Old 06-02-2010, 01:33 PM   #1
m_pun
Member#: 246373
Question on an '08 sti, what is the best FIT rim i can get on 265/ 35ZR/18 tires ?
on an '08 sti,
what width & offset on rims can i get on a set of 265/ 35ZR/18 tires ?
the reason i ask is because these are a wide set of tires and i need to know what width and offset would clear the brakes w/o a problem.
m_pun is offline   Reply With Quote
Old 06-02-2010, 02:01 PM   #2
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
for that specific tire i would want a 18x9.5 with a +48 or +45 offset.
jdmboy is offline   Reply With Quote
Old 06-02-2010, 10:09 PM   #3
austinpike
Member#: 11279
2o11 wrx dgm
2oo8 tribeca swp
Are you asking what could fit or what would be the best fit? Are you on stock suspension?
You can put 265/35s on the stock rims, they fit fine, though a bit wider rim would be better.
A particular offset isn't going to guarantee brake clearance, it also depends on the spoke design of the specific wheel.
austinpike is offline   Reply With Quote
Old 06-02-2010, 10:13 PM   #4
mosc
Member#: 177401
2015 STi White
18x9" to 18x10.5". If you want to fit that tire without any fender modification though, you will need to be conservative with offset. Somewhere in the +55 to +48 range probably. Not all wheels that fit that criteria will clear your brakes or even come in your bolt pattern but some do. You can get OZ Ultraleggera in 18x9" +55 that clear your brakes and will fit that tire with no issue.They also weight <20lbs btw...
mosc is offline   Reply With Quote
Old 06-02-2010, 10:16 PM   #5
m_pun
Member#: 246373
yes i am on stock suspension.
those are the tires i have on now. i am looking to replace the rims, but was just hearing that others w/ '08 sti's have to get specific rim widths because they don't clear the big brakes.
i was looking to see what the best fit on those tires would be..
Old 06-02-2010, 10:19 PM   #6
m_pun
Member#: 246373
Originally Posted by mosc View Post
18x9" to 18x10.5". If you want to fit that tire without any fender modification though, you will need to be conservative with offset. Somewhere in the +55 to +48 range probably. Not all wheels that fit that criteria will clear your brakes or even come in your bolt pattern but some do. You can get OZ Ultraleggera in 18x9" +55 that clear your brakes and will fit that tire with no issue.They also way <20lbs btw...
i was actually looking into the OZ Ultraleggera. Thanks for the size recommendation. I am also looking at the Advan RZ as a possibility.
Old 06-02-2010, 10:30 PM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
i would personally buy something along the lines of 18x9.5 with an offset somewhere between +40 and +45.
a lot of people are proponents of maintaining the stock offset, but i'd rather have a wider track.
Old 06-03-2010, 01:06 AM   #8
mosc
Member#: 177401
2015 STi White
18x9.5" Rota DPT are available in +44 but your fenders are going to need help dealing with a 265 on that. They're also considerably over 20lbs. If you go with those, you should probably just do what you need to do on the fenders and get some 275/35R18. Better gearing, wider.
What is the best way to change someone's views on a particular topic? dmross Political Playground 19 03-27-2010 03:38 AM
what is the best car for a project car on a budget? SonicScooby27 Off-Topic 45 07-17-2008 02:42 PM
What is the best size rim that can make your rim flush with the fender? Stanley Park Rex Vancouver Impreza Club Forum -- VIC 12 04-06-2007 02:58 PM
What is the best way to go about getting sponsorship? disque71 Motorsports 5 03-19-2004 10:42 AM
what is the best stuff to use to get stains out of seats? waitandbleed92 Off-Topic 15 01-04-2004 09:00 PM
