Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 06-03-2010, 11:46 AM   #1
CosworthSTI77
Member Sales Rating: (2)
Member#: 195473
2007 STI
Default FS: 07 Cosworth STI NEW PRICE $36000.00
Now that I see know one is surviving this economy I have dropped the price , I KNOW A LOT OF YOU MIGHT STILL NEED FINANCING SO THE LINK AT THE BOTTOM SAID THEY CAN HELP. A lot of you have seen or heard of the car and know I am an older gentleman who has over $100,000.00 invested in this car. I can certainly say who ever would whined up being the new owner of this car would be happy as hell and be getting probably the best deal on NASIOC. I have all receipts and went back and figured up parts and labor and you will save a bundle. This car makes 530 whp on 93 octane for daily driving has 3 turbo boost settings including q16 map that is at 640 whp right now at 27 psi but could easily go to 32-35 psi and get well into the 700 whp mark. The car has 13000 miles on it right now and thats about 6600 on engine for I swapped out for the Cosworth right away. Has way to much for me to write in aftermarket parts but if someone is truly interested from NASIOC you can pm me and I will talk to you on the phone and even set up to meet you, but please don't waste my time for I really don't need the money I am older and have really took great care of this car while taking it to its limits . I am actually disabled and I am having a hard time driving it because of the power level, but am now trying to give someone else a huge break financially for this car is set with all top quality parts and needs nothing else. I am looking to go back to a more conservative car. Saying all of that this car is universal, it is a DD, can be a track car and can also be a drag car which I have not done track or drag. All my time with this car has been building it to its max to make sure it handles all 3 that I just mentioned. Phil from Element tuning said you may call him to vouch for the mechanical and tuning that was done to this car, all top notch. Well here is a couple of pictures if you have not seen this already. CAR HAS SSR TYPE CRS 17X8.5 GUNMETAL WITH MICHELIN PS2 TIRES NOW WITH PRICE DROP. TYPE F's WILL BE SOLD SEPARATE.
HERE IS A WEB SITE I PUT THE CAR ON TO HELP WITH FINANCING, SHIPPING AND ALL OTHER ISSUES. http://www.usamotorsales.com/Default...6-00192134d25b
http://www.photoshop.com/accounts/f5...398a2eb4cb2e78
http://www.photoshop.com/accounts/f5...488caf4b9d3135
http://www.photoshop.com/accounts/f5...a6555133645d35
http://www.photoshop.com/user/subies...ackingid=BTAGC
2007 Subaru Sti Mod List:
ENGINE:
New Subaru EJ25 STI Engine Block
Cosworth CNC machined port-bored Big Valve Cylinder heads sealed with 11 mm studs
Cosworth 81 mm Billet Crankshaft
Cosworth Forged Pistons and Rings
Cosworth motorsport Tri-metal bearings
Element Tuning Competition H Beam Connecting Rods
Enlarged Intake and Exhaust ports
Large diameter stainless steel intake valves
Large diameter Incolel exhaust valves
Hi Rev Dual valve springs
Titanium Retainers
Hardened Steel spring platforms
Multi angle valve job
CNC Machined port finish
Knife edge port divider
Cosworth S2 High lift camshafts - KK3766
Cosworth High Volume Intake Manifold Rotated
Valve lash set
Cosworth high pressure oil pump
Cam covers
2007 STI with single AVCS drive by wire application
Element Tuning Hydra 2.6 ECU
Element Hydra EMS Accessory Harness
AutoTune WB Air Fuel Sensor for ELT-EMS
Element Tuning GT75 turbo 35/40R with A Frame turbo support bracket
Element Tuning Competition Catch Can System
GT-Spec Custom Header & Rotated uppipe with Vbands
Custom Fabricated Turbo Heatshield
Custom Massive Precision FMIC
Process West Oil Cooler Kit
ATI Super Damper
Power Enterprises Timing Belt
Unorthodox Racing Power Steering Pulley
Unorthodox Racing Alternator Pulley
Gates Alternator Belt
Custom Rotated Intake Pulley Bracket
Perrin Big MAF Intake
Custom Intake with 4 inch Cone K&N Filter
NGK Iridium Gapped Spark Plugs
Optima Battery
Tial 44 mm Wastegate
Tial Blow Off Valve
Cobb Radiator Shroud
Visteon Radiator with dual shrouded fans
Sti 1.5 BAR Radiator Cap
Perrin STI blue radiator hose kit
Vibrant Silicone Sleeves & Couplings
Goodrich Aramid braided hoses & fittings
FUEL SYSTEM:
Walbro GSS 342 Fuel Pump
Full Blown Dual In-Tank Fuel Pump HangerAeromotive Eliminator Fuel Pump
Aeromotive Top feed fuel rails
Fuel Rail Spacers
1600cc EV1 Bosch Indy Fuel Injectors
Aeromotive 6 adjustable fuel pressure regulator
Aeromotive Micron Fuel Filter
Aeromotive Y Block
Aeromotive Hi Flow Oring Fittings
Aeromotive Fittings & Unions
Aeroquip Reducer & Tube
Russell Braided Hose
DRIVETRAIN:
Exedy Triple Disc Cerametilic Clutch
Kartboy Short Shifter
Kartboy Front & Rear Shifter Bushings
ACPT Carbon Fiber Driveshaft
DSS 1000 HP Level 5 Axle/Hub Kit
SUSPENSION:
Tein Flex Coilovers
Tein EDFC Motor Kit
Tein EDFC Controller
Cusco Aluminum Front & Rear Strut Tower Bars
Kartboy Front & Rear Endlinks
Cobb Adjustable Sway Bar Mounts
GT-Spec 3 Piece Subframe Kit
GT-Spec Diff Mount Tie Brace
BRAKES:
DBA 5000 Series Front Rotors w/Blue Hats
DBA 4000 Series Rear Rotors
Hawk Performance HPS Front & Rear Pads
Goodrich Brake Lines
Brembo Calibers
ELECTRONICS:
Blitz FATT Turbo Timer
HKS FT-3 Turbo Timer Harness
Turbosmart E-Boost 40 psi 60mm
Defi Center Gauge Pod
Defi BF Series Amber EGT Gauge 60mm
Defi BF Series Amber Fuel Pressure
Defi BF Series Amber Oil Temp 60mm
Defi BF Series Amber Oil Pressure 60mm
Defi BF Series Amber Water Temp 60mm
Defi BF Series Amber Boost 60mm
Orange Electric Tire Pressure Monitoring System
Pioneer AVIC D2 With Navigation & Back Up Camera
EXTERIOR:
Chargespeed Type 2 Body Kit w/ Rear Diffuser
Chargespeed Sideskirts
Chargespeed 370MM Carbon Wing on Seibon Carbon Fiber Trunk (NOT SHOWN BUT IS INCLUDED)
Seibon CWII Carbon Fiber Hood w/Air Ducts
Rolled & Pulled Front & Rear Fenders
35% Tinted Glass
Sparco Blue Hood Pins
Cosworth License Plate Holder "Power To Pass"
INTERIOR:
Corbeau CR1 Race Seats Black Microsuede
Corbeau Driver & Passenger Seat Bracket
Takata 4-Point Harnesses
Takata 3" Harness Pads
Takata Eyelot Bolt
AutoPower Rollbar
Cobb Shiftknob
Carbon Fiber Gauge Set-Up in Glove Box
WHEELS & TIRES
SSR Type CRS Wheels 17x8.5 Gunmetal
SSR Carbon Fiber Center Caps
Michelin PS2 245/45/17 Tires
Performance Alignment
Titek Lug Nuts
CosworthSTI77 is offline   Reply With Quote
Old 06-03-2010, 11:49 AM   #2
PSM_02_WRX
Member Sales Rating: (3)
Member#: 197108
2003 Ford Mustang GT
BEAUTIFUL CAR, WISH TO OWN ONE LIKE THAT ONE OF THESE DAYS. GLWS
PSM_02_WRX is offline   Reply With Quote
Old 06-03-2010, 12:46 PM   #3
stormhalter
Member Sales Rating: (6)
Member#: 145884
06 STi
Good God, she is beautiful. If you still have it after I come back from overseas I'll have the cash to buy it, hehe.
Bump for a great deal and gorgeous Subie.
Cheers!
stormhalter is offline   Reply With Quote
Old 06-03-2010, 03:01 PM   #4
Abnormal
Lil Curious
Member Sales Rating: (45)
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Curious... Since Phil is vouching, does that mean it's running a Hydra?
Abnormal is offline   Reply With Quote
Old 06-03-2010, 03:37 PM   #5
CosworthSTI77
Member#: 195473
2007 STI
Yes and with no issues at all. Car idles and drives beautifully !
Old 06-03-2010, 03:52 PM   #6
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Gah, SO jealous! Tell you what... if you ever need a kidney, I'll trade you. Just cover my hospital bills and make sure I get the car with a half tank of q16
Old 06-06-2010, 11:03 PM   #7
CosworthSTI77
Member#: 195473
2007 STI
Bump..... Thank you all for the kind words, I do believe if no one comes forward to buy her I will be keeping and turning into a race car, will have to start taking applications for drivers.
Old 06-06-2010, 11:06 PM   #8
madcatz
Member#: 187530
Fuk UrSelf
like I told ya in OC
get that 4 inch dump tube and go crazy on the track
and I would like to submit my hat into the ring for drivers!
my quals:
I like to hear myself talk
I like cheese
madcatz is offline   Reply With Quote
Old 06-07-2010, 08:43 PM   #9
AspenScoob255
Member Sales Rating: (10)
Member#: 217405
2006 WRX
Saw it this weekend, the pictures don't do it justice. It really is a beautiful beast .
AspenScoob255 is offline   Reply With Quote
Old 06-07-2010, 11:05 PM   #10
Louie
Member Sales Rating: (47)
Member#: 43393
2014 Audi a6
Daytona Gray
Bump for you scott.
Check your PM's
Louie is offline   Reply With Quote
Old 06-09-2010, 10:50 PM   #11
CosworthSTI77
Member#: 195473
2007 STI
bump....
Old 06-09-2010, 11:28 PM   #12
ASPENWDriven
Member Sales Rating: (8)
Member#: 248952
2004 Impreza WRX STi
Bump for this amazing Subaru ....... ( you should keep it ! ) ; P
-Joseph
ASPENWDriven is offline   Reply With Quote
Old 06-10-2010, 02:10 AM   #13
yohan04
Member#: 73003
- __ -
What does age have to do anything with the sale? I know plenty "mature" folks who equally make bad decisions and abuse their cars as much as younger folks.
Anyways, seen this car at the OC show and it does look clean. GLWS
yohan04 is online now   Reply With Quote
Old 06-10-2010, 07:17 AM   #14
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Age sometimes (in this case) has to do with maturity. Someone like he, who is older has a better appreciation for the things that his money bought (instead of mom and dad), I can vouch for him. He takes care of his possessions; this wasn't a DD for him, the GTO in the background... DD.
Old 06-11-2010, 04:22 PM   #15
Robs05sti
Member#: 222218
2005 Sti
Free bump for an amazing car. Saw it in OC this past weekend and just as was said above, the pictures do not do it any justice. Truly an amazing car inside and out. Good luck with the sale and congrats to the driver that gets his/her hands on it.
Robs05sti is offline   Reply With Quote
Old 06-13-2010, 10:59 AM   #16
CosworthSTI77
Member#: 195473
2007 STI
bump....
Old 06-13-2010, 02:26 PM   #17
TheBlackNinja
Member#: 246369
2004 Wrx STi
Java Black Pearl
bump! I have a 04 STi with cosworth longblock. Is that the cosworth intake manifold? Looking to get one. What kind of difference did it make if that is it?
TheBlackNinja is offline   Reply With Quote
Old 06-13-2010, 10:23 PM   #18
CosworthSTI77
Member#: 195473
2007 STI
Yes that is the Cosworth intake manifold. In my opinion it did make a significant difference especially up top on my car.
Old 06-15-2010, 02:51 PM   #19
CosworthSTI77
Member#: 195473
2007 STI
BUMP..... For a feeler thread I am actually getting a lot of inquires, thank you all.
Old 06-16-2010, 11:41 PM   #20
CosworthSTI77
Member#: 195473
2007 STI
Bump.....
Old 06-17-2010, 01:19 PM   #21
CosworthSTI77
Member#: 195473
2007 STI
SLIDESHOW ADDED bump....
Old 06-17-2010, 02:04 PM   #22
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Slideshow is locked. Give me a call.
Old 06-17-2010, 09:05 PM   #23
Str8Gone
Member Sales Rating: (36)
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
Slideshow worked fine for me, 1 legit STi
Str8Gone is offline   Reply With Quote
Old 06-18-2010, 07:30 PM   #24
CosworthSTI77
Member#: 195473
2007 STI
Thanks, Louie actually had to help me fix it ! Bump....
Old 06-21-2010, 08:18 PM   #25
CosworthSTI77
Member#: 195473
2007 STI
Bump.... Looks like I will be getting that twinscroll 42r after all !
FS : MD: 07 Cosworth Subaru STI $36000.00 CosworthSTI77 Private Vehicle 'For Sale' Classifieds 269 11-15-2013 06:38 PM
FS: 07 Stock STI turboback and 07 STi Trunk w/ STi wing syswolf SWIC Private Classifieds 9 02-02-2009 09:28 AM
FS: 07 stock sti springs dmoneywrx Suspension/Brakes/Handling 2 05-16-2007 08:37 PM
FS: 07 gold STI rims NHSRT4andSTi Wheels/Tires 3 04-04-2007 01:53 PM
FS: 07 stock STI CBE Siks TXIC Private Classifieds 4 03-12-2007 09:13 AM
