Old 06-03-2010, 01:27 PM   #1
NWSTi-wa
Member#: 245786
Default Wiring for prosport gauges?
I recently bought prosport gauges and am in the process of installing them. I have egt, boost, and oil pressure. I had a few questions to anyone who has installed these before me. Firstly does anyone have a link to a page that has a DIY as to what wires go to what and any other info on how to install? And where does the oil pressure adapter go? Im a little confused on the wiring for the clock (im installing them on a clock pod) as they are mixed colors. red/white cords etc...
Any info would be great!
thanks
NWSTi-wa is offline   Reply With Quote
Old 06-03-2010, 04:00 PM   #2
BoostinChick
Member#: 218971
2007 WRX
BoostinChick is offline   Reply With Quote
Old 06-05-2010, 03:29 AM   #3
NWSTi-wa
Member#: 245786
Thanks! That helped a little, Im still stumped on the wiring though... And I have been searching and can't find anything about prosport wiring!
Old 06-05-2010, 10:42 PM   #4
bholl3346
Member#: 220752
Hey buddy, I still have my diagram from when I installed them.
red-12v accessory power
black-ground
white-accessory power 12v
blue-head light switch(12v switch power)
Now the colors for the white and blue might be diff depending on the color of the gauges. The prosport support page has more answers. I'd try searching there. Good luck to you.
bholl3346 is offline   Reply With Quote
Old 06-07-2010, 03:27 PM   #5
BoostinChick
Member#: 218971
2007 WRX
Did you look on the back of the clock? It tells you what wire is what (i.e. PWR, GND, ILLUM/ACC, IGN). As simple as it gets.
Old 06-16-2010, 04:54 PM   #6
IllustriousBrown
Member#: 200355
2006 WRX Wagon
WRB, Cobb Stage 2
For Oil pressure (if any of you know) do I ground the black wire only on the sender, or do I have to split it and ground it at my clock (that's where I tapped in for boost) as well?
IllustriousBrown is offline   Reply With Quote
prosport gauge wiring. Freakstyle101891 Newbies & FAQs 91 08-18-2011 06:09 PM
**Prosport gauge wiring, need exact wires** shamrock 05 Interior & Exterior Modification 10 08-04-2011 11:13 AM
Wrapping up install need help with Prosport Gauge wiring last lemming alive Electrical & Lighting 4 01-14-2008 03:52 PM
Need Exact Wires to Attach Prosport Gauge Wires To Idaho Electrical & Lighting 1 09-12-2007 06:15 PM
Prosport Gauge wiring. Gocasen Interior & Exterior Modification 19 06-08-2007 01:55 AM
