Old 06-03-2010, 10:15 AM   #1
PoZeR
Member#: 114202
2006 FXT E85
LEZWAGN
Default Head info needed,2.5 2003-2004 JDM DOHC w/AVCS
Hello all as you can see I’m a noob with a question.
I’m wondering if anyone happens to have a flow chart or knows the CFM of theses heads.
I have very little info on the head other than they are from 2001–2004 JDM Legacy RS25 with 2.5L NA and AVCS. The ports look huge compared to my 06 FXT head.
PoZeR is offline   Reply With Quote
Old 06-03-2010, 12:09 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It's hard to find flow information for heads common here in the US, let alone ones that aren't available here.
Some of the guys in the Built Motors Discussion forum might be able to give you some ideas.
Pat Olsen
Setting Timing - Replacing Head Gasket on 2.5 DOHC Tessai Normally Aspirated Powertrain 8 05-20-2011 09:16 AM
Need expertice on canadian 2.5 replacing with JDM 2.5 caminoguy Subaru Conversions 4 10-04-2009 10:25 AM
JDM STi v7/v8 cyl head info needed CKxx Subaru Conversions 11 05-11-2009 11:52 PM
2.5 litre sti heads (fully built) 2.5 crank, AVCS cam gears 700hp Engine/Power/Exhaust 7 11-24-2007 02:37 PM
In 2002, 2003,2004 jdm wrx, avcs an option? Turbo Tin Can Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-11-2003 09:19 PM
