Old 06-03-2010, 11:12 AM   #1
xbongox
Member#: 246426
2005 Impreza WRX STi
Platinum Silver
Default Brake Noise
It seems as though every time my brakes start warming up from driving/stopping, my brakes squeek and when i push down the brake pedal when im stopped, they make a clicking/creeking type sound? I bought my 05 sti about a week and a half ago, and im trying to debug all the noises that shouldnt be. The brake pads are brand new (not oem tho) and the brakes work amazingly, but i just dont know what that damn sound is. Anyone have this problem before or know of a solution?
xbongox is offline   Reply With Quote
Old 06-03-2010, 11:15 AM   #2
chapstien
Member#: 68284
2009 FXT Limited
obsidian black
Some pads make noise.
chapstien is offline   Reply With Quote
Old 06-03-2010, 11:59 AM   #3
nairbmik
Member#: 220259
09 2.5i
SSM
Yeah, what pads are they?
nairbmik is offline   Reply With Quote
Old 06-03-2010, 12:49 PM   #4
xbongox
Member#: 246426
Platinum Silver
I cant tell just by looking at them, I just know that they arent the OEM pads. I could understand if they just squeak as your stopping, but it's just the noise that it makes when your at a full stop and press/release the break.
Old 06-03-2010, 01:02 PM   #5
Landman
Member#: 169650
04 WRX/2.5/18G/6MT
Well allot of higher quality pad do have a tendency to do a bit of squeaking.
If some one replaced the pads with out the spaces on the back side of the pad could that create some "paly" in the pads and pistons for weird nosies to take place during use? Just a though and could be an easy mistake to make. ALSO if the pads were not greased on the back of them between and the pistons could that cause problems/sounds?
Landman is offline   Reply With Quote
Old 06-03-2010, 01:14 PM   #6
Java Black Pearl
Member#: 188593
2004 Impreza WRX
18L
Obviously with out seeing or hearing in person I can't tell what your issue is, but the 'symptom' you described sounds similar to what my Hawk HPS pads do, especially when I am on a hill and release the brakes when it is cold out.
Java Black Pearl is offline   Reply With Quote
Old 06-03-2010, 01:33 PM   #7
Landman
Member#: 169650
04 WRX/2.5/18G/6MT
I use Hawk HPS pads and have none of those issues. Could incorrectly bedding in brakes cause things like this?
Old 06-03-2010, 01:41 PM   #8
al82
Member#: 177913
2011 WRX STi PBP
If the brake pads are ment for racing and autox then its going to make noise, its just how some pads are. Since you just bought the car i would recommend you change the engine oil, tranny fluid, brake fluid and maybe the pads if you want.
al82 is offline   Reply With Quote
Old 06-03-2010, 01:50 PM   #9
xbongox
Member#: 246426
Platinum Silver
Yea, when i first heard it, I pulled out the pads and found out that the person who owned the car put 3 shims on each pad for the front. I removed the extras and gresed it up like normal and put em back in. It didnt help the noise, but it definitely was something that didnt need to be there. I'll try changin the fluids this weekend and see if that makes any difference. Ill also see if i can take a video of some sort sometime today and post it up on youtube so i can link it here, this way i can get everyone to hear exactly what the noise is.
Old 06-03-2010, 04:05 PM   #10
Java Black Pearl
Member#: 188593
2004 Impreza WRX
18L
I installed the fronts - bedded them in. Installed the backs six months later - bedded them in. I even re-greased all the hardware. All to no avail, I have just accepted the faint squeel when I am on a decline and have to release the brakes slowly to allow the car to inch forward as a characteristic of the pad.
Old 06-03-2010, 05:06 PM   #11
arrrwhyy
Member#: 239605
09 STI
Sorry nooby question.. if the higher performance pads tend to squeal a lot, when would you know to change them out? I thought it was time to change pads when they squeal?
arrrwhyy is offline   Reply With Quote
Old 06-04-2010, 03:14 PM   #12
Java Black Pearl
Member#: 188593
2004 Impreza WRX
18L
My squeal is faint and only my I am on a steep decline and have to release the brake slowly.
When you have worn your brakes down to the squeal tab - the squeal for the most part will be constant when ever you brake.
On my '04 WRX even with the wheel still on you can pretty much get a clear look to see how much pad is left and how close to the squeal tab you are.
Old 06-04-2010, 03:58 PM   #13
mtbiker278
Member#: 242578
2010 WRX
Spark Silver
If it's an older car you might look into replacing the pad retaining hardware. After so many heat cycles and pad changes I think they don't hold the pad as firm. Plus it's only a couple bucks at a local parts store.
mtbiker278 is offline   Reply With Quote
Old 06-04-2010, 05:32 PM   #14
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
On a lot of cars you can see how much pad material you have left without even taking off the wheel.
the suicidal eggroll is online now   Reply With Quote
Old 06-04-2010, 05:45 PM   #15
tedward88
Member#: 235474
2005 WRX
CGM
^^ that and when the pads are gone, there is excessive shaking coming from your steering wheel, also sometimes you can feel it when your stepping on the brake pedal
tedward88 is offline   Reply With Quote
Old 06-05-2010, 12:32 PM   #16
mtbiker278
Member#: 242578
2010 WRX
Spark Silver
Default might be too late
^^^ At this point you might have marred up your rotors. Visual inspection is probably the best. It can be done with the wheel on, but you'll only see the outside pad. If you have the time, I'd do a wheel off inspection. If for whatever reason you had a sticky slide pin, or piston the inside pad would wear faster. I would assume this is the reason why those screech clips are on the inside of the pads.
If the pads are worn down a bunch (<1/8-1/16"), it's probably a good idea to replace them. Cheaper to replace pads upfront than it is to replace rotors and pads later. Also if the pads are unevenly worn inside to outside, you'll probably want to have the calipers inspected and lubed.
03 Impreza brake noise after brakes/rotor replacement derek800 Service & Maintenance 2 03-23-2010 10:32 AM
Brake Noise - Went AutoX on new brakes, now grinding(ish) RandomRacing Brakes, Steering & Suspension 5 10-29-2008 09:11 PM
odd brake noises Suladed Brakes, Steering & Suspension 2 05-18-2001 06:43 AM
Brake noise!? jacktam1 Brakes, Steering & Suspension 5 02-16-2001 09:10 PM
Rear Brake noise Jeff 2.5RS Technical Forum Archive 0 09-17-2000 10:29 PM
Message Board Statistics All times are GMT -4. The time now is 05:45 PM.
