Old 06-02-2010, 01:56 PM   #1
wilz02wrx
Member#: 234318
Default timing belt change in a 1.8 from 86
i just picked up a beater for winter rig. 86 subaru gl wagon. it was having timing issues the guy said. it looks like the timing belt is way off. i cant turn the distributer enough to get it to hit at the right time with the firing. he swears that he out the belt on right. im doubting him though so i oulled it apart ready to do it. 1st time to do this on a dual timing belt so just wondering if anyone knows of a tutorial on here. ive seached but everything i find has nothing to do with my situation. any help wopuld be great
wilz02wrx is offline   Reply With Quote
Old 06-02-2010, 11:38 PM   #2
Burnout
Member#: 4721
2002 2.5 RS
1997 Brighton
First Doing the drivers side belt: Line the cam gear mark at 12, then look through the access hole on top on the bell housing and you will see an arrow notched into it. Turn the engine over until you see three lines in a row all within an inch of each other (DO NOT use the timing marks on the flex plate/flywheel or any marks on the crank gear/pully!) use the three little lines. Line the arrow up with the middle line. Put the first belt on and tension it.
Second Doing the passenger side belt: Rotate the crank 360 degrees and line the arrow up with the middle line again. Then line the passenger side cam gear at 12 and put the belt on and tension.
The passenger side gear should be at 12, the flywheel/flex plate should be at the middle line, and the drivers side gear should be at 6.
Burnout is offline   Reply With Quote
Old 06-03-2010, 11:49 AM   #3
Qman
Member#: 964
'95 work in
progress
Full timing belt tutorials can be found at http://www.ultimatesubaru.org/forum/
Qman is offline   Reply With Quote
Old 06-03-2010, 12:48 PM   #4
wilz02wrx
Member#: 234318
so i dont go off top dead center? well i guess the flywheel mark should top dead though i guess
Old 06-03-2010, 12:48 PM   #5
wilz02wrx
Member#: 234318
ok thanks ill take a look
Shop for Timing Belt Change in Houston Drumboy Texas Impreza Club Forum -- TXIC 2 09-07-2008 08:26 AM
where to get timing belt changed in central nj alfmoney Tri-State Area Forum 3 06-05-2008 11:37 PM
Timing belt change in LA area x01011000x Southern California Impreza Club Forum -- SCIC 3 05-18-2007 12:52 AM
Timing belt change tomorrow (friday 7/8/05) weather permitting. lunch provided. RootUsr Mid Atlantic Impreza Club -- MAIC 1 07-10-2005 10:08 AM
Timing belt change tomorrow (friday 7/8/05) weather permitting. lunch provided. RootUsr Mid West Subaru Owners Club Forum -- MWSOC 0 07-07-2005 09:43 PM
