Old 06-04-2010, 12:42 PM   #1
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Default 370WHP alternative to Dom 3.0XT-R
Looking for around 370WHP on 93 octane. Track days and time trials.
Something with a 3" inlet and full ball bearing.
I have been looking at results with the 3.0XT-R, but I would rather have earlier torque and don't need that much max power.
turboICE is offline   Reply With Quote
Old 06-04-2010, 01:47 PM   #2
FlannelWagon
Member#: 209998
2007 Fxt
Urban Grey Metallic
have you looked at the AVO turbo's? my friends AVO450 made 461whp on e85 and the power delivery was intense!
FlannelWagon is offline   Reply With Quote
Old 06-04-2010, 02:10 PM   #3
KurtP
Member#: 44836
1999 Fozzy
How about a 2.5xtr?
I've never been impressed with AVO turbos relative to their price point.
KurtP is offline   Reply With Quote
Old 06-04-2010, 03:00 PM   #4
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
I was wondering about the 2.5, but there isn't as much feedback and results posted on it. Most likely because for the price difference most probably figure why bothering with the 2.5 rather than the 3.0
I would definitely consider it but would want to see more results. Currently I can't tell if in fact power would come on earlier with the 2.5 over the 3.0
Old 06-04-2010, 03:10 PM   #5
pauli18c
Member#: 174553
2005 STi 360whp
345wtq on 93oct @ 20psi
my SR/56 put down 360whp at a hair under 20psi
pauli18c is offline   Reply With Quote
Old 06-04-2010, 03:27 PM   #6
Fierysun
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
There's only a few choices for BB turbos. Blouch 2.5, 2.5 XT-R, and ATP 3071R. The 2.4" inlet spool earlier than the 3". With an EWG, they should all be around 370whp+ on pump gas.
Fierysun is offline   Reply With Quote
Old 06-04-2010, 03:34 PM   #7
awoodSTI
Member#: 160656
2011 FXT
ATP 3076 EWG, I put 363 on a mustang on 93
awoodSTI is offline   Reply With Quote
Old 06-04-2010, 08:17 PM   #8
rexblake
Member#: 178426
2010 S4
Gray
You could try the old dom 3 with the 8cm hotside. That will provide you with close to the same power (it's 3lbs/min different) and slightly better spool.
rexblake is offline   Reply With Quote
Old 06-04-2010, 08:43 PM   #9
Fierysun
Member#: 82745
2005 Subaru STI
I thought the 3.0 XT-R spools better than the old Dom 3?
Old 06-04-2010, 09:31 PM   #10
07wrx4life
Member#: 171514
07 DOM 3 WRX
352/326 @ 20psi EQ Tuned
Correct me if I'm wrong but I thought that blouch didn't use the 8cm housing any more, atleat that's what i was told when I had my dom 3 hotside replaced.
07wrx4life is offline   Reply With Quote
Old 06-04-2010, 09:37 PM   #11
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Thank you for the responses.
Yes I thought they put up results showing better response with 10cm XT-R over the 8cm.
Old 06-04-2010, 09:44 PM   #12
SeaOfGreen
Member#: 241512
2007 Impreza WRX STi
Satin White Pearl
I'm in the same boat I'm going Dom 2.5 xtr iwg get 375whp on mustang with pump or meth!
SeaOfGreen is offline   Reply With Quote
Old 06-06-2010, 06:30 AM   #13
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Sounds like it is between the 2.5XT-R and the 3071.
Old 06-06-2010, 07:54 AM   #14
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Go with a Element GT52 its a better turbo than the Doms IMO
ASU is offline   Reply With Quote
Old 06-06-2010, 01:08 PM   #15
awoodSTI
Member#: 160656
2011 FXT
Get the 3076 over the 3071...
Sent from my iPhone using Tapatalk
Old 06-06-2010, 04:39 PM   #16
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Why the 3076? I want power to come on quickly and don't want or need to get over 370whp on 93 octane, will the 3071 not get there?
Old 06-06-2010, 06:32 PM   #17
awoodSTI
Member#: 160656
2011 FXT
The 3071 isnt going to hit 370 on pump. The spool between the two is negligable imo anyways.
Old 06-06-2010, 07:51 PM   #18
boost_556
Member#: 176536
2004 wrx
blue
hey i have a 2.0 wrx 04, just got tuned made 383 whp have the fp18g, running m1 methonal and 373 tq cant wait to take to the track to see what the hell i gonna do this time lol.
boost_556 is offline   Reply With Quote
Old 06-06-2010, 08:20 PM   #19
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Let me guess, on a dynapack? You can make any dyno read just about whatever you want it to but that does not mean that they are accurate. Trust me, your car does NOT make anywhere near 370 on a mustang.
dexterous is offline   Reply With Quote
Old 06-06-2010, 08:26 PM   #20
novacivic
Member#: 117980
2005 sti
wr blue
wanna buy my deadbolt sz55? not bb but hits 23psi around 3800 with a fmic and pulls straight to redline.
novacivic is offline   Reply With Quote
Old 06-06-2010, 09:29 PM   #21
Steve.804
Member#: 68647
07 STI 35R
05 BMW M3 ZCP
for what the dom 3 xt-r is, it performs damn well. it is going to be tough to find a turbo that makes a real 370whp and spool better on straight pump and fits in the stock location. You can always go rotated and try a 3076. Flows a hair less (i think like 3lbs/min(?)) and should perform better due to the more direcet intake and exhaust path. If you are going to stick with stock location and want something with more low end torque I'd look into an FPGreen, or see what the latest and greatest is from FP.
Steve.804 is offline   Reply With Quote
Old 06-06-2010, 09:41 PM   #22
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
What WHP would a 2.5XT-R or a stock location 3071 reach on a Mustang dyno using 93 octane?
Old 06-06-2010, 09:57 PM   #23
rexblake
Member#: 178426
2010 S4
Gray
I'm not sure actually. But if they don't sell one, you could always try to find a used one.
As for the spool characteristics, it seems to be different depending on the dyno. Sometimes the 8cm spools quicker, sometimes the 10cm does.However, the 10cm has more top end, the 8cm has a bit more midrange.
Old 06-06-2010, 10:07 PM   #24
rexblake
Member#: 178426
2010 S4
Gray
Who knows, all depends on the dyno. Could be anywhere between 300-350. I'd highly recommend calling your tuner and asking them what setups run on their dyno.
Old 06-06-2010, 10:09 PM   #25
awoodSTI
Member#: 160656
2011 FXT
I hit 363 on a mustang with an ATP 3076....
Dom 3.0XT-R and Dom 4.0XT-R Dyno Charts Blouchturbo Proven Power Bragging 480 11-15-2014 04:05 PM
2.0 + Dom 3.0XT-R + E85 makes 392whp rexblake Proven Power Bragging 36 07-20-2010 10:58 PM
thinking about going dom 4.0xt-r novacivic Proven Power Bragging 40 06-29-2010 10:55 AM
Dom 3.0XT-R and Dom 4.0XT-R Now Available Blouchturbo Engine/Power/Exhaust 17 02-04-2010 02:01 AM
Dom 3 or Dom 2.5 or Dom 1 or FP Green? Want ~400 whp with quickest spool? 2.1 stroker NITROS Built Motor Discussion 10 10-26-2009 12:40 PM
