Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 06-02-2010, 08:36 PM   #1
MNsuby
Member#: 186530
02 Bugeye
MBP
Default 08+ wrx turbo upgrades?
I have not done to much research yet. I hoping some others are in the same boat I am and have found out already. I was wondering what options there is for 08+ wrx owners as far as turbo upgrades go? Is there any previous generation sti turbos that could swapped in?
MNsuby is offline   Reply With Quote
Old 06-02-2010, 09:54 PM   #2
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
You can make alot of turbos fit. You have to cut the flange off your stock turbo and weld it to the new one you want to run....just like Ultimate Racing does.
Or you can swap over to an Sti intake manifold etc etc.
bhhamblin is offline   Reply With Quote
Old 06-03-2010, 04:13 AM   #3
Rfed
Member#: 177519
08 WRX
AVO. Bolt right up, expensive but worth it.
Rfed is offline   Reply With Quote
Old 06-03-2010, 11:11 AM   #4
forrealsss
Member#: 182954
2008 WRX hatch
SSM
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1_3 like Mac OS X; en-us) AppleWebKit/528.18 (KHTML, like Gecko) Version/4.0 Mobile/7E18 Safari/528.16)
anything that fits 2005+ Legacy GT
forrealsss is offline   Reply With Quote
Old 06-05-2010, 05:16 PM   #5
GravyRobber
Member#: 205568
2002 S2000
Suzuka Blue
Convert to FMIC and anything works. The Ultimate racing mod is also an option.
GravyRobber is offline   Reply With Quote
Old 06-05-2010, 05:50 PM   #6
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
if you have an 08 get an 09 turbo. the VF52 is on par with the biggest most flowing best turbos subi ever uses. if you have an 09 turbo trying to put anything else from subi on will be a waste of time and money! if you go aftermarket a few will fit the stock top mount like said, but the turbos from Bloush like the 2.5 xtr and 3.0 xtr with FMIC are your best upgrades IMO!
synolimit is offline   Reply With Quote
Old 06-06-2010, 12:19 AM   #7
Liquidr1
Member#: 205015
2009 Impreza WRX
What are your goals.
if you just looking for 300 whp 300+ WTQ just get a vf52 from an 09. It bolts right up.
Liquidr1 is offline   Reply With Quote
Old 06-06-2010, 04:51 PM   #8
savsuby300
Member#: 189232
1995 Nissan 240SX
Dead in the shed.
^Can't go wrong there if you want budget power. Oh and maybe injectors and fuel pump for E85.
savsuby300 is offline   Reply With Quote
Old 06-06-2010, 05:21 PM   #9
DG39
Member#: 209619
05 EVO VIII
99 impreza L
FMIC and u can fit any turbo, but if you dontwant to gothat route BNR and AVO make turbos that fit our cars
oh yeah and a VF52 with bigger injectors E85 and a tune will put down about 315-340
I made 330whp and347tq on my VF2 pump and injectors
DG39 is offline   Reply With Quote
Old 06-07-2010, 02:56 AM   #10
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Maybe on PRE's dyno.
Byzantium is offline   Reply With Quote
Old 06-07-2010, 03:00 AM   #11
DG39
Member#: 209619
05 EVO VIII
99 impreza L
HAHAHAHAHA or maybe on Surgeline's DYNO thanks for trying to call BS tho
http://forums.nasioc.com/forums/show....php?t=1855430
heres one for the graph
http://surgeline.cobbtuning.com/dyno...rgb1=000000255
Old 06-07-2010, 03:01 AM   #12
Byzantium
Member#: 207826
85k 2002 WRX
E85 is not pump gas.
Old 06-07-2010, 03:04 AM   #13
DG39
Member#: 209619
05 EVO VIII
99 impreza L
sorry, pump as in walbro should have specified
Old 06-07-2010, 04:11 PM   #14
09rexspeed
Member#: 216923
Default walbro
Hey where did u guys get your walbro at. I called them and they said its still in production. Thx pm me w answer
09rexspeed is offline   Reply With Quote
Old 06-07-2010, 04:16 PM   #15
Byzantium
Member#: 207826
85k 2002 WRX
Internet. You're welcome.
And you called them?
07 wrx turbo same as 08 wrx turbo? JustAnotherSubie Newbies & FAQs 3 12-03-2009 01:54 PM
08 WRX Turbo XS UTEC DELTA and 08 WRX stock parts philo Engine/Power/Exhaust 7 04-21-2009 10:40 AM
08 WRX Clutch Upgrade kennyd1gital Transmission (AT/MT) & Driveline 1 03-02-2009 06:35 AM
08 WRX turbo & TMIC Swap for a 08 STIs 08SubieWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 06-30-2008 12:06 PM
FP wrx turbo upgraded stock turbo titanium wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-19-2003 06:29 PM
