Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 06-03-2010, 03:42 PM   #1
TSReynolds
Member#: 21015
2002 Impreza WRX
Default AC is shooting mist and frost out vents
2002 WRX sedan with 67,000 miles. Single owner, always used dealer maintenance.
The car received a full 60,000 mile tune up at the dealer in December so it should be running fine. They said everything looked good, replaced the fuel lines per the recall, changed steering fluid, flushed the system, etc... I hardly drive the car because I live in the city and keep the car at my office in Westchester in a garage. It gets around 3000-5000 miles a year...hence the low mileage.
Was running the AC for the first time this season today while driving on the highway around 60mph. AC was running fine on the way to Court (30 miles) but on the way back it began to blow much softer to barely at all and I noticed the two center vents (but not the right and left door vents) were blowing out something that looked like smoke. At first I thought the engine was overheating/smoking but I checked the temp gauge and under the hood and it was fine. I then smelled the alleged smoke and it didn't smell like anything. The windows were shut and there was no odor of smoke. So I'm scratching my head trying to figure out what's going on. I turn the AC on full blast and the smoke (now I've realized it's mist/steam) comes out harder along with little white flecks, which I am assuming was frost or ice.
Anyone know what's going on with my AC? Never experienced this before. Thought it was pretty weird.
TSReynolds is offline   Reply With Quote
Old 06-03-2010, 03:53 PM   #2
TSReynolds
Member#: 21015
2002 Impreza WRX
Default Oh, a few more details
There was no CEL and the car is stock and has never been modified.
Old 06-03-2010, 03:55 PM   #3
AlboWRX
Member#: 37719
2003 WRX
Might be low on refrigerant. I know that when this happens in a house ac evaporator, you're building ice due to the lack of freon.
AlboWRX is offline   Reply With Quote
Old 06-03-2010, 04:00 PM   #4
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Let me guess, it does it as soon as you slow down, or when you open a window right?
Might want to check the ol' pollen filter...
Mine has been doing it for 8+ years... gets progressively worse as the filter gets clogged, and as the humidity goes up.
NitroTrike is offline   Reply With Quote
Old 06-03-2010, 04:08 PM   #5
TSReynolds
Member#: 21015
2002 Impreza WRX
Hmmm...I'll have to check out both. Pardon my ignorance, but where is the filter located?
Old 06-03-2010, 04:12 PM   #6
NitroTrike
Member#: 62408
Behind the glove box under the white cover.
http://forums.nasioc.com/forums/show...ghlight=pollen
Old 06-03-2010, 04:26 PM   #7
TSReynolds
Member#: 21015
2002 Impreza WRX
Gracias.
Old 06-04-2010, 03:25 AM   #8
Chi_San
Member#: 53558
2002 WRX Wagon
I'd guess it's the thermal expansion valve is frozen open. You're basically freezing your evaporator solid. The valve is supposed to regulate the amount of refrigerant that goes into the evaporator, to prevent it from icing over, and also to keep the compressor from having to cycle on and off.
Is the AC compressor kicking on and off? If it isn't, then you might have a bad temperature sensor, or it fell off the evaporator core.
It's easy to tell if this is the problem by simply turning the AC off when this happens, leave it off for a few minutes, and see if the AC works okay when you turn it back on, then starts blowing vapor again as it runs. You can also turn the AC on when it's cold, and the compressor should cycle on and off, with longer periods of 'off' time. If it just comes on constantly, then the thermal probe needs to be serviced.
Edit: A low charge typically results in warm air coming out the vents, and would not effect the volume of air coming out the vents. The Evaporator core icing over would. A clogged pollen air filter could do this too, though I don't know if they are standard or optional equipment. Mine doesn't even have a filter.
Chi_San is offline   Reply With Quote
Old 06-04-2010, 08:16 AM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Should have posted this in the Service and Maintenance section (where it should be moved shortly), but anyway it sounds like you have the known freezup issue-
http://forums.nasioc.com/forums/show...postid=4179167
I had this problem several years ago, did the fix and my AC has been perfect since then.
Old 06-04-2010, 08:58 AM   #10
rkramer
Member#: 118209
2015 WRX Limitec
Unless I'm mistaken, there was no filter option on the '02's. Yep, the spot is there, you just couldn't get it installed out the door.
Old 06-04-2010, 11:10 AM   #11
NitroTrike
Member#: 62408
My 02 had it right off of the truck. The only way I knew it even had one was the sticker that was on my door jamb.
Old 06-07-2010, 03:33 PM   #12
TSReynolds
Member#: 21015
2002 Impreza WRX
Default Thank you
Thanks all for the response. Sorry, Mulder, for the incorrect forum. I couldn't figure out where it should be posted. As you can tell, I have not posted in a while so I get lost among all the different categories.
I do have an air filter, which was an option on the '02 WRX. If that's not the problem, I'll check into the thermal expansion valve fix as my symptoms are exactly as explained by Chi_San.
Thanks all.
Old 06-07-2010, 03:38 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Did you look at the link I posted for you (it's in the stickies in this section)? Your symptoms are exactly what happens with the old-style thermoswitch unit, and will most likely be fixed by doing the TSB fix with the new updated one.
Old 06-07-2010, 03:55 PM   #14
TSReynolds
Member#: 21015
2002 Impreza WRX
I did. I'm going to contact the dealer when I get a chance to have it checked out. Thanks!
Old 06-07-2010, 04:06 PM   #15
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ok, just bear in mind that they will charge you for any diagnosis and repair. As a TSB it was only done for free during the original 3/36 warranty period. Unfortunately it is a fairly labor-intensive fix although there is an alternate procedure described in the linked thread for R&R'ing the evaporator core that requires less disassembly than what's in the service manual. The actual part that gets replaced is not that expensive, about $60 when I bought it a few years ago so probably a bit more now.
I'd suggest printing out the info from that thread and taking it with you to show them, in case they aren't aware of it.
Old 06-07-2010, 04:15 PM   #16
TSReynolds
Member#: 21015
2002 Impreza WRX
Just called the dealer and made an appointment. Mentioned the TSB and they didn't even question me. This dealer has been pretty good about service bulletins. They did the fuel line fix for me without me even asking and at no charge. Then again, all the other work they did at the 60K tune up ran me over $1,000...which was insane. So maybe they just felt bad.
Old 06-16-2010, 03:12 PM   #17
TSReynolds
Member#: 21015
2002 Impreza WRX
So I just got the car back from the dealer. The problem wound up being a leak in a thermo tube? He said air and moisture were getting into the lines which was causing the fog and decrease in pressure. The new tube was $127. They also had to discharge the system and then refill it. All together, with labor and tax, it came out to $452. Definitely not a cheap fix. Hopefully this is the last bit of maintenance I'll have on the car for a while.
Thanks to everyone for the help/suggestions. It didn't wind up being the air filter or the temp gauge.
My STI is overheating when the AC is on and the AC fan doesnt work, why overheating? nicksamba_18 Service & Maintenance 1 03-09-2015 09:55 PM
Happy Birthday H.K., Butterz is in TO, ...and now out. Lucky Loser Texas Impreza Club Forum -- TXIC 77 07-02-2009 06:39 AM
Gee, I wonder why my AC is blowing slowly and smells vaguely mouse-ish. Strider Off-Topic 19 06-27-2009 07:35 PM
saying "Post reported scumbag" is so old and played out alacrity024 Off-Topic 1 08-07-2007 03:44 PM
AC is a BOOOOOOG and not THAT cold V8killaREX General Community 9 07-08-2006 10:06 PM
