Old 06-03-2010, 11:12 AM   #1
scurabus
Member#: 178158
0002 ppg'd wrx / gc
stm/wrb
Default Can I use 98 outback manual center diff in my 01 rs manual trans?
I think the answer is yes but just want to verify? Thanks
scurabus is offline   Reply With Quote
Old 06-03-2010, 11:19 AM   #2
MrSlowbaru
Member#: 129231
2005 wrx
cgm
i think that the answer is no, isn't the rs 4.11 fd, and the obs is 3.90 fd
MrSlowbaru is offline   Reply With Quote
Old 06-03-2010, 12:40 PM   #3
scurabus
Member#: 178158
0002 ppg'd wrx / gc
stm/wrb
Thus is what confuses me? 3 different subaru specialty shops say It will be alright. I dont know much at all about trannies and gearing nor what the viscous coupling has to do with final drive. I want to believe them but need a concrete answer before I go throwing parts on a transmission that werent intended for it.
Old 06-03-2010, 01:14 PM   #4
grafton
Member#: 187936
07 WRB STi
after being elbow deep into my transmission i am going to say that unless your dealing with the wrx 5mt, where the center diff is not 1:1, it should work fine as long as it slides on to the shafts
on the legacy's & rs's the center diff doesn't effect the FD that's all taken care of by the ring and pinion gears in the front and rear diff's
grafton is offline   Reply With Quote
Old 06-03-2010, 01:51 PM   #5
scurabus
Member#: 178158
0002 ppg'd wrx / gc
stm/wrb
Thank u. I also have a wrx trans that needs a cd and was told I cannot not use the outback cd in it but with the rs trans it will be alright.
Old 06-03-2010, 03:54 PM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
Look at both transfer sections (bolted onto the main gearbox). I'm pretty sure the 98 was a "phase II" type, easily identified by the lack of a flat access panel bolted down on top. I know the 01 will be a phase II. If both are the same, the center diff will literally plug and play.
If the 98 trans has that access panel, you will need to swap the entire transfer section, including the housing and shift selector shaft, along with the center diff. They are not interchangable by themselves.
FWIW, this can all be done under the car, without pulling the trans out completely.
Jay Storm
Old 06-03-2010, 03:58 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
yes
It would work in the wrx trans also.
Old 06-03-2010, 04:27 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
98 Outback tranny is still a phase1 and uses a different center diff than all the 99+.
You cannot use a 98 on your 01, sorry. phase1 is up to '98. Phase2 is 99+.
Put that Outback tranny in your RS!!! You'll love the shorter 5th gear!
People, please do NOT confuse "Outback" with an "Impreza Outback Sport/Outback Sport (OBS)."
FuJi K is online now   Reply With Quote
Old 06-04-2010, 01:15 AM   #9
69subaru360
Member#: 159682
1995 WRX
2015 F150
I thought 98 was the first year of the phase 2 trans. Maybe it was one of those mid year things.
Old 06-04-2010, 07:32 AM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
This is why the OP should look at the trans for the access panel on the top.
It most certainly CAN be done, as I just did it a few months ago on my Forester. The entire transfer section has to be swapped with it, but it can be done. '00 Forester using a 96 Impreza center diff (and housing).
Jay
Can I use a 05 2.5i 4eat in my 03 WRX 4eat? 8URVTEC Transmission (AT/MT) & Driveline 0 12-28-2009 04:03 AM
MY 01 RS 5mt trans question... (asap please) wong-wing Transmission (AT/MT) & Driveline 0 04-12-2005 06:19 PM
new flooring in my 01 RS coupe projectrally Interior & Exterior Modification 6 02-14-2004 07:39 AM
Where can I buy a front mount I/C for my 01 rs 2.5rsMI Normally Aspirated with bolt-on Forced Induction Powertrain 40 11-17-2001 01:44 AM
Wondering if 18 x8 with a 40 offset will fit in my 01 RS? STi - IMPREZA Newbies & FAQs 4 04-29-2001 11:45 PM
