Old 06-04-2010, 01:45 PM   #1
STiluv55
Member#: 206102
1999 2.5 RS
Default Stock 2.5 RS sputters and wont accelerate
The other night I had made the mistake of leaving off the vent on the hood over my air filter while it was raining. When I drove the car it seemed fine except for one small bogging down after I left a light. I had my knock sensor go out and it felt like it was again. No codes were thrown though.
The next day the car starts up fine and idles fine but I can't run the RPMs up. If I'm careful with it, I can get them up to 1500 then it dies back down to idle. I got a P0122 TPS code out of it for low signal.
After confirming that I have good fuel pressure and my plugs aren't soaked with oil or water ( I even blew out the cylinders just incase). I checked the voltage on the TPS and it read 5.1v and wouldn't read anything in a sweep test. So I bit the $216 stealership price bullet and bought a new one. It was the only one in town that I could get today and need my car running ASAP.
It didn't do jack. The engine still won't rev up but idles fine. I cleaned the IAC and tested the coil but I'm having trouble locating the exact specs on what I should be seeing in a coil test and what pins to check. I know I replaced the coil about 3.5 yrs ago, but it could be bad because it was some cheapo brand from NAPA.
I have also disconnected the negative on the battery to reset the ECU as some have said to do and that will relearn the idle. Well that didn't help either.
I know this is long but I wanted to lay out all the symptoms and fixes and tests that I've tried. Thanks for reading and I hope you can help!
Oh yeah the car is a '99 2.5 RS bone stock except for the short ram intake that it came with when I bought it.
STiluv55 is offline   Reply With Quote
Old 06-04-2010, 02:59 PM   #2
STiluv55
Member#: 206102
1999 2.5 RS
Anyone know of this???? I have searched and searched on this subject and all I get is people with WRXs that they modded and screwed something up to get this code. Has anyone had this on a stock 2.5 RS?? Or anything with the same engine??
Old 06-04-2010, 04:04 PM   #3
STiluv55
Member#: 206102
1999 2.5 RS
I sees you looking! Any help???
Old 06-04-2010, 07:20 PM   #4
STiluv55
Member#: 206102
1999 2.5 RS
feel free to close this, i solved my issue with the recall MAF from the dealer!
WRX parts, 2.5 RS parts and 98 2.5 RS coupe (PA) 69subaru360 Tri-State Area Private Classifieds 13 11-03-2010 12:04 AM
fs- 1998 stock gold 2.5 rs wheels and tires superrooo Wheels/Tires 18 06-27-2007 02:23 PM
fs- 1998 stock gold 2.5 rs wheels and tires. superrooo RMIC Private Classifieds 9 06-21-2007 12:04 AM
2.5 rs block and heads, stock wrx interior parts wrxben Engine/Power/Exhaust 7 10-04-2006 12:29 AM
FS: 2002 Stock 2.5 RS seats Front and Rear swatts007 Private 'For Sale' Classifieds 0 07-12-2006 08:37 AM
Message Board Statistics All times are GMT -4. The time now is 05:21 AM.
