Old 06-11-2002, 02:58 PM   #1
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Question Up-Pipe & Down Pipe installed... Interesting noises... Leak?
Hi folks,
I installed a PDE Up-Pipe and a ScoobySport Down Pipe last night.
Took a total of about 6 hours, though I still need to put the heat shields back on. One glitch was an exhaust manifold to up-pipe bolt that loosened a bit, then seized. I ended up twisting the bolt in half. Just glad it wasn't a stud! Used plenty of WD40 too.
My question is, what does an exhaust leak on a WRX sound like?
I know that a header leak on a Big Block Chevy sounds like a tap-tap-tap...
I hear lots of interesting noises now, but not sure if any signify an exhaust leak. I'm hoping it's all turbo whine and normal exhaust sounds. I don't really hear anything unusual at idle, but cruising around at 2k to 3k rpms, I hear somewhat more pronounced whining/whooshing than when I removed my silencer.
I followed the Vishnu instructions. Much, much more thorough than the PDE instructions!
There are a LOT of exhaust fittings that get disconnected and reconnected:
Head to exhaust manifold
Exhaust manifold to cross pipe
Exhaust manifold to up-pipe
Up-pipe to turbo
Turbo to down pipe
Down pipe to mid pipe
Too many areas prone to failure. I used the old gaskets since my car only has 1200 miles on it. Replacing all 6 gaskets would cost a fortune!
Any feedback would be great!
Thanks
Russ
rlavalle is offline   Reply With Quote
Old 06-11-2002, 04:23 PM   #2
BeavisNuke
Member#: 14981
2002 WRX Sedan WRB
TurboXS Stage 2.5
Uppipe exhaust leaks are a high-pitched shrieking.
"Shreeeeeeeeeeeeeeeeeeeeeeeee"
You should have at least replaced the up-pipe gaskets. You can get both of them for like $30. Those are the areas where people have had problems with leaks.
BeavisNuke is offline   Reply With Quote
Old 06-11-2002, 04:34 PM   #3
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Hmmm... I don't think I have a shrieking, though I wouldn't mind an expert taking a listen.
I get more of a whooshing that matches RPMs. I'm hoping that's normal turbo sound.
Thanks,
Russ
Old 06-11-2002, 04:53 PM   #4
MackDaddy
Member#: 15451
2016 Accord EXL Navi
Lunar Silver
Thanks,
Russ
What you're hearing is normal... welcome to the wonderful world of the turbo sounds!!
Jim
Edit: you really should have replaced the up-pipe gaskets, at the very least. I replaced all of the gaskets when doing my up/down combo, except the manifold to head and 3rd cat/mid doughnut. You might be o.k., time will tell.
MackDaddy is offline   Reply With Quote
Old 06-11-2002, 05:21 PM   #5
rlavalle
Member#: 18384
2004 STi: 580 AWHP
Java Black Pearl
Thanks for the info...
It "sounds" like I may be OK.
Yeah, I should have replaced all gaskets, but if I need to later, it'll be a lot easier than it was getting the the old up-pipe & down-pipe off.
Thanks again,
Russ
Old 06-11-2002, 07:23 PM   #6
MackDaddy
Member#: 15451
Lunar Silver
Wink Word, my brother
Thanks again,
Russ
Good luck, and enjoy the drive!!!
Jim
Old 06-12-2002, 12:48 PM   #7
DaveyREX
Member#: 16210
Hey Russ,
I just had a Brullen Up-ipe and full turbo back installed and had somewhat the same question. Basically I hear a loader than usual swoosh sound around 2500-3000 RPM and yes it is just the turbo and the new Up-pipe. Less restrictive now so more air going thru the up-pipe. If you had a leak it would be a hi pitch squeal. Hope that helps
DaveyREX is offline   Reply With Quote
Old 06-12-2002, 01:14 PM   #8
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
I just got my Godspeed uppipe with new gaskets installed and that's what I get.
The noise doesn't really bother me but...since there is a leak am I losing performance?
MAD REX is offline   Reply With Quote
FS: OEM STi Up-Pipe & Down pipe. Angel81 MAIC Private Classifieds 7 12-10-2009 07:32 PM
Up Pipe & Down Pipe Help Turbospool72505 Newbies & FAQs 3 09-27-2009 07:00 PM
vf37 with header, up-pipe & down-pipe gold rush Canada Region Private Classifieds 15 02-16-2007 11:44 AM
05 STi Header, Up-Pipe & Down Pipe Legba Engine/Power/Exhaust 4 11-30-2006 08:56 PM
WTB: turbo xs up-pipe & down-pipe Kazzer360 Private 'Wanted' Classifieds 1 06-07-2006 06:10 AM
