Go Back   NASIOC > NASIOC Classifieds > Private 'Wanted' Classifieds
Old 06-01-2010, 10:30 PM   #1
GraphicWRX
Member Sales Rating: (21)
Member#: 57743
2015 Golf TDI
Default SPEC B axle part numbers
History: 03 WRX with a 6spd and R160 open rear diff
After a day at the track, the open diff is just not going to cut it. I knew this was going to be a problem, but I thought I would try it first.
Solution: R180 from an STI and the Legacy Spec B rear axles.
Problem: I have two part numbers:
First one is from here, courtesy of a few individuals; 28421AG03b
Second one is what the dealership thinks is the #: 28491AG03b
The dealership looked up both, and they are described in the exact same way for the same vehicle. The difference so far is about $100 a piece..CHEAPER????
The cheaper one being the dealership looked up part number.
Can anyone clarify? I would like to think we could use the Second one. A call is going out tomorrow to Subaru to see what is up.
GraphicWRX is offline   Reply With Quote
Old 06-02-2010, 02:38 AM   #2
kpluiten
Member Sales Rating: (34)
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
opposedforces.com
Old 06-02-2010, 07:55 AM   #3
garface
Member Sales Rating: (55)
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
How much are they?
garface is offline   Reply With Quote
Old 06-02-2010, 08:20 AM   #4
yaya20
Member Sales Rating: (123)
Member#: 130354
Have you checked the length on the Spec B axles? I remember a thread on here about how they were too long to work on an Impreza...
yaya20 is offline   Reply With Quote
Old 06-02-2010, 11:16 AM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
You must pull the outer CV joint off of the spec B axles and swap them with the outer CV joint from some WRX axles and you'll be in business. It was done recently with awesome results.
Old 06-02-2010, 11:57 AM   #6
GraphicWRX
Member#: 57743
2015 Golf TDI
Mod. Thanks for moving this????
I am searching for info. Why move this?
Old 06-02-2010, 02:38 PM   #7
PuenteHillsSubaru
Vendor Sales Rating: (23)
Member#: 175745
According to our computer, the 28491AG03B is just the shaft and boot repair kit
The axle shaft assembly is the 28421AG03B
PuenteHillsSubaru is offline   Reply With Quote
Old 06-02-2010, 09:03 PM   #8
Fierysun
Member Sales Rating: (104)
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Why was this moved to WTB as well as a bunch of other threads with part # requests?
Fierysun is offline   Reply With Quote
Old 06-02-2010, 11:27 PM   #9
GraphicWRX
Member#: 57743
2015 Golf TDI
I found out the same thing via the local dealership. SOA said it was bad cataloging description. Thanks for the info as well.
Scott
05 STI Front Axle PART NUMBER cdawgger Transmission (AT/MT) & Driveline 0 12-16-2008 02:22 PM
I need a part number for JDM sti axle boots Capt Crunch Transmission (AT/MT) & Driveline 4 07-25-2007 07:48 PM
Part numbers for 6MT Axle stubs, circlips, and axle seals Tullin Transmission (AT/MT) & Driveline 4 09-12-2006 07:15 PM
Axle Back Exhaust Bolts:: Part number? dowroa Normally Aspirated Powertrain 6 02-15-2006 09:40 PM
04 STi left rear axle part number? NORCAL STI Transmission (AT/MT) & Driveline 1 05-04-2005 02:28 PM
