Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 06-02-2010, 11:52 PM   #1
karnick
Member#: 103863
Default Recurring CEL, yet "no problem codes found". Datalogs included
I'm really praying someone can explain this issue to me.
I have an 06WRX MT. I have been running Cobb stage 1 for about 55,000 miles (currently at 64,000). Recently, I got my first CEL. It went away for some unknown reason, perhaps after I filled up the tank. Soon enough (<500 miles) it came back.
Here is how I approached this: I recently connected my Cobb OBD-II cable to my car and laptop via serial and tried to pinpoint the trouble codes with the latest version of ecuExplorer. Oddly enough, my car model did not show up in the tree on the left (as it has in the past), it just was blank. I was still able to monitor live data, but there were no trouble codes, neither current or historic. I then connected my AccessPort to see the trouble codes. The AP told me there were No problem codes found. I reset the ECU and the CEL went away for about 5 minutes until it came back. I decided to log some data so I can post it here. I found that I did not exceed 4.9psi, even with a heavy foot.
I then decided to reflash my base map to the stock (married) map. The CEL once again went away and I started to achieve around 12psi or so. However, the CEL came back eventually, but I was still hitting 12psi. The AP still tells me that no trouble codes were found. Every time I clear it, it comes back.
I logged some data prior to flashing back to stock, in the hopes that someone who knows enough about the data can easily spot something. I logged as many parameters as I could before the ecuExplorer software simply stopped polling.
If anyone can look at the data I'd really appreciate it. I can also log some more data with parameters you think would give more information.
The csv files can be accessed here:
http://elvis.rowan.edu/~karnic08/run1.csv
http://elvis.rowan.edu/~karnic08/run2.csv
run1 is driving around town, run2 is driving on a major highway with no traffic lights.
I zipped them both up here if your browser displays them poorly.
http://elvis.rowan.edu/~karnic08/run1and2.zip
Thank you in advance.
karnick is offline   Reply With Quote
Old 06-03-2010, 04:05 PM   #2
karnick
Member#: 103863
Nothing?
Old 06-03-2010, 08:13 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
learned view has code reader built in.
Old 06-03-2010, 09:07 PM   #4
karnick
Member#: 103863
learned view?
Old 06-03-2010, 09:40 PM   #5
karnick
Member#: 103863
Downloaded Learning View... P1410 - "Secondary air pump valve stuck open"
Great.
So i clear my headlights... now strange problem! Help please! pics included! litowrx Electrical & Lighting 22 05-25-2009 07:10 PM
NewTurbo Back, No CEL....Yet... EagleRockWrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-29-2005 04:41 PM
No CEL yet! bigdweeb Normally Aspirated Powertrain 14 09-24-2004 06:20 PM
Any CELs yet with new exhaust? redrexx STi Forum Archive 12 07-30-2003 01:15 AM
recurring CEL - Exhaust Gas Temperature too high Subie Gal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 04-02-2003 07:24 PM
