Old 06-01-2010, 09:08 PM   #1
Dane509
Member#: 204683
2004 STI
JBP
Default Compression Test Results. OK?
Started up my car and drove about 10 minutes to the dealership for a compression test. Car probably sat for another 10 minutes before being taken in for the test, so the motor was decently warm, but not overnight sitting cold.
2004 STi
72,xxx miles
Cylinder 1 - 135
Cylinder 2 - 135
Cylinder 3 - 150
Cylinder 4 - 140
The 150 and 140 look fine to me but the 2 135's seems a bit odd to me. Or am I just being worried over nothing?
Dane509 is offline   Reply With Quote
Old 06-01-2010, 09:15 PM   #2
ShaneInHisRoom
Member#: 148737
Yarp.
ShaneInHisRoom is offline   Reply With Quote
Old 06-01-2010, 09:16 PM   #3
THEVERGE
Member#: 127421
2002 Subaru WRX
I don't think those numbers are good. They should be within, I think, plus or minus 5 psi to be kosher.
THEVERGE is offline   Reply With Quote
Old 06-01-2010, 09:18 PM   #4
Dane509
Member#: 204683
2004 STI
JBP
1 yay and 1 nay. Anyone else?
Old 06-01-2010, 10:06 PM   #5
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
you=ok
jerbull88 is offline   Reply With Quote
Old 06-01-2010, 10:53 PM   #6
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
135 seems low for these motors. 145-150 is good. and with the large difference throws me off too. how many cranks where done on each cyclinder? you should only do about 4 cranks on each.
synolimit is offline   Reply With Quote
Old 06-01-2010, 11:25 PM   #7
Dane509
Member#: 204683
2004 STI
JBP
I'm not too sure. They handed me the paperwork and told me that 135 is a little low but it's still fine. But I don't know how many cranks were done on each cylinder. Just weird to me that #1 #2 cylinders were 135 and the other two are way within spec.
Old 06-02-2010, 01:36 AM   #8
07wrx4life
Member#: 171514
07 DOM 3 WRX
352/326 @ 20psi EQ Tuned
All cylinders should be within 10% of each other not 5 psi, just letting you know.
135 on 2 cylinders Is a little low but I wouldn't cry about it just yet 120 or lower would really show signs of a dieing motor.
Keep on boostin Op
07wrx4life is offline   Reply With Quote
Old 06-02-2010, 03:16 AM   #9
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Out of curiosity..how much did this compression test run you through the dealer?
Coop1103 is offline   Reply With Quote
Old 06-02-2010, 11:21 AM   #10
Dane509
Member#: 204683
2004 STI
JBP
I'll need to take a look because I got new plugs and an oil change at the same time. I think everything came out to about $350. Sucks when there isn't really anywhere else in town I can take the car for that stuff besides the dealer.
Old 06-02-2010, 12:37 PM   #11
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
You're fine. As long as it's not like 130-130-130-45, you're good to go.
Acejam2k is offline   Reply With Quote
Old 06-02-2010, 12:46 PM   #12
Sifounas
Member#: 222684
2007 STi
Yeah ideally you want them to be closer, but if you had a blown piston the reading would be much lower than 135.
Sifounas is offline   Reply With Quote
Old 06-02-2010, 03:27 PM   #13
Dane509
Member#: 204683
2004 STI
JBP
I guess my second question would be, would it still be safe to throw my car up on a dyno? I'm planning on getting it tuned here pretty soon and just want to make sure everything looks good before doing so.
Compression test results. Do they look ok? darksands Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 10-31-2005 08:00 PM
Compression Test Results @ 55,650k PaulRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-12-2003 02:59 PM
EJ25 Compression Test Results at 50,000 miles latinskllz Normally Aspirated Powertrain 4 11-11-2002 02:46 PM
Compression Test Results- 3 Motors dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 10-31-2002 11:32 PM
Compression test results numbers Imprezer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 09-12-2001 01:08 AM
