Old 06-04-2010, 02:42 PM   #1
nrclptcnsmniak
Member#: 245368
2005 05 WRX
CGM
Default have some questions regarding maintenance
ok so i read the maintenance faq sheet and ive still got some questions...
for my coolant it says i need approximately 8.1 US qt of collant... now am i going to mix that entire bottle 50/50 water? or use 8.1 qts of coolant and water already mixed?
also brake fluid... how much of it do I buy because I am going to stop by the subaru dealership to pick up the oem coolant and brake fluids... also should i buy the coolant conditioner? if so how many qt?
nrclptcnsmniak is offline   Reply With Quote
Old 06-04-2010, 03:26 PM   #2
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
For the coolant you need to buy ~4 qt of concentrate OR ~8qt of premixed.
If your dealer does not sell premixed, then buy ~4qt of distilled water to mix with that concentrate.
Yes you also need that small bottle of conditioner
notjustforshow is offline   Reply With Quote
Old 06-04-2010, 03:32 PM   #3
nrclptcnsmniak
Member#: 245368
2005 05 WRX
CGM
thank you ^__^
Old 06-04-2010, 03:35 PM   #4
leecea
Member#: 37359
2003 WRX
IMO, brake fluid is cheap - just buy one large bottle and you'll be fine. I've never actually checked to see if I could get away with one small bottle. I think I could, but not worth the risk for saving a couple of bucks.
leecea is offline   Reply With Quote
Old 06-04-2010, 03:40 PM   #5
nrclptcnsmniak
Member#: 245368
2005 05 WRX
CGM
ok one more question on the FAQ for coolant
What about a DIY coolant flush? There are generally three ways to perform this:
a. After the system is drained, many fill up the radiator with regular or distilled water alone. Then heat cycle, cool, and drain.
how many times do i do that until i fill the radiator up for good.
Old 06-04-2010, 03:43 PM   #6
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
I don't flush the coolant, simply drain as per manual and let it sit. I've done my coolant 4 times and I'm at approximately 100k, no rad leaks and temperature is well within tolerance range.
Old 06-04-2010, 03:48 PM   #7
nrclptcnsmniak
Member#: 245368
2005 05 WRX
CGM
so just drain and fill huh?
Old 06-04-2010, 04:09 PM   #8
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
yep, i dont think it matters either way but someone who is adamant on flush should chime in
I have some questions regarding - Version 7 v7 EJ207 into USDM 2004 STi STepeci Subaru Conversions 8 09-18-2009 08:26 PM
some questions regarding to chipping my 02 wrx boreas Engine Management & Tuning 3 06-28-2005 07:09 AM
Some questions regarding the alignment I just got done. YinUCSD Brakes, Steering & Suspension 8 04-19-2004 03:55 PM
ACT Clutch Installed: Have some questions regarding engagement latinskllz Transmission (AT/MT) & Driveline 9 07-08-2003 12:02 AM
I have some questions regarding Cusco Adj sway bar. Rodan Brakes, Steering & Suspension 5 01-09-2002 11:27 AM
