Old 06-03-2010, 02:05 PM   #1
prodrive02
Member#: 113977
2007 Subaru wrx
Default Spacers
I have a set of 10mm eibach spacers, I've been skeptic on installing them after reading that spacers will aid the wear of bearings and such. Anyone installed spacers this size? Any problems?
prodrive02 is offline   Reply With Quote
Old 06-03-2010, 02:13 PM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Why are you installing spacers? Do you have longer studs? IMO the bigger issues with spacers (pushing the wheels out without adding wheel size) is the unfavorable change to the scrub radius. Steering will be heavier, the car will tramline more, and bumps will be more harsh.
Old 06-03-2010, 03:12 PM   #3
prodrive02
Member#: 113977
2007 Subaru wrx
I do have longer studs(they were in the kit) I have prodrive p 1's that are stock offset, and wanted to get rid of the sunk in look but was unsure or the effects of them - which doesn't sound like anything I would want..
Old 06-03-2010, 03:54 PM   #4
sc00by4life
Member#: 97135
I dont think you'll run into tramlining issues (at least anymore than normal) unless you are running a wider tire.
You'll be fine with the spacers, dont be scared. There is going to be increased stress on the wheel bearings, but you'll get that issue by simply running a lower offset wheel in the first place (same with the scrub radius issues).
Old 06-03-2010, 11:16 PM   #5
prodrive02
Member#: 113977
2007 Subaru wrx
Thanks for the info, I didn't want to go to all the trouble of swapping studs out then not be happy with the aftermath.
FT: 15mm spacer for 10mm spacer wantsti RMIC Private Classifieds 5 01-30-2010 03:05 PM
Group A / GrimmSpeed Power Package IM Spacer/ TB Spacer GrimmSpeed MWSOC Vendor Classifieds 2 08-11-2009 06:57 PM
Spacers and wheel balance + other issues with spacers Yoo Shin Tire & Wheel 4 07-09-2009 10:15 AM
bought used old model whiteline alk 60319WL w/o spacers. Are the spacers necessary? garie Brakes, Steering & Suspension 8 05-02-2005 05:00 PM
