Old 06-02-2010, 09:34 PM   #1
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Default Dyno Tune: 2.5L Shortblock + VF39 = 270hp/310tq w/ 91 oct (05 WRX)
Event: dyno pull
Ambient Temp: ~75? June in socal
Elevation: 33ft
Weather: Clear
Tires: Hankook RS-2 265/35/18
Car: 2005 WRX
Tuner: jon @ hbspeed
Dyno Info: dynomite
Peak HP at RPM: 270HP @ 4900 RPM
Peak Torque at RPM: 311.0 ft-lbs @ 4400 RPM
Baseline : No base Line
Target Boost: 21.5 psi
Target AFR:
Fuel: 91 unleaded pump gas
Engine/Power Modifications:
2.5L Short block with 2.0L Heads
VF39
Greddy FMIC
Apexi Short ram intake
Power Enterprise 800cc top feed injectors
Denso Supra Fuel pump
Espelir prototype Header
Sti catless uppipe
Helix Catless downpipe (bell mouth)
Gramlight 57 Dragon Catback exhaust 3" with 2.5 Taper at mid pipe
Open Source Tuning
Grimmspeed Boost Solenoid
Driveline Modifications: none
Suspension Modifications: Meister R Coilover with 18X9.5 Bee Racing Wheel.
Other Modifications:
Kenji815 is offline   Reply With Quote
Old 06-02-2010, 10:35 PM   #2
STi-MAN
Member#: 70252
05 STI
blue
I likes!
STi-MAN is offline   Reply With Quote
Old 06-03-2010, 10:29 PM   #3
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
I'm having problems with the car thou.. There seems to be something wrong. The car is having problem idling, flashing cel and misfire codes.
I have the feeling there is something wrong with the PE injectors.
Old 06-03-2010, 11:58 PM   #4
jonfrow
Member#: 190239
2002 impreza
psm
I think there's more power to be had there.
jonfrow is offline   Reply With Quote
Old 06-04-2010, 12:25 AM   #5
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
Yeah i would agree ^ Would expect to see a good bit more out of the 39 with all those supporting mods. I built a hybrid bugeye at the beginning of this year with stock td04-13t, stock injectors, stock fuel pump, stock headers, and stock intercooler and made 264 hp and 343 ft lbs tq. not the best looking curve but holy heck it would break loose on the highway.
Here's the info for your reference:
Event: Dyno Tune
Ambient Temp: 40 F
Elevation: 900 ft. ASL
Weather: Cloudy / Rainy
Track and Conditions: N/A Tires: Unknown
Car: 2002 Subaru Impreza WRX
Tuner: Todd @ Motion Lab Tuning
Dyno Info: Mustang 500
Peak HP at RPM: 264whp @ 4650rpm (SAE Corrected)
Peak Torque at RPM: 343ft.lbs @ 3550rpm (SAE Corrected)
Baseline hp/tq for a stock on same dyno: 180whp stock WRX
Target Boost: 21psi tapering to 11 psi
Target AFR: 11.8:1
Fuel: 93 octane unleaded
Engine/Power Modifications: 2.5L block, STi cams in 2.0L heads, '08 STi oil pump, Invidia 3'' TBE, Deleted / Ported TGV's, Stock in-take w/ K&N drop-in filter, Venair intercooler hose kit, Grimmspeed 3 port EBCS
Driveline Modifications: ACT heavy duty street clutch kit & resurfaced flywheel
Suspension Modifications: SPT Springs
Other Modifications: N/A
subydude02 is offline   Reply With Quote
Old 06-04-2010, 10:42 PM   #6
STIll inspired
Member#: 248431
clean
STIll inspired is offline   Reply With Quote
Old 06-05-2010, 03:41 AM   #7
jsmoov44
Member#: 191568
2004 wrx
black
this may just be the beasty_ist suby ive ever seen in my life
jsmoov44 is offline   Reply With Quote
Old 06-07-2010, 10:04 PM   #8
HB Speed
Member#: 160911
2008 GT33R Evo X
560+ whp GG
Originally Posted by Kenji815 View Post
I'm having problems with the car thou.. There seems to be something wrong with the tune and car is having problem idling.
And HBspeed has not got back to me how they will solve it.
Right now i'm not very happy with the results of the tune and hbspeed's service.
actually we have been waiting for you to make an appointment
to come in and have it looked at, i wont get into the issues this car has/ had previous to this tune. But i fixed quite a few things on the dyno.
See you soon eddie we will get that lil ****er fixed up!!
HB Speed is offline   Reply With Quote
Old 06-07-2010, 10:07 PM   #9
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
lol is this ppb or the vendor forums???
nice little mountain of tq your starting to build. are the pe's holding you back?
mongoosaroo is offline   Reply With Quote
Old 06-07-2010, 10:59 PM   #10
Eric.H
Member#: 241884
05 WRX STI Stage 2
I was afraid of this, but i guess im a victim too?
I don't feel the car is making the power it suppose to. the dyno numbers are so weak sauce. what ticks me off is, i see guys with just a tbe and some supporting mods and they're making a little over 300awhp. I am not even making that and running methanol.
maybe is the tuned, who knows.
Eric.H is offline   Reply With Quote
Old 06-07-2010, 11:05 PM   #11
HB Speed
Member#: 160911
2008 GT33R Evo X
560+ whp GG
Noone is a victim of anything
here is the same car pre and post re calibration
as you can see the dyno reads alot lower now
after his retune we got this
nothing is wrong relax
Old 06-07-2010, 11:07 PM   #12
HB Speed
Member#: 160911
2008 GT33R Evo X
560+ whp GG
anything over 300 now used to be 325+
Old 06-07-2010, 11:26 PM   #13
HB Speed
Member#: 160911
2008 GT33R Evo X
560+ whp GG
another PRE POST calibration
HB SPeed Tuned GTR
PRE 585 POST 545
Same car same tune same Everything
Old 06-08-2010, 02:46 AM   #14
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
I'm not trying to slam any vendor for the problems. And this is not a vendor review.
I'm simply trying to get my car fixed.
http://forums.nasioc.com/forums/show....php?t=1999698
If you see my other thread i'm just having a bad week with my car.
I spoke to Jon @ HBSpeed and he was very helpful.
We will be swapping out the injectors to see if the tune will be more reliable and see if we can squeeze alittle more power out of the car..
I'm hoping we can get the car running smoothly soon.
Old 06-08-2010, 09:21 AM   #15
Scooby921
Merci Buckets
Member#: 88606
2016 Cayman GTS
Dark Blue Metallic
Thank you!
The rest of you need to follow suit and quit whining and complaining in here. Some of you have been told this before. This is not the vendor review forum. Its not your thread about your car. Its not your place to bitch, moan, and complain. If you want to discuss the car that is one thing. If you want to start whining about your own car or start slamming vendors you're going to run into problems. Vendor complaints/comments go in the vendor review forum/threads. Issues with your car go in your thread.
Just so everyone knows where their comments went....I deleted them. They don't belong here and only run the thread off-topic.
Scooby921 is offline   Reply With Quote
Old 06-08-2010, 06:08 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
awe....my rub n tug post was gold.
Old 06-08-2010, 06:43 PM   #17
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
In reference to the original post, why is boost hitting so late? Looks like full boost is after 4k RPM which is ridiculously laggy for a VF39 on a 2.5l. Of course the torque peak is up at 4500RPM as well, but that's because boost is hitting so late. I would recommend inspecting for boost leaks.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 06-08-2010, 07:12 PM   #18
jason06scooby
Member#: 248874
WRB - STG 2
Hopefully "Jesus" will solve your problem on your car OR has been already solved.
jason06scooby is offline   Reply With Quote
Old 06-08-2010, 07:19 PM   #19
Phatron
Member#: 36033
CEO PhatBottiTuning
Originally Posted by Equilibrium Tuning View Post
why is boost hitting so late? Looks like full boost is after 4k RPM which is ridiculously laggy for a VF39 on a 2.5l. I would recommend inspecting for boost leaks.
-- Ed
probably a combination of non-avcs heads, different compression ratio, fmic, short ram intake, "prototype" header and 2.5" tapering exhaust
Old 06-08-2010, 07:19 PM   #20
Badler
Member#: 133597
Event: Dyno Tune
Ambient Temp: 40 F
Target AFR: 11.8:1
You have 93oct. Apples to Oranges.
Badler is offline   Reply With Quote
Old 06-08-2010, 08:54 PM   #21
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
-- Ed
I will check on that. The boost does seem to come in alittle late.
Thanks for the suggestion.
Old 06-08-2010, 08:59 PM   #22
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
No kind of hardware, no matter how poorly designed, would cause a VF39 to hit full boost after 4k RPM on a 2.5l. Hell, even 2.0's hit around 3600RPM!
-- Ed
Old 06-08-2010, 08:59 PM   #23
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
It's Hey-seus!
Fierysun is offline   Reply With Quote
Old 06-18-2010, 02:39 PM   #24
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
Got a retune yesterday and the misfire and stall issue seems to have all gone away.
We resolved the issue by switching out PE injectors for set of deatchwerks 750cc top feed.
Big thanks to Jon and Dannyh for squeezing me in last minute to get a retune done.
Even thou he wasn't able to push more number off the dyno. The car feels much more solid on the street and car comes into full boost much faster.
Old 06-18-2010, 02:43 PM   #25
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
damn, I wanna sell my injectors so bad, but Id lose my ass, I just bought some brand new PE 850 cc sidefeeds & would love to replace them with DW's
KB'izzle is offline   Reply With Quote
Dyno Tune: 2.5L '09 WRX Completely stock, makes 263whp. <-- dyno reading incorrectly Breezio Proven Power Bragging 114 10-12-2010 10:00 PM
Road Tune: 2.5L + Dom4-XTR Makes 470whp on 91+meth Phatron Proven Power Bragging 77 02-25-2010 11:13 PM
Maxwell Power Dyno Tune: 2.5L Hybrid + GT35R = 588whp Maxwell Power Proven Power Bragging 47 12-31-2009 07:31 PM
Dyno Tune: 2.5L hybrid + VF39 makes 352whp on 92 octane *03wRx* Proven Power Bragging 8 11-09-2009 12:18 AM
Dyno Tune: 2.5L + ATP35 makes 360whp 2gnt2wrx Proven Power Bragging 12 10-31-2009 09:32 AM
