Old 06-03-2010, 04:31 PM   #1
Carartist
Member#: 241627
2007 WRX STI Limited
Metallic Grey
Default My first TURBO car. Is this normal?
Hi guys; I was wondering about the behavior of my 07' STI Limited car. It's bone stock exept a K&N air filter. When I accelerate hard; it seems that right as the turbo starts to kick in; there is 2 distinct pops of power as if I had "double stepped" the accelerator pedal. At first I thought it was the tires breaking loose on a wet road; but it does the same on a dry road. I have also noticed just today while back out of my garage, that it may have a front right CV joint going out. (Clicking while turning) Any ideas?
Carartist is offline   Reply With Quote
Old 06-03-2010, 05:34 PM   #2
kh15
Member#: 132400
sounds like something is slipping, possibly your cv joints as you say it sound like they may be going out.
your car should pull much harder once the turbo kicks in but it should be a rather smooth progression and not like a"pop"
seeing as your car is stock im willing to bet its your cv joints or another mechanical issue since your stil running your stock conservative map
kh15 is offline   Reply With Quote
Old 06-03-2010, 05:57 PM   #3
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
CV joints don't slip.
Splinter is offline   Reply With Quote
Old 06-03-2010, 06:13 PM   #4
kh15
Member#: 132400
well never mind then lol
Old 06-03-2010, 06:19 PM   #5
antigfk
Member#: 122242
2006 WRX LTD
As for the jerkiness of acceleration, it is probably the crappy stock ECU tune. My 06 wrx had jerky acceleration until I got it tuned... now the powerband is relatively smooth.
antigfk is offline   Reply With Quote
Old 06-03-2010, 06:27 PM   #6
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
ditch the K/N, clean your MAF sensor and start from there. that filter will only compound problems and get the insides of your engine quite dirty. A paper type air filter really is not a restriction unless you increase engine output and there are dry foam type filters that are the best compromise between catching dirt and flowing air if you have to have an after market filter.
Old 06-03-2010, 06:50 PM   #7
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
You have some good tuners in Oregon! I'd recommend taking the car in and having it tuned. Not only can you insure that your new pride and joy is running right but you can also gain a nice bump in power!
Mike
GrimmSpeed is offline   Reply With Quote
Got my first turbo car finally 97 Pimpreza New England Impreza Club Forum -- NESIC 24 04-13-2010 02:08 PM
Water dripping from my car, is this normal? Landsharkk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-04-2007 08:08 PM
first gear shakes...is this normal? POiNT5CHiNK Transmission (AT/MT) & Driveline 1 08-23-2004 01:42 AM
I get .85mpa in first and second. is this normal? dijay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-05-2002 04:49 PM
My First Turbo Car ! Jon Bogert General Forum Archive 21 10-12-2000 12:32 AM
