Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 06-03-2010, 06:19 PM   #1
CosworthSTI77
Member Sales Rating: (2)
Member#: 195473
2007 STI
Default MD: 07 Cosworth Subaru STI $36000.00 SOLD
Now I see know one is surviving this economy so I have dropped the price. I KNOW A LOT OF YOU STILL WOULD NEED FINANCING, SO THE LINK AT THE BOTTOM SAID THEY WOULD HELP OUT, GIVE THEM A CALL ITS WORTH A SHOT ! A lot of you have seen or heard of the car and know I am an older gentleman who has over $100,000.00 invested in this car. I can certainly say who ever would whined up being the new owner of this car would be happy as hell and be getting probably the best deal on NASIOC. I have all receipts and went back and figured up parts and labor you will save a bundle. This car makes 530 whp on 93 octane for daily driving has 3 turbo boost settings including q16 map that is at 640 whp right now at 27 psi but could easily go to 32-35 psi and get well into the 700 whp mark. The car has 13000 miles on it right now and thats about 6600 on engine for I swapped out for the Cosworth right away. Has way to much for me to write in aftermarket parts but if someone is truly interested from NASIOC you can pm me and I will talk to you on the phone and even set up to meet you, but please don't waste my time for I really don't need the money I am older and have really took great care of this car while taking it to its limits . I am actually disabled and I am having a hard time driving it because of the power level, but am now trying to give someone else a huge break financially, for this car is set with all top quality parts and needs nothing else. I am looking to go back to a more conservative car. Saying all of that this car is universal, it is a DD, can be a track car and can also be a drag car which I have not done track or drag. All my time with this car has been building it to its max to make sure it handles all 3 that I just mentioned. Phil from Element tuning said you may call him to vouch for the mechanical and tuning that was done to this car, all top notch. Well here is a couple of pictures if you have not seen this already. *****Car has the SSR TYPE-C 17X8.5 with Michelin PS2 on them now with the price drop*****. The SSR Type F can be bought separately if wanted with car.*******
HERE IS A WEB SIGHT I RECENTLY PUT THE CAR ON TO HELP WITH FINANCING, SHIPPING AND ALL OTHER ISSUES.
http://www.usamotorsales.com/Default...6-00192134d25b
http://www.photoshop.com/accounts/f5...a6555133645d35
http://www.photoshop.com/accounts/f5...398a2eb4cb2e78
http://www.photoshop.com/accounts/f5...488caf4b9d3135
http://elementtuning.com/store/wp-co...600raceweb.jpg
http://www.photoshop.com/user/subies...ackingid=BTAGC
2007 Subaru Sti Mod List:
ENGINE:
New Subaru EJ25 STI Engine Block
Cosworth CNC machined port-bored Big Valve Cylinder heads sealed with 11 mm studs
Cosworth 81 mm Billet Crankshaft
Cosworth Forged Pistons and Rings
Cosworth motorsport Tri-metal bearings
Element Tuning Competition H Beam Connecting Rods
Enlarged Intake and Exhaust ports
Large diameter stainless steel intake valves
Large diameter Incolel exhaust valves
Hi Rev Dual valve springs
Titanium Retainers
Hardened Steel spring platforms
Multi angle valve job
CNC Machined port finish
Knife edge port divider
Cosworth S2 High lift camshafts - KK3766
Cosworth High Volume Intake Manifold Rotated
Valve lash set
Cosworth high pressure oil pump
Cam covers
2007 STI with single AVCS drive by wire application
Element Tuning Hydra 2.6 ECU
Element Hydra EMS Accessory Harness
AutoTune WB Air Fuel Sensor for ELT-EMS
Element Tuning GT75 turbo 35/40R with A Frame turbo support bracket
Element Tuning Competition Catch Can System
GT-Spec Custom Header & Rotated uppipe with Vbands
Custom Fabricated Turbo Heatshield
Custom Massive Precision FMIC
Process West Oil Cooler Kit
ATI Super Damper
Power Enterprises Timing Belt
Unorthodox Racing Power Steering Pulley
Unorthodox Racing Alternator Pulley
Gates Alternator Belt
Custom Rotated Intake Pulley Bracket
Perrin Big MAF Intake
Custom Intake with 4 inch Cone K&N Filter
NGK Iridium Gapped Spark Plugs
Optima Battery
Tial 44 mm Wastegate
Tial Blow Off Valve
Cobb Radiator Shroud
Visteon Radiator with dual shrouded fans
Sti 1.5 BAR Radiator Cap
Perrin STI blue radiator hose kit
Vibrant Silicone Sleeves & Couplings
Goodrich Aramid braided hoses & fittings
FUEL SYSTEM:
Walbro GSS 342 Fuel Pump
Full Blown Dual In-Tank Fuel Pump HangerAeromotive Eliminator Fuel Pump
Aeromotive Top feed fuel rails
Fuel Rail Spacers
1600cc EV1 Bosch Indy Fuel Injectors
Aeromotive 6 adjustable fuel pressure regulator
Aeromotive Micron Fuel Filter
Aeromotive Y Block
Aeromotive Hi Flow Oring Fittings
Aeromotive Fittings & Unions
Aeroquip Reducer & Tube
Russell Braided Hose
DRIVETRAIN:
Exedy Triple Disc Cerametilic Clutch
Kartboy Short Shifter
Kartboy Front & Rear Shifter Bushings
ACPT Carbon Fiber Driveshaft
DSS 1000 HP Level 5 Axle/Hub Kit
SUSPENSION:
Tein Flex Coilovers
Tein EDFC Motor Kit
Tein EDFC Controller
Cusco Aluminum Front & Rear Strut Tower Bars
Kartboy Front & Rear Endlinks
Cobb Adjustable Sway Bar Mounts
GT-Spec 3 Piece Subframe Kit
GT-Spec Diff Mount Tie Brace
BRAKES:
DBA 5000 Series Front Rotors w/Blue Hats
DBA 4000 Series Rear Rotors
Hawk Performance HPS Front & Rear Pads
Goodrich Brake Lines
Brembo Calibers
ELECTRONICS:
Blitz FATT Turbo Timer
HKS FT-3 Turbo Timer Harness
Turbosmart E-Boost 40 psi 60mm
Defi Center Gauge Pod
Defi BF Series Amber EGT Gauge 60mm
Defi BF Series Amber Fuel Pressure
Defi BF Series Amber Oil Temp 60mm
Defi BF Series Amber Oil Pressure 60mm
Defi BF Series Amber Water Temp 60mm
Defi BF Series Amber Boost 60mm
Orange Electric Tire Pressure Monitoring System
Pioneer AVIC D2 With Navigation & Back Up Camera
EXTERIOR:
Chargespeed Type 2 Body Kit w/ Rear Diffuser
Chargespeed Sideskirts
Chargespeed 370MM Carbon Wing on Seibon Carbon Fiber Trunk (NOT SHOWN BUT IS INCLUDED)
Seibon CWII Carbon Fiber Hood w/Air Ducts
Rolled & Pulled Front & Rear Fenders
35% Tinted Glass
Sparco Blue Hood Pins
Cosworth License Plate Holder "Power To Pass"
INTERIOR:
Corbeau CR1 Race Seats Black Microsuede
Corbeau Driver & Passenger Seat Bracket
Takata 4-Point Harnesses
Takata 3" Harness Pads
Takata Eyelot Bolt
AutoPower Rollbar
Cobb Shiftknob
Carbon Fiber Gauge Set-Up in Glove Box
WHEELS & TIRES
SSR Type CRS Wheels 17x8.5 Gunmetal
SSR Carbon Fiber Center Caps
Michelin PS2 245/45/17 Tires
Performance Alignment
Titek Lug Nuts
CosworthSTI77 is offline   Reply With Quote
Old 06-03-2010, 07:40 PM   #2
wayoutwest
Member Sales Rating: (4)
Member#: 14379
2007 Acura
gray
Holy crap! Bump for you good sir.
wayoutwest is offline   Reply With Quote
Old 06-03-2010, 07:44 PM   #3
2.5rshead
Member Sales Rating: (3)
Member#: 186692
04 WRX
bump for a RIDICULOUSLY bad ass subie
2.5rshead is offline   Reply With Quote
Old 06-03-2010, 07:46 PM   #4
Fireant
Member#: 235510
2006 GTO
Torrid Red
Awesome GTO in the pics
Fireant is offline   Reply With Quote
Old 06-03-2010, 08:19 PM   #5
HSBabyFace
Member Sales Rating: (6)
Member#: 130204
14 JKUR
That good sir is SICK
HSBabyFace is offline   Reply With Quote
Old 06-03-2010, 08:32 PM   #6
ilikesubaru:)
Member Sales Rating: (10)
Member#: 207275
2000 RSTI/07 STI
WRB/SWP
I wish I had the money.
ilikesubaru:) is offline   Reply With Quote
Old 06-03-2010, 09:02 PM   #7
beantown
Member#: 185593
Beautiful!
beantown is offline   Reply With Quote
Old 06-03-2010, 09:56 PM   #8
leach0789
Member Sales Rating: (9)
Member#: 210903
2013 MS3/Turbo Miata
Nitrous Rhodes
Amazing. This will never leave the front page haha
leach0789 is offline   Reply With Quote
Old 06-03-2010, 10:55 PM   #9
acarterl524
Member#: 244829
bumpity bump bump bump to the top!
Nice car...its beasty
What kind of body kit is on that car? (Rear Bumper/Air Diffuser)(front Bumper/Spoiler)
GLWS
acarterl524 is offline   Reply With Quote
Old 06-03-2010, 11:42 PM   #10
MARKSTIV8
Member Sales Rating: (78)
Member#: 206393
2008 STI
BLUE
Black on black, BAD ASS!! Amazing car ,but $100k?
Maybe just a little details of the build?
MARKSTIV8 is offline   Reply With Quote
Old 06-03-2010, 11:49 PM   #11
Mr Squiggles
Member#: 235039
2005 WRX
OB
DA-yum! yes sir, may i have more please? If you need some sort of apprentice/lacky and are willing to move to Kansas. I will more than willingly drive that beast and let you bask in the glow of my perma-smile.
Mr Squiggles is offline   Reply With Quote
Old 06-04-2010, 01:16 AM   #12
CosworthSTI77
Member#: 195473
2007 STI
O.K Here's just a taste !
ENGINE:
Titanium Retainers
Valve lash set
Cam covers
ATI Super Damper
Optima Battery
Tial Blow Off Valve
FUEL SYSTEM:
Fuel Rail Spacers
Aeromotive Y Block
DRIVETRAIN:
SUSPENSION:
Tein Flex Coilovers
Tein EDFC Motor Kit
BRAKES:
Brembo Calibers
ELECTRONICS:
EXTERIOR:
35% Tinted Glass
INTERIOR:
Takata Eyelot Bolt
AutoPower Rollbar
Cobb Shiftknob
WHEELS & TIRES
Titek Lug Nuts
Old 06-04-2010, 01:29 AM   #13
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
trade you for a ****ty 08 STI.
silver arrow is offline   Reply With Quote
Old 06-04-2010, 02:17 AM   #14
wuuusaa
Member Sales Rating: (20)
Member#: 92894
2015 Wrx
you have great taste my friend... glws.
Old 06-04-2010, 07:52 AM   #15
[JT]
Member Sales Rating: (14)
Member#: 218435
2001 18g'd Rs Coupe
2 doors less whores
Hot damn, amazing car
[JT] is offline   Reply With Quote
Old 06-04-2010, 11:08 AM   #16
mspeed6
Member#: 212324
sorry but not gonna get anything close to 100k. 30k if lucky.
mspeed6 is offline   Reply With Quote
Old 06-04-2010, 11:24 AM   #17
deegee
Member Sales Rating: (1)
Member#: 158145
02 WRX
Go-go-gadget reading comprehension. He stated he invested 100k, not asking price. . .
Bump for OP! Beautiful car.
deegee is offline   Reply With Quote
Old 06-05-2010, 12:03 AM   #18
WREXION
Member#: 204661
2002 wrx
partially muredered out
one of the nicest cars i have seen yet so tempting
WREXION is offline   Reply With Quote
Old 06-05-2010, 05:23 AM   #19
Str8Chillin
Member#: 212090
2006 WRX
Default The Big ???
HOW MUCH
Str8Chillin is offline   Reply With Quote
Old 06-05-2010, 08:56 AM   #20
Faster_Gun
Member Sales Rating: (15)
Member#: 180217
2001 Porsche 911 TT
1990 Nissan Skyline GTR
If you didn't take the time to read the ad you cant be serious.
Originally Posted by Str8Chillin View Post
HOW MUCH
Originally Posted by CosworthSTI77 View Post
the least amount that I could let it go for and that would be $45,000.00.
Faster_Gun is offline   Reply With Quote
Old 06-05-2010, 09:59 AM   #21
01rs25
Member#: 117555
07 LGT
Agile Protunned
Bump for an awesome Car!!
I've watched this car through all its stages. Agile, VP. Its always been everywheres mines been.
01rs25 is offline   Reply With Quote
Old 06-05-2010, 10:23 AM   #22
LeeC
Member Sales Rating: (229)
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
bump for an AWESOME car
LeeC is offline   Reply With Quote
Old 06-06-2010, 06:53 PM   #23
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
No kidding... That thing is a freakin' beast. Hopefully you find the right buyer.
Old 06-06-2010, 10:31 PM   #24
wrblueballs
Member#: 121549
2005 WRX 20G, PPG
that car is teh secks. free bump for you, sir
wrblueballs is offline   Reply With Quote
Old 06-06-2010, 10:44 PM   #25
CosworthSTI77
Member#: 195473
2007 STI
Thank you all for the kind words about my car, I have put a lot of time and money into it. I just got home from O.C MD. and everyone said I was crazy for selling it, so if I don't get any buyers here shortly I am thinking of maybe a 42R Twinscroll and just turning it into a drag car. Will have to see, I have had a lot of trade offers, but of course if I would even consider a trade the car would have to correspond with what I am asking for my car.
FS: 07 Cosworth STI NEW PRICE $36000.00 CosworthSTI77 MAIC Private Classifieds 93 06-01-2011 07:10 AM
FS MD: 07 STI 7k miles, Mods a plenty pornstar1969 Private Vehicle 'For Sale' Classifieds 80 09-13-2009 09:14 AM
FS: NIB Cosworth Subaru EJ25 High Volume/Pressure Blueprinted Oil Pump & install kit ill-luzion Engine/Power/Exhaust 4 10-10-2008 10:55 AM
FS: (CO) Cosworth Subaru Oil Pan Baffle Scuba Steve Engine/Power/Exhaust 3 10-02-2008 02:07 PM
