Old 06-03-2010, 01:04 PM   #1
pinoy_boy204
Member#: 223987
2004 WRX
Default washed engine bay, now car won't start CEL on
As the title says. I washed the engine bay of my 04 wrx and proceeded home. at this point the car did not want to idle, barely made it home.
pulled out the AP, got p0244 wastegate actuator solenoid. when i disconnect my MAP sensor the car will run, and just the code for the MAP appears on the AP. what could be the problem?
04 subaru wrx
AP stage 2 91 octane
cobb downpipe
cobb cat-back
ARC intake chamber
pinoy_boy204 is offline   Reply With Quote
Old 06-03-2010, 01:13 PM   #2
felixk
Member#: 188019
2004 Audi S4
You maybe did something to your factory boost controller. Maybe one of the hoses got pulled out when you were washing the engine bay?
felixk is offline   Reply With Quote
Old 06-03-2010, 01:17 PM   #3
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
When you say "wash"... do you mean "powerwash" (considering you didn't do this at home)? I would definitely look for a hose / connector blown off.
NitroTrike is offline   Reply With Quote
Old 06-03-2010, 01:20 PM   #4
spinningcain
Member#: 176490
2005 STI
Check the maf
spinningcain is offline   Reply With Quote
Old 06-03-2010, 01:27 PM   #5
pinoy_boy204
Member#: 223987
2004 WRX
no codes for MAF though, i will try and pick up a new one.
why would the wastegate solenoid code clear when the MAP sensor disconnected? this is the only way the car can run.
i checked the vaccuum lines connected to the boost controller, everything still connected.
Old 06-03-2010, 03:51 PM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
how did you wash the engine bay exactly?
Old 06-03-2010, 04:32 PM   #7
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
perhaps you cracked one of the boost lines...the stock lines get very brittle and break easily. They get very hard and basically if you move them from their cozy little spot they will snap immediately.
kayen is online now   Reply With Quote
Old 06-03-2010, 06:09 PM   #8
pinoy_boy204
Member#: 223987
2004 WRX
i might've cracked one of the boost lines... should i just replace the 2 vacuum lines connected to the boost controller ?
car instantly dies when everything is connected. i've tried going back into stock mode to see if it helps, nothing works.
i'm going to try and order a new boost solenoid but i doubt its the problem since the code disappears once i remove the map sensor plug. and only map sensor code is present.
Old 06-03-2010, 06:32 PM   #9
speedymaker
Member#: 162070
2005 VF48 wrx wagon
that shouldnt make ur car not run, it would just run off wastegate pressure... must have done something else. Do you still have the stock airbox or an exposed filter that could have sucked water in it
speedymaker is offline   Reply With Quote
Old 06-03-2010, 07:12 PM   #10
pinoy_boy204
Member#: 223987
2004 WRX
i have a ARC filter and ARC airbox and the filter element is not exposed to water.
Old 06-03-2010, 07:47 PM   #11
pinoy_boy204
Member#: 223987
2004 WRX
im gonna try and remove the plugs to see if water is inside. i doubt there is.
Old 06-03-2010, 07:57 PM   #12
SVT_WRX
Member#: 164830
G61 III OVE 58e
Did you check the filter anyway?
The reason I ask is because I had a similar issue not long ago. I washed my car and water got on my filter and wouldn't allow me to start it. Dried it up and it started immediately.
SVT_WRX is offline   Reply With Quote
Old 06-03-2010, 09:43 PM   #13
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Wirelessly posted (Phallic Tractor: BlackBerry9630/5.0.0.497 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Washed it how? What chemicals and tools?
XanRules is offline   Reply With Quote
Old 06-04-2010, 12:46 AM   #14
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Pressure washer vs a garden hose, chemicals, solvents, open flame or heat guns, urine, explosives? The only fact we know is you washed your car and now its F'd up.
I'd take apart the electrical connectors for your boost solenoid and MAP sensor a see if you got water in there. Could be cause of your problems. Check the bulkhead connector too.
Old 06-04-2010, 01:44 AM   #15
pinoy_boy204
Member#: 223987
2004 WRX
Just washed it with low pressure at the coin operated wash. I will double check the connection to the map and boost solenoid again. Its just weird how the car can run with the map sensor unplugged .
Old 06-04-2010, 08:23 AM   #16
quazimoto
Member#: 70395
There is a right way and a wrong way to wash an engine. You did the wrong way. Using any kind of pressurized wand will force water into areas it shouldn't be,like electrical connectors.
quazimoto is offline   Reply With Quote
Old 06-04-2010, 10:26 AM   #17
pinoy_boy204
Member#: 223987
2004 WRX
Friend said could be electrical issue via shop key. I guess its time to start tracing
Old 06-04-2010, 11:51 AM   #18
DanBates2002
Member#: 183102
2002 Impreza WRX
Sedona Red
Did you wash it with soap? The reason I ask is because soap holds an electrical charge and will simulate a short in all or most of your electric systems. Happened to my dads mustang, just rinse it out with clean water and let it sit outside with the hood open for a while.
DanBates2002 is offline   Reply With Quote
Old 06-04-2010, 01:42 PM   #19
quazimoto
Member#: 70395
And water doesn't?
Old 06-04-2010, 02:48 PM   #20
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Originally Posted by quazimoto View Post
And water doesn't?
De-ionized water will not. All others will conduct by varying degrees.
Old 06-04-2010, 07:20 PM   #21
pinoy_boy204
Member#: 223987
2004 WRX
my accessport has p0244 wastegate code when its plugged in ...but when i plug in my other obd reader i get p0129 and p0244.
Old 06-04-2010, 07:44 PM   #22
DeatschWerks
Member#: 87358
What CEL is on? You want to try avoid the alternator and the distributor/coilpacks. I usually use a plastic back to cover them up, as well as, the air filter element. ...and I usually just focus on the hood, firewall, and engine bay. Don't really focus on the engine much. It cleans up pretty well with a little window cleaner/simple green and a wet cloth.
DeatschWerks is offline   Reply With Quote
Old 06-04-2010, 08:49 PM   #23
quazimoto
Member#: 70395
And how many coin operated DIY car wash pressure washers use de-ionized water? Yeah.............
Old 06-04-2010, 08:50 PM   #24
pinoy_boy204
Member#: 223987
2004 WRX
see above
Old 06-05-2010, 01:46 AM   #25
kbobomber89
Member#: 231418
2006 WRX
im a detailer at carmax and we powerwash the engine bay. ive only had one issue with a dodge not starting...but then again thats a dodge ha. but i just bought engine degreaser for the wrx and covered the cobb air filter and mass air flow sensor and used a hose and rinsed the degreaser off. no need for a powerwasher imo. you just leave the hood popped and let it dry for a while? sometimes wires and what not will get disconnected if you power wash so just check all the connections.
kbobomber89 is offline   Reply With Quote
Wife wrecked into fence, now car won't start. Gorgar General Community 18 11-24-2004 06:59 PM
Changed brakes... now car won't start??? slim speedy Mid Atlantic Impreza Club -- MAIC 12 02-02-2004 07:24 PM
Rat chewed on a wire, now car won't start ! Help ! 99LegacyGT Legacy Forum 3 07-14-2003 04:16 PM
Did engine swap, now car won't start, I need help! (non-subaru) RebelINS Mid West Subaru Owners Club Forum -- MWSOC 14 06-23-2003 01:21 AM
I unplugged my unichip now car won't start! potouli Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-23-2002 01:17 PM
