Old 06-03-2010, 08:26 PM   #1
JustAnotherSubie
Member#: 185224
2013 EVO X GSR
Wicked White
Default OEM Banjo bolt on fp18g?
I have been reading a lot of threads and on Forced Performances website saying DO NOT USE OEM Banjo Bolt on FP18g turbos. I am reading plenty of mixed comments about this, but i really want to know for sure. The person i bought the turbo from told me he used the stock banjo bolt on the fp18g turbo for about 3k miles with no problems. I am getting re-tuned next week with the fp18g on my car with the oem banjo bolt, should i be okay with it? Any owners with the FP18g using the oem banjo bolt? The FP18g turbo i have is a single scroll td06 with a 7cm compressor wheel.
JustAnotherSubie is offline   Reply With Quote
Old 06-03-2010, 10:00 PM   #2
hex2bit
Member#: 135072
2004 FXT, 19t-td04
FP is just covering their butts as best they can. The only real issue is the mesh filter in the oil line, as there's actually a TSB for it from Subaru. I removed my as a preventive measure, but mine had no problems.
http://store.forcedperformance.net/m...een=Oil_Supply
The restrictive ports in the lines and bolts are not as big of a deal. The only reason to require a lot of oil flow would be for cooling. The FP turbo is water cooled, so it shouldn't have much issue with heat. If you run a turbo that wasn't water cooled, then you could have issues with the oil getting too hot if the flow wasn't high enough, or you didn't let it cool down after a hard run.
Personally, I wouldn't worry about the OEM banjo bolt. Tons of people run big turbos without upgrading the banjo bolt, or removing the inline filter without problems. I guess it comes down what you want to do as preventive measures.
hex2bit is offline   Reply With Quote
Old 06-03-2010, 10:15 PM   #3
JustAnotherSubie
Member#: 185224
2013 EVO X GSR
Wicked White
Oh okay thanks a lot, huge help .
-Alex
Is the banjo bolt on the td04 the same size? Blakeat86 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-17-2009 11:35 PM
what size and pitch is the banjo bolts on the td04 turbo. supernick77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-22-2009 02:01 PM
Oil feed banjo bolt on pass. side head? silentt Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-12-2009 10:59 PM
What size washers do I need for banjo bolts on brake caliper? thrdeye South East Region Forum 27 10-14-2005 01:15 AM
Banjo bolt on turbo oil line! CatchME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-03-2003 05:35 PM
