Old 06-03-2010, 10:52 AM   #1
AndrewFD3
Member#: 210458
2003 wrx built ej207
Rally blue
Default Ej207 V6
Any other differences between the v6 and v7 other than AVCS? Anyone have V6? If so how do you like it?
AndrewFD3 is offline   Reply With Quote
Old 06-03-2010, 11:13 AM   #2
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
The engine harness wiring is different...so depending on what car you want to put this in, it could be a lot harder of a swap. Also depending on what v7 engine you get could get way better cams and I believe the v7 is actually a stronger engine overall. You should go look through the EJ207 owners thread.
kayen is offline   Reply With Quote
Old 06-03-2010, 12:17 PM   #3
AndrewFD3
Member#: 210458
Rally blue
I would be swapping into my wrx and sticking with the stock ecu.. I know this has probably been talked about many times sorry for flooding
Old 06-03-2010, 01:09 PM   #4
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
you may want to fill out your profile and let us know what year of WRX you have...
Old 06-03-2010, 02:01 PM   #5
AndrewFD3
Member#: 210458
Rally blue
Anyone have the v6 installed?
Old 06-03-2010, 02:22 PM   #6
Aphex28
Member#: 11506
2000 Silver RS swap
thingy. USDM STI goodness
A lot of differences.
OBD 1, turbo, Open deck block, Coil pack and not coil on plug, and different head and intake manifold design just for starters. It won't be worth the money you'd be saving to get a v6. It isn't much different than the EJ20k in terms of reliability as well, as in, they are prone to spin bearings.
I'm also highly doubtful that you would be able to use your stock ecu and wiring. You will most likely have to get the harness merged as well as get rid of OBD-2 compliance.
Check out the Pre-2002 Factory Turbo Powertrain forum for more info.
http://forums.nasioc.com/forums/forumdisplay.php?f=92
Aphex28 is offline   Reply With Quote
Old 06-03-2010, 02:45 PM   #7
AndrewFD3
Member#: 210458
Rally blue
[quote=Aphex28;30919705]A lot of differences.
http://forums.nasioc.com/forums/forumdisplay.php?f=92[/quot
Thanks for the info! im probably going to buy a v7, anyone know of any good places to source them from? gruppe s has none and ebay only has a few
Old 06-03-2010, 03:47 PM   #8
Aphex28
Member#: 11506
2000 Silver RS swap
send a pm over to millennium auto
or their website is www.y2kimports.com
other places:
www.wrx-tx.com
http://www.silverlineautomotive.com/
Old 06-03-2010, 04:21 PM   #9
AndrewFD3
Member#: 210458
Rally blue
other places:
www.wrx-tx.com
Thanks for the support mang!
Old 06-03-2010, 04:22 PM   #10
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
I would also look into:
Lachute Performance and JDMSpecC (here on nasioc)
both of those places are highly reputable and will take care of you.
Old 06-03-2010, 04:53 PM   #11
AndrewFD3
Member#: 210458
Rally blue
Thx just contacted them!
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
ej207 will fire up and die. v6 swap is grumpster supermoose Subaru Conversions 30 01-22-2009 02:10 AM
EJ207 V6 / EJ205 shortblocks... is there a difference? blacktalon606 Factory 2.0L Turbo Powertrain 25 11-17-2006 12:48 PM
2000 WRX STi Version 6 MAF Mass Air Flow Sensor NEW V6 JDM EJ207 accord94dx Private 'For Sale' Classifieds 0 05-18-2006 04:59 PM
anyone have a jdm v6 ej207 maf housing or need a maf sensor? swapstar Subaru Conversions 2 02-04-2006 09:11 PM
Message Board Statistics All times are GMT -4. The time now is 07:35 AM.
