down kit ? one way to tell is jack up the rear end and look inside the wheel wells in the back to see if the bolts are in or if the holes are still open. the bolt holes are on all wrx .they will help with any type of racing you might do they lock the rear diff of the car so it does not rotate on take off . subaru makes it loose for the old ladies so they wont jerk their neck on take off with a turbo.sadly old ladies have weak necks and subaru makes fast cars. if you are going to rally cross or any type of racing you will feel the change.they only take a few minuets to install in any drive way no major mechanical knowledge needed.
get the power to the wheels!!
Add drivetrain rigidity and precision to throttle input to your Subaru with our PERRIN PerformanceTM Diff Lock Down System. This kit consists of (2) kits in one, the DLS and SLS. The DLS (differential lock down system) consists of 6 urethane bushings to lockdown the rear differential support beams. This helps remove movement from the rear differential under extreme conditions such as drag racing and road racing. Under these conditions the drivetrain (diff included) will twist and move around before it starts to turn the wheels causing a "squishy" or spongy feel at the point of initial acceleration. The PERRIN rear diff lock down (DLS) locks the differential by stiffening up the front and rear mounts for zero movement so when you push on the gas, the car goes with no delay.
Also included in the kit is the PERRIN (SLS)Subrame lockdown kit. The rear subframe on the 02-07 Impreze/STI/WRX is monted to the chassis with rubber bushings. Under extreme conditions like road racing where high cornering forces are seen, the subframe moves around causing a loose feeling in the car. This also can cause the alignment of the wheels to change, also causing a feeling of looseness.
As you can see both the SLS and DLS goes hand and hand and can make a noticeable difference on your 02-07 STI/WRX/Impreza.
$49.99
__________________
Old 06-02-2010, 08:28 PM   #3
flat4motorsports1
Vendor
Member#: 246331
Want huge horse power??
YOU NEED THE PERRIN ROTATED TUBRO KIT
PERRIN ROTATED TURBO KIT
KIT INCLUDES
* Rotated Turbo Uppipe
* Rotated Turbo Downpipe
* GT Turbo Assembly
* Wastegate
* STI oil line with female fitting (WRX oil line with banjo fitting is ordered separately)
* Gasket set (T3 inlet, Turbo outlet, GT oil drain, 3” gasket, (2) restrictors)
* Banjo Coolant Sets (M14 banjo bolt, M14 banjo fitting, (2) M14 washers)
* GT oil drain flange
* 3/8NPT- 1/2” barb 45 degree fitting
* 10mm x 1.25mm Studs
* M8 x 20 Socket cap screws
* M8 x 25 Socket cap screws
* 1/2”-3/8” reducers
* 1/2”-5/8” reducers
* 3/8” reducer
* #3 hose clamps
* T-bolt 175 size
* 8 PERRIN PYROshield
* 1/2” Fuel hose
* 6 Pushlock coolant hose
* 5/32” vacuum hose
* Zip ties
* Aluminum 3” Turbo Intake (Polished, Red Wrinkle, or Black Wrinkle)
* 3” Silicone Reducer coupler (Black coupler for red, or black pipe and Red coupler for polished pipe)
* 2”-2.25” Silicone Jog coupler (Black coupler for red, for black pipe and Red coupler for polished pipe)
* 3”ID 2 piece air filter
* Size 64 hose clamp
* Size 48 hose clamp
* Size 36 hose clamp
* Size 6 Micro hose clamps
* 1/2” tees
* 1/2” straight connector
* 3/8” Straight connector
* 3/8”-5/16”connector
* 5/32”-1/8NPT fitting
* 1/2” fuel hose
* 1/4” fuel hose
* 5/32” Vacuum hose
* Instructions
__________________
Old 06-05-2010, 12:41 AM   #4
flat4motorsports1
Vendor
Member#: 246331
__________________
Old 06-05-2010, 09:17 AM   #5
flat4motorsports1
Vendor
Member#: 246331
__________________
Old 06-06-2010, 01:41 AM   #6
flat4motorsports1
Vendor
Member#: 246331
june 6 d-day subaru impreza drive in meet up
june 6 2010 flat4 motorsports will be having a d-day subaru meet up and sale . in honor of the sacrifices made june 6 1944 . that includes phone in orders. we have the whole lot to ourselves fill with subaru . we will have food and give-aways . come down and show your ride and talk subaru with the subaru experts,every one is welcome to come down. ask questions ,there will be plenty of people around answer questions.
let me know if your coming down just so i can plan for enough food
if your in colorado rally cross we will be helping kids get set up for rally cross and scca - rules car prep + stuff .
the last time we had one of these little meets it turned out great we had atleast 20 cars show up from one week of planning. let me know if you have any suggestions how to make this one better
we have talked to the local 4wd dyno guy he will come by to talk to people about dyno tunes
they have been pulling some impressive numbers lately
__________________
Old 06-06-2010, 01:53 AM   #7
flat4motorsports1
Vendor
Member#: 246331
__________________
Old 06-06-2010, 11:05 AM   #8
flat4motorsports1
Vendor
Member#: 246331
sounds like lots of people are coming down. should be fun!!
__________________
Old 06-07-2010, 01:15 AM   #9
flat4motorsports1
Vendor
Member#: 246331
we had a great tun out today lots of really nice cars!!
thanks every one for coming out . sorry we didnt have some of the stuff you needed. i had it planned as more of a meet up and hang out type thing. next time i will have more in stock . i promise
lots of really nice cars out there today!! you kids really know your stuff!! we will have to set up flat4 rally cross day . we could even run a mud pit so people can get their mud on. we could set up timming and cones and all. any one interested ? pm me with a good date to set it up for.
Carl would let us take over core for a day. im sure every one has been out there. judging by the cars that came out today we would have a pretty good day.
thanks again to every one for coming out !! we had a great time hope you you did too! your all welcome at our shop any time . if you ever need anything just let us know :grin:
__________________
Old 06-07-2010, 11:14 PM   #10
flat4motorsports1
Vendor
Member#: 246331
we have a special package deal
skunk 2 racing limited edition radiator hose kit with bonus radiator cap
radiator hose and cap set usually retails for for $175.99 without a radiator cap.
we have them for 125.99 that includes the radiator cap. you cant find this deal any where else this is a special from flat4 and skunk2.
click here for our special on skunk2 special limited edition radiator kit
we also have a special price on subaru impreza lowering springs
normal retail on the skunk2 racing lowering springs is usually 175.00 we have them for 169.00
click here for the special price on skunk2 lowering springs
__________________
Old 06-07-2010, 11:53 PM   #11
flat4motorsports1
Vendor
Member#: 246331
thanks again to everyone who came down to the shop this week end !! i cant say how much fun it was. we met lots of great people and i hope to see you all again very soon!! come back any time you are all always welcome at Flat4motorsports!!! :-P
__________________
Old 06-08-2010, 12:03 PM   #12
ppericfe
Member Sales Rating: (3)
Member#: 117973
2004 GT52 sti
FJ cruiser vodoo blue
How much is the keychain?
ppericfe is offline
Old 06-08-2010, 12:10 PM   #13
flat4motorsports1
Vendor
Member#: 246331
we sell them for $13.95 on our website.there are some lower quality versions out there but we sell the original . these are high quality fully assembled spinning turbo key chains . first time you hear it spin youll be in love.
click here for real spinning turbo key chain
__________________
Old 06-08-2010, 03:22 PM   #14
flat4motorsports1
Vendor
Member#: 246331
__________________
Old 06-09-2010, 12:16 AM   #15
flat4motorsports1
Vendor
Member#: 246331
WE CAN ALSO INSTALL EVERYTHING SO ITS ONE STOP.
__________________
Old 06-10-2010, 09:42 PM   #16
flat4motorsports1
Vendor
Member#: 246331
__________________
Old 06-12-2010, 02:27 PM   #17
flat4motorsports1
Vendor
Member#: 246331
sparco mud flaps and hks bov flanges back in stock
__________________
Old 06-12-2010, 04:15 PM   #18
flat4motorsports1
Vendor
Member#: 246331
Flat4motorsports will be out at Pikes Peak Fanfest June 25 from 5-10 pm
http://www.usacracing.com/ppihc/fan_fest
Fan Fest is the annual pre-race celebration held in downtown Colorado Springs (Tejon St. between Colorado Ave. & Bijou St.) promoting the Pikes Peak International Hill Climb. This event is FREE and typically features a large Budweiser beer garden, live bands, chili cook-off, motorcycle jumpers and Denver Bronco cheerleaders as well as other live entertainment. Top race qualifiers will display their vehicles (cars, trucks, quads, motorcycles, etc.), give driver demos and be present for autograph sessions.
__________________
Old 06-13-2010, 02:37 PM   #19
flat4motorsports1
Vendor
Member#: 246331
if you have never been to a fanfest you have to come out. where else can you meet a giant like Monster Tajima or Rhys Millen the king of the mountain in person????? if your into motocross there is always Metal Militia. See the hill climb Coyote from Martini racing and much much more . its a good time for all. food fun cars and bikes what else could you want???
oh yeah and dont forget to stop by the flat4 tent to say hey
__________________
Closed Thread
New to Nasioc but not Subies! GreenEJ Newbies & FAQs 4 01-16-2009 03:35 PM
New To NASIOC but not to the Subaru World Subastar24 Newbies & FAQs 11 01-05-2009 12:58 PM
new to nasioc but not subarus i<3mybugeye Newbies & FAQs 17 12-08-2008 11:21 PM
New to nasioc but not to subies 02 wagon NY Newbies & FAQs 5 01-23-2008 08:42 PM
new to nasioc but not to subies hipower Vancouver Impreza Club Forum -- VIC 7 08-12-2007 02:31 AM
