Old 06-02-2010, 03:18 PM   #1
silverf0x
Member#: 147664
2015 WRX Limited
Angry 07 WRX, VF-30, e-Tune, Deceiving Dyno Graph
Facility: Chag Autosport, Montreal, QC, Canada
Type of Dyno: Mustang
Tuner: Tim Bailey (via e-Tune)
Baseline # for a stocker at the dyno: ?
Boost: 22
Fuel: Pump 94, Petro-Canada
Peak HP at RPM: 269.4 @ 5329
Peak Torque at RPM: 312.4 @ 3121
Mods:
VF-30
USDM STi TMIC
BPM 3" DP catless
JDM STi 2.75" Mid-pipe
2.5" STi GeNome Axle-Back
K&N Drop-In
Car a stock internals, stock injectors, stock Fuel Pump
Comparing with other setup here I feel like it's not quite the most beautiful graph I could get, am I correct?
Sorry for the bad dyno sheet quality
silverf0x is offline   Reply With Quote
Old 06-02-2010, 03:42 PM   #2
DamnThatRevLimiter
Member#: 174294
02 WRX , 2013 FXT
VF30 Stage 8 billion
i have a vf30 with pinks and the AP vf30 OTS map and i put down 263 hp with 253 trq to the wheels on a 2.0L . I still need to get mie custom tuned .
So in answer to your question no it is not at the full potential.
DamnThatRevLimiter is offline   Reply With Quote
Old 06-02-2010, 03:59 PM   #3
silverf0x
Member#: 147664
2015 WRX Limited
Thank you for this input, how much boost does the OTS map uses ?
Old 06-02-2010, 04:30 PM   #4
smokey07
Member#: 151683
i'd be scared for my motor's life with that map... WTF is happening at 5500?? thats the worst looking graph up top ive ever seen.
smokey07 is offline   Reply With Quote
Old 06-02-2010, 04:39 PM   #5
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
not the best exhaust setup for power, 91 octane I assume too?
send to your tuner I'm sure he can make you a great revision Tim Bailey is one of the best.
bren wrx is offline   Reply With Quote
Old 06-02-2010, 04:43 PM   #6
silverf0x
Member#: 147664
2015 WRX Limited
I have no idea Maybe someone has a clue ?
As for the "Butt-feeling" at this RPM I don't feel anything unusual..
Old 06-02-2010, 04:44 PM   #7
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
could also be a lack of fan or airflow at that rpm, most dynos dont do this properly for a subaru.
Old 06-02-2010, 04:47 PM   #8
silverf0x
Member#: 147664
2015 WRX Limited
I am well aware that this exhaust setup is probably too resrtictive to get the max power possible. I had to compromise between sound (police) and power. Unfortunately, I my part of the country, I had to choose Sound I assumed that the restriction wouldn't be THAT bad tough
The Octane is 94.
About Tim, I did try to contact him via email a few times (and Surgeline Sales) in the last months but NEVER got an answer. I guess phone would be quicker but my English sucks so much that I prefer waiting for emails..
Old 06-02-2010, 04:49 PM   #9
silverf0x
Member#: 147664
2015 WRX Limited
Well this was a Dyno Day with a bunch of other Subarus from the Montreal chapter. If the airflow was bad, would I see the same behavior on the other Dyno Sheets ??
Old 06-02-2010, 04:53 PM   #10
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
Depends how it was tuned. a super conservative car may not care for additional airflow, a moderately tuned car will, depends on how many pulls and how hot the car was when it went in. Did the car have 40+ mph fans on it or the intercooler? If not, does that really simulate street airflow at the top of 3rd (100mph?) probably not
May I repeat that Tim bailey is one of the best in the world, it is possibly not his map. I have seen fault in dyno operators causing incorrect readings (lifting up top or too early).
Old 06-02-2010, 05:05 PM   #11
silverf0x
Member#: 147664
2015 WRX Limited
There was no fan installed on the TMIC
There was some big ass fans in front of the car, I could not tell about the specification of those.
I will add that the pull was done in 4th gear if that changes anything..
Old 06-02-2010, 05:20 PM   #12
SpicyPeaNut
Member#: 43310
1978 Brat
tuned by Tim Bailey...
SpicyPeaNut is offline   Reply With Quote
Old 06-02-2010, 05:29 PM   #13
cireturbo
Member#: 119777
2013 BRZ
There's your problem.
cireturbo is offline   Reply With Quote
Old 06-02-2010, 05:38 PM   #14
Donzo
Member#: 95337
2012 Jeep Overland
Stock injectors on an '07 are fine for his setup. He desperately needs a Walbro fuel pump though. I put down 240/320 with an AP, k&n drop in filter, STi tmic, Walbro fp, full 3" turboback exhaust (bellmouth downpipe and Perrin single tip catback) and Cobb AP.
I then put down 260/320 with same mods and a tune a month later. My dyno sheets are somewhere in this section.
Donzo is offline   Reply With Quote
Old 06-02-2010, 05:38 PM   #15
silverf0x
Member#: 147664
2015 WRX Limited
I cannot say for the Fuel Pump, but monitoring my injector duty cycle on my AP shows a MAXIMUM of 85% so I guess there's still space left for that..
I was planning to install a Walbro 255 but this as yet to come.. Could this make SUCH a diffrence? Isn't the stock fuel pump 175-ish ?
Old 06-02-2010, 05:39 PM   #16
silverf0x
Member#: 147664
2015 WRX Limited
Is it possible to monitor the flow of the fuel pump via the AP to see if this could be the problem ?
Old 06-02-2010, 05:41 PM   #17
silverf0x
Member#: 147664
2015 WRX Limited
Also, I think I know the answer to that one but would a change of fuel pump require another tunning ?
Old 06-02-2010, 05:42 PM   #18
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
4th gear on an 07? that goes to like 135mph? no enough airflow and too much load those cars need to be in 3rd on that dyno.
Old 06-02-2010, 05:45 PM   #19
silverf0x
Member#: 147664
2015 WRX Limited
Aargh another reason to get another Dyno session elsewhere .... I'm already planning a 3-dyno pull session at Lachute Performance. They have a MAHA dyno. Will try to go next week.
Old 06-02-2010, 05:47 PM   #20
Badler
Member#: 133597
It's just a sheet of paper. Who gives a ****.
Badler is offline   Reply With Quote
Old 06-02-2010, 05:54 PM   #21
silverf0x
Member#: 147664
2015 WRX Limited
Well since this sheet of paper directly reflects the status/health of my motor, I care a lot !
Old 06-02-2010, 06:09 PM   #22
Badler
Member#: 133597
It has nothing to do with the status/health of your motor. You had no idea what it put down before. What happened is you got tuned and were happy with your car. You then went to a dyno to get random numbers(my guess is to brag) and now think something is wrong with your car because it didn't put down OMGWTFBBQwhp. Road tunes/e-tunes and dyno tunes are not the same. Back to the original. It's just a piece of paper. Who gives a ****.
Old 06-02-2010, 06:14 PM   #23
All4bSpinnin
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
Agree in the fact that that is a very concerning dip in horsepower. I would at the very minimum get a 255 fuel pump and a custom tune to make sure it doesnt knock ...it definitely doesnt look good around 5500
The only way i would use an etune is if i upgraded injectors and needed to drive to the dyno to get custom tuned
All4bSpinnin is offline   Reply With Quote
Old 06-02-2010, 06:28 PM   #24
Infamous1
Member#: 133692
2003 Chevy Z06
Black/Black
A properly performed E-tune could yeild identical results to a dyno tune. It all depends on who is tuning and how may revisions have been conducted.
Infamous1 is offline   Reply With Quote
Old 06-02-2010, 08:26 PM   #25
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Silverfox - Did you perform a compression and leakdown test on your engine before loading the map? What about a boost-leak test?
Don't get so hung up on the numbers that the dyno is putting out. It is a Mustang Dyno, and they tend to read much lower than most. I would imagine that your numbers would be much closer to around 300whp.
The other thing you have to consider is that you have an e-tune. The tune is not optimized for your car and its peculiarities. See if you can get a protune done on your car to really maximize the gains from your modifications.
jigga is offline   Reply With Quote
04 STI open source tune with dyno graph Blee Proven Power Bragging 34 09-18-2009 04:13 PM
04 WRX - VF 48 P&P tuned/ P&L Motorsports Rudywrx04 Proven Power Bragging 26 08-05-2009 05:05 PM
WRX 07 & VF-30 => Works with AP VF39 map ? silverf0x Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 04-08-2009 04:57 PM
FS : MPB 02 wrx vf-30 FL $18k invested. sk82712 Private Vehicle 'For Sale' Classifieds 8 06-17-2007 12:34 AM
vf-30 stage 4 Turboxs dyno newand improved mikaust Proven Power Bragging 13 05-23-2003 11:30 PM
