Old 06-03-2010, 11:12 PM   #1
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
Default STi swap wiring question
Swapping 04 STi wiring into an 02 wrx. What do I need to do to eliminate the check engine light for the missing fuel pressure sensor and diff temp sensor? can i just use resistors like on O2 sensors?
BMXspears is offline   Reply With Quote
Old 06-03-2010, 11:45 PM   #2
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
The fuel pressure is related to the evap system, which I believe is the same on both cars, I could be wrong though.
For the diff temp.. Did you use the entire 04 harness with the DCCD controller?
NitroTrike is offline   Reply With Quote
Old 06-04-2010, 12:28 AM   #3
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
The STi has a separate fuel pressure sensor than the 02. I used the entire harness excess gas tank section. I don't have the DCCD controller, but i don't need it because i am using stock trans.
Old 06-04-2010, 11:49 AM   #4
NitroTrike
Member#: 62408
The reason I asked about the DCCD controller is because it's tied into the main ecu, and will probably go into "safe" mode if it sees a high temp in the trans or rear diff, which may be what's causing the temp code.
Old 06-04-2010, 12:21 PM   #5
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
My rear diff does not have a temp sensor. My harness does, it will be expecting some sort of signal, that's what I am trying to get around.
Old 06-04-2010, 12:30 PM   #6
NitroTrike
Member#: 62408
You have the front harness, or the rear harness also?
I'm trying to remember where the rear diff sensor wire tied in (DCCD harness or main ecu harness).
Generally leaving it unplugged will mean "cold" and grounding it will be "max hot", but it could be backwards.
I think there are different codes for trans diff temp and rear diff temp.
I have a rear diff sensor somewhere. I could always ohm it out for you and just use a resistor on the harness.
Old 06-04-2010, 02:25 PM   #7
BMXspears
Member#: 79339
2002 EJ257 6spd WRX
Midnight Black
I have the whole harness except the gas tank cord. So I have "front" and "rear". Does anyone know what spec resistor I should use for these sensors?
Old 06-04-2010, 02:32 PM   #8
NitroTrike
Member#: 62408
It would depend on the resistance of the sensor is at a "normal" temperature. Too cold, and it may act funny, and too hot it will throw the light.
Figure that one out, and you're in.
I can tell you the resistance of the rear diff sensor sitting on the table if that helps, and if I can find it.
07 STI to 99 RS Swap -- Wiring questions silentt Subaru Conversions 0 06-17-2008 09:21 PM
Swap wiring questions! Need help MilesToEmpty Subaru Conversions 2 05-09-2007 04:43 PM
Quick: Swap wiring question Skatermxracer Subaru Conversions 2 03-19-2007 10:09 AM
good old subaru jdm ej20 swap wiring questions scobaru Subaru Conversions 1 09-11-2003 11:23 PM
Engine swap wiring question Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-15-2002 07:30 PM
