#1 |
Member#: 64147
Vehicle:1993 STi RA V LTD Green |
Okay so I stopped getting spark in my #2 cyl out of nowhere. After checking all fuses, replacing the coil pack, plug, etc, I ended up trying to find a break in the wiring, since it was getting 12v power, and had a good ground, it just wasn't getting signal from the ecu to spark. When I traced the signal wire from #2 cyl it appeared to run into a green/blue wire. I followed that wire all the way to the firewall where it was getting continuity, then i lost it behind the dash, re-appearing down by the ecu, where it no longer got continuity, so I cut the wire at the ecu, and where it entered the firewall, and ran a new wire joining those two, which fixed the spark problem. But then the tach stopped working. When I disconnected the new wire, and put it back to the way it was originally, the tach started working, but the spark in #2 stopped. So it almost like the coil is somehow ran into the same wiring as the tach, or i some how got it working with the coil getting signal from the wire thats supposed to go to the tach? Because theres also the same color blue/green wire that plugs into the cluster.
#2 |
Member#: 4800
TXIC
Vehicle:1990 Legacy & 97 OBS AWD 5MT EJ22T AWIC Swap |
More than likely the tach is tied into that wire to the coil.
If you tie the wire going to the tach to the new wire you put in, everything will probably be back to normal. |
#3 |
Member#: 64147
If I do that, I have neither tach nor coil
#4 |
Member#: 4800
TXIC
Ok....that's weird.....hmmm
Any chance you have a wiring diagram? |
#5 |
Member#: 159682
NESIC
Vehicle:1995 WRX |
Stock tach in the dash or aftermarket? The stock tach has a seperate wire off the ecu.
#6 |
Member#: 64147
Legacy, I have a wiring diagram I got from SubarDave but I can't seem to figure it out.
69Subaru, Stock tach |
#7 |
Member#: 65916
Vehicle:1996 Impreza WRX |
The following information is based on you having an EJ20G, I also assume you have converted to 02+ Coil packs because you make no mention of the ignitor. If that is true the first place I'd look is where the ignitor removal wiring was done.
Are you sure it's #2? The blue/green wire in the engine bay should be to #4 and that wire should cease to exist at the ignitor or splice into the black/red if its removed. The blue/green at the computer is only to the tach. The correct wire for #4 at the ECU is black/red, pin 7. The correct wire for #2 at the ECU is red, pin 8. The ignition outputs are all in the 26pin connector. |
#8 | |
Member#: 64147
#9 |
Member#: 64147
upon further diagnostic, i think i may have something reversed. when i was tracing wires, i ended finding out that the solid red wire at the ecu was cyl #4, so maybe i have a plug reversed somewhere in the engine bay, and #4 is actually #2, but the plugs are reversed at the engine?
#10 |
Member#: 65916
ECU Pinouts
That's the link you need to figure out the wires at the ECU. I would really look at the splices where the ignitor was removed, should be near the intake box/strut tower. I could easily believe the plugs being reversed, but your car would've run funny unless they were wired reverse as well. |
#11 |
Member#: 64147
Well sir, you just fixed my car
![]() Thank you very much for the assistance. I reversed the plugs in the engine bay so that white is in the front, and black is in the rear, but blk/red goes to 4 and red goes to 2. Now my tach, and all 4 plugs work!! Now I just have to replace my dead injector, and figure out why my cluster fuse keeps popping! Thank you again!!!! |
| Thread Tools | |
| Display Modes | |
| How to determine if plug or coil pack is bad. | rallynutdon | Factory 2.0L Turbo Powertrain | 8 | 10-29-2009 11:04 AM |
| To people who have had coil pack failures | attitude | Service & Maintenance | 3 | 06-11-2005 08:06 PM |
| Is it just me, or does the guy have to do everything? | IgotWRXed | Off-Topic | 30 | 11-28-2003 10:52 PM |
| uppipe or downpipe if I had to choose only one | rallysquirrel | Factory 2.0L Turbo Powertrain | 12 | 08-14-2003 02:29 PM |
