Old 06-04-2010, 02:07 AM   #1
fordfabwiz
Member#: 8875
2007 STi
Default Boost problems with VF34
Hey guys,
I have a weird problem going on, I have an 02' Rex mods are below
Wiesco Pistons
TGV deletes
mild port and polished heads
match ported intake
Unequal header
3" tbe
light wheel
VF34
BC valve springs
SS over sized valves
HKS SSQ
Silly cone hoses
stock air box with drop in
stock tmic
Cobb VF34 ots map
The trouble I am having is the turd bow drops boost at 6200 rpm in every gear, I am not getting a ping or any knocks. I hit 17-18 psi up to about 6000 and then boom the gate dumps and I drop to like 8.8 psi. I dont see any issues and I just had the engine out to reseal a case bolt. Also I am running the stock TD04 pill and a ixiz ebc set up for stock bleed off. Any ideas??
fordfabwiz is offline   Reply With Quote
Old 06-04-2010, 02:10 AM   #2
ejmalernee
Member#: 129989
2002 impreza 2.5Rsti
You might be flowing to much are for that turbo. My old 39 used to drop from 20 to like 14 psi and redline.
ejmalernee is offline   Reply With Quote
Old 06-04-2010, 02:28 AM   #3
fordfabwiz
Member#: 8875
2007 STi
The boost just shuts down at 6200 like right now, it isnt like a taper but like the gate just opens and that's it. I was reading another post that he was having in issue with his inlet collapsing. I am running the same inlet, GPmoto *insert flame here* I haven't had an issue with it before and I can still hit redline with out an issue. I just drop boost for some reason. I live in Montana so there are no tuners in the area. I am going to try and do a data log and submit it to romraiders and maybe some here that would be interested in helping me out. Thanks for the post.
Old 06-04-2010, 03:34 AM   #4
ejmalernee
Member#: 129989
You could try my tuner hes a real good guy and will look at a log for you. His name on there is Wrx_Fan_0717. His name it Anthony.
Old 06-04-2010, 11:17 AM   #5
fordfabwiz
Member#: 8875
2007 STi
Okay thanks, when I get my log done I will try and search him out.
Old 06-05-2010, 12:00 AM   #6
fordfabwiz
Member#: 8875
2007 STi
Any ideas?? any one
Old 06-05-2010, 01:12 AM   #7
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
Post a log - I'd log the following:
IAM
RPM
FLKC
FBKC
MAF Voltage
MAF g/sec
PSI (Corrected)
Wideband if you have it
TPS
Injector Duty Cycle
I may be missing some too, but these may help.
paintbing is offline   Reply With Quote
Old 06-05-2010, 10:24 PM   #8
VWGrk1
Member#: 57882
2004 WRX
Are you sure it is the wastegate opening? Have you tried a boost leak test? I had something similar happen to me and I was convinced it was electronic. The culprit: a leaky BOV seal. Made boost just fine until 6,250 rpm.
I could not hear the "hissing/whistling" you normally hear with a leak, so give it a shot. Hope you get it figured out.
VWGrk1 is offline   Reply With Quote
Old 06-07-2010, 02:10 AM   #9
fordfabwiz
Member#: 8875
2007 STi
Thanks you guys for the suggestions, I haven't had time to do a log yet. Had to rebuild the rear diff in the wife's Expedition this weekend and we are heading out for Seattle for a vacation this week. I'll repost when I get the log done. I am not sure it is a waste gate issue for sure yet, I cant hear and thing from the BOV that sounds weird but I will triple check that. The odd thing is it is consistent in every gear almost like it is the puter doing the dumping. Just don't know....
Old 06-07-2010, 02:32 PM   #10
tidalwake
Member#: 245662
What injectors do you have? I don't see any bigger ones listed. Might be hitting the limit of stock injectors if that is what you have.
tidalwake is offline   Reply With Quote
Old 06-07-2010, 10:05 PM   #11
fordfabwiz
Member#: 8875
2007 STi
Sorry I forgot to post that
Deatsch Werks Cobb spec 565cc
Old 06-09-2010, 06:45 PM   #12
gingertooth
Member#: 82242
2005 wrx wagon
wooh wooh!!!!!
sure your not getting a misfire? and you should definately have a walbro fuel pump in there too with all those mods......
gingertooth is offline   Reply With Quote
Old 06-20-2010, 08:28 PM   #13
fordfabwiz
Member#: 8875
2007 STi
Ya I do have a walbro in there as well, I brain fart sometimes when I list my mods... I found out though it was my POS ebay special intake hose causing the issues. I picked up an AVO from a guy on the site at a good price, popped it on and wala no more dropped boost at 6200. Now gotta save up for a tune, running a Cobb OTS map, and I'll be good to go.
Problem with VF34 install... question. txl146 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-21-2006 05:09 AM
Boost controller with VF34? sfjohnson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 08-01-2005 08:57 AM
anyone ever had problems with vf34 turbo? ronnyek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-09-2005 10:26 PM
Boost Problems With The Ver6 Swap HeMan1320 Subaru Conversions 9 01-04-2005 06:57 PM
Boosting problem with new stage 4/UTEC Leonardo Engine Management & Tuning 15 05-02-2004 09:49 AM
