Old 06-02-2010, 08:03 AM   #1
tumtum411
Member#: 177530
2002 Subaru wrx wag
flat black
Default RomRaider Works Romraider ecu logger doesnt
I connected my tactrix cable to 2 subie ecuflash connects no problem,romraider reads the rom no problem but i can not log the car with romraider logger,also how may i add launch control to the map
tumtum411 is offline   Reply With Quote
Old 06-02-2010, 11:26 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Make sure the port is set correctly and you have the logger definitions set up.
Old 06-03-2010, 10:56 AM   #3
redline41190
Member#: 241743
2011 Impreza WRX
World Rally Blue
^^ you need to have the correct definitions installed
The launch control can be added from TinyWrexs patches for the 16bit ECU
redline41190 is offline   Reply With Quote
Romraider cant read ecu.... : | PLZ help! lavid2002 Open Source Reflashes 39 01-02-2010 11:28 AM
Romraider cant read ECU streetzdiciple Open Source Reflashes 9 10-24-2008 06:31 AM
swap works great cobb ap doesnt any help Rdwrc Subaru Conversions 8 10-18-2006 10:07 AM
J&S works after ecu reset munkis Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-21-2004 12:00 AM
ECU reset, doesnt start on the first try? moogooob Normally Aspirated Powertrain 4 08-21-2002 01:45 AM
