Welcome to the North American Subaru Impreza Owners Club Tuesday March 31, 2015
Old 06-01-2010, 11:59 PM   #1
RdRx02
Member#: 248294
02 WRX 4DR
Sedona Red
Default How to Clean MAF 02 WRX
How do you clean the MAF without causing any harm to sensor? I have never cleaned mine and am getting both P0172 and P1131 popping up (after installing a catless TBE). Only other mod is a short ram intake. Hoping that this cleaning will get rid of this code. Still gotta do a few other checks for leaks. Never had these codes before the exhuast was swapped out.
RdRx02 is offline   Reply With Quote
Old 06-02-2010, 12:01 AM   #2
ShaneInHisRoom
Member#: 148737
brake cleaner is what i've always used.
ShaneInHisRoom is offline   Reply With Quote
Old 06-02-2010, 12:07 AM   #3
turboscooby13
Member#: 56280
2003 M3
This stuff FTW... spray the sensor on both sides as well as slightly down in the tube, let air dry. done.
turboscooby13 is offline   Reply With Quote
Old 06-02-2010, 01:14 AM   #4
prometheum
Member#: 92003
04 bicycle!
http://www.obd-codes.com/p0172
P0172 System too Rich (Bank 1)
http://www.obd-codes.com/trouble_cod...obd2-codes.php
P1131 Front oxygen sensor circuit malfunction (short circuit)
i'd say its an o2 sensor or wiring
prometheum is offline   Reply With Quote
Old 06-02-2010, 01:55 AM   #5
flukewrx
Member#: 75081
2003 WRX
Use the CRC MAF Sensor Cleaner. However it sounds like you might be looking to get some type of CEL Fix (either Mechanical or Electrical) as that might solve the problems that you are now seeing after recently swapping in a new exhaust setup.
flukewrx is offline   Reply With Quote
Old 06-02-2010, 06:42 AM   #6
prometheum
Member#: 92003
04 bicycle!
no this is the front O2 sensor...you do not want to put a mechanical cel fix on the front O2 sensor
Old 06-02-2010, 06:53 AM   #7
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
The Maintenance FAQ in the maintenance forum has the correct answer.
Old 06-02-2010, 08:22 PM   #8
RdRx02
Member#: 248294
02 WRX 4DR
Sedona Red
Thanks for the help! Only my P1131 has come back on abruptly the other code has disappeared. One of my buddies said that doing a tune should rid that code from my car.
Have yet to do that but my ECU was replaced last year with a newer version by dealer under warranty. My buddy and I tried to do a ECU Flash with his Tactrix setup but it kept timing out (when trying to write / communicate to ECU in my car). He programmed his WRX and another guys WRX ok but with mine (the newer ECU) it wouldn't do anything. He had heard in the past that some ign. switches are more finicky than others and that could be part of the issue. Is there something that the dealers can do to lock out a ecu flash?? Has anyone ever heard of this happening before?
Old 06-02-2010, 08:30 PM   #9
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
A dealer cannot lock it out as that's against federal law.
Old 06-02-2010, 08:46 PM   #10
Cornercarver82
Member#: 247545
2005 2.5 RS
Platinum Silver
Also when you clean your MAF with the CRC(I use it too) it's a good measure to put a little dab of dialectric grease on the plug contacts. It keeps moisture out and promotes elecritcal continuity.
Cornercarver82 is offline   Reply With Quote
Old 06-02-2010, 10:05 PM   #11
prometheum
Member#: 92003
04 bicycle!
dielectric grease doesn't not promote continuity.
anyway its a bad o2 sensor no amount of tuning its going to magically fix it . you've got a short circuit somewhere disconnect it and shoot the 2 pins to ground from the probe side to find out where your short is from; make sure its not the car.
how to clean MAF? hulkSTi Service & Maintenance 33 08-05-2009 05:02 AM
How to clean a maf sensor simpsons7s Newbies & FAQs 10 08-05-2007 12:08 AM
how to tow an 02 wrx DLBWRXR Newbies & FAQs 8 03-10-2006 07:39 PM
How to Clean the MAF Sensor starBug Electrical & Lighting 2 07-24-2004 09:10 AM
How to clean MAF HOK Normally Aspirated Powertrain 0 03-11-2001 03:33 PM
