Old 06-01-2010, 09:00 PM   #1
red06rex
Member#: 246914
2006 wrx
Default 6spd swap question
im currently doing a 6spd swap on my 06 wrx..im sure there is a thread about my question but i cant find it..what exactly do i do with the connector on top of the tranny for the dccd when im not using it? i was told the 5spd has 4 wires and 6spd has 6..and i was told to cut the connector and soder the wires..any suggestions?
red06rex is offline   Reply With Quote
Old 06-01-2010, 09:45 PM   #2
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Coil it up and zip-tie it to the side of the trans or put leads on it and tie it to the dog bone.
Old 06-02-2010, 08:00 AM   #3
talvai
Member#: 136358
2006 WRX Limited
6mt/5x114/vf43/S204
I cut 2 dccd cables solder about 10ft of extra cable to it and ran it through the firewall and inside car. This way I had cable sitting there and ready for when I did my dccd controller.
talvai is offline   Reply With Quote
Old 06-02-2010, 12:09 PM   #4
tramix
Member#: 148317
1998 Subaru Impreza
Brilliant Red
your 2 options are posted above. You don't have to cut the connector. If you can find 6pin connecter you can just depin/repin your wrx connector and plug it right in. Later on you can pin the 2 dccd wires for that function. You will want to make some sort of connection there and not a permanent solder in the event you need to make repairs/clutch/etc.
Dccdpro is a nice controller if you want to grab one now or later.
tramix is offline   Reply With Quote
Old 06-02-2010, 12:14 PM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
+1 On the DCCDPro. I could not be more satisfied with the product. If you do decide to go that route or at considering it, hit me up and I can answer any questions you might have. Or you can email DCCDPro and you will also get exceptional service.
Old 06-02-2010, 06:41 PM   #6
red06rex
Member#: 246914
2006 wrx
thanks for the info guys
6spd swap question talvai Transmission (AT/MT) & Driveline 5 07-15-2009 11:34 AM
6spd swap question ryan_west06 Transmission (AT/MT) & Driveline 5 05-30-2008 09:23 PM
6spd Swap Questions Ryanr1490 Transmission (AT/MT) & Driveline 5 05-19-2008 11:45 PM
Another 6spd swap question gnarlyWRX Transmission (AT/MT) & Driveline 1 11-22-2007 11:49 PM
any 5spd gears to hold 350+whp, and a couple 6spd swap questions...please help jimtweet Transmission (AT/MT) & Driveline 37 08-02-2006 05:55 PM
