Old 06-03-2010, 05:43 PM   #1
roanokeimpreza
Member#: 222717
2009 2.5i 5dr
obsidian black
Question STI rear anti sway bar on an 09 2.5i
My friend search hasn't answered all my questions so I'd like hear from some people that have done this install.
I just worked out a Trade with another member and I have the rear sway bar and endlinks on the way. Will I need some other parts to do this?(brackets maybe?) If so where did you get them?
Thanks
roanokeimpreza is offline   Reply With Quote
Old 06-04-2010, 02:06 AM   #2
littlec
Member#: 208934
09 2.5i
The n/a's unfortunately don't come with a rear sway bar or brackets in the 08+'s. you'll need to get the brackets and bolts as well.
check this thread for part numbers http://www.3gwrx.com/forum/index.php?topic=2605.0
just pick them up from the dealership. subarugenuineparts/chaplins should be able to get you the parts for cheap.
littlec is offline   Reply With Quote
Old 06-04-2010, 02:34 AM   #3
Magic Marker
Member#: 181568
2011 3.6R Legacy LTD
Steel Silver Metallic
Yeah you'll need all the parts. I had it done on my 08 OBS and it's a great upgrade.
Magic Marker is offline   Reply With Quote
Old 06-04-2010, 04:39 AM   #4
marcf
Member#: 159039
2011 WRX Hatch
I would double check whether STi swaybars fit the others, I've heard the don't
it might apply up to 07 models, best find out before you buy
marcf is offline   Reply With Quote
Old 06-04-2010, 09:11 AM   #5
archdude
Member#: 205968
Yeah, you're also going to need bushings
archdude is offline   Reply With Quote
Old 06-04-2010, 09:55 AM   #6
Magic Marker
Member#: 181568
It fits. I have the 19mm STi RSB. At least it does on my 08.
Old 06-04-2010, 11:50 AM   #7
Ty55
Member#: 237195
2007 Impreza 2.5i
WY Scooby Lover
Does anyone have picture of rear sway bars installed in say an '07 2.5i or comparable model? I've never seen exactly where they sit installed and am curious if they interfere with trunk space at all. (wife needs her trunk space? : /)
Ty55 is offline   Reply With Quote
Old 06-04-2010, 12:18 PM   #8
twilightx
Member#: 245305
2007 Impreza 2.5i
Newport Blue Pearl
^ Sway bars go under the car...I think you're thinking of strut tower bars which mount inside.
twilightx is offline   Reply With Quote
Old 06-04-2010, 12:32 PM   #9
Ty55
Member#: 237195
2007 Impreza 2.5i
WY Scooby Lover
yep, another stupid moment for the day
Old 06-04-2010, 04:35 PM   #10
roanokeimpreza
Member#: 222717
2009 2.5i 5dr
obsidian black
Parts ordered. Big help.
Came with the STI bushings.
Thanks Guys.
I'll try to post some pics of the install for the next guys.
Old 06-04-2010, 06:07 PM   #11
Gate4jg
Member#: 98798
04 impreza STI
http://www.mainelysubarus.com/forums...hlight=gate4jg
if you need to know anything just shout
Gate4jg is offline   Reply With Quote
Old 06-05-2010, 12:22 AM   #12
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
another great place for stuff like this is the suspension forum. I know it's a radical idea but if you give it a try I promise you will find loads of better info.
Old 06-05-2010, 12:24 AM   #13
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Thanks Guys.
Please, for the love of the next guy being able to find the pics, don't post them here!!!! 99.9% of NASIOC users/members will look in the suspension forum for info about how to install the SWAYBAR!
Old 06-05-2010, 01:17 AM   #14
GT11
Member#: 128002
0000 four door sedan
Poop color
the 08's and + don't come with a rear sway bar?
wtf
GT11 is offline   Reply With Quote
Old 06-11-2010, 01:18 PM   #15
Henry H
Member#: 184330
2008 Impreza 2.5i
Dark Grey Metallic
Not sure if everyone covered everything but I did this add-on from a seller that got me the sway bar, bushings and endlinks
You'll need:
-4 mounting bolts
-2 mounting brackets (clamp stabilizer)
-2 endlink bolts (flange bolts)
-2 endlink nuts (flange nuts)
-moly lube or teflon tape for bushings (optional)
The mounting bolts can be purchased at an autoparts store. I went to autozone for mine 1.15$ for 4 bolts. The other six items can be purchased at the dealership. You might be able to get away with getting the bolts and nuts at a hardware store but I wasnt sure if they had a shank or not and it wasnt that expensive anyways. You'll definitely need the brackets tho.
The moly lube or teflon tape is just to grease up your bushing contacts to keep them from creaking when old. You apply the lube or you can wrap contact points with teflon tape to keep it a little cleaner.
The mounting equipment cost about 17$ all together.
Henry H is offline   Reply With Quote
Old 06-11-2010, 02:14 PM   #16
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
To clarify, because different model-series owners (GD/GG vs GE/GH/GR) asked the same question.
For within the 2002-2007 models, an STI rear swaybar will not fit an RS/I/WRX. (It is not a direct swap - you would need the STI specific rear lateral-links to do so.)
For within the 2008+ models, an STI rear swaybar will fit. As you have read, the "I" models (non-turbo) do not come with one and as such, you will have to purchase the requisite hardware to mount the bar.
Perrin 22mm rear sway bar kit for '08 2.5i heat7881 MAIC Private Classifieds 1 02-05-2013 08:49 AM
Will this wheel set up fit on an 09 2.5i? chigger702 Newbies & FAQs 9 04-19-2010 01:11 AM
Will 09 STI suspension fit on my 09 2.5i? CrotchMonster Brakes, Steering & Suspension 3 03-30-2009 04:36 PM
03 sedan rear sway bar on an 04 sedan? LYHTSPD Brakes, Steering & Suspension 4 07-31-2004 05:15 PM
getting an anti sway bar on to my brighton left footed whooten Brakes, Steering & Suspension 5 01-28-2004 06:38 PM
