Welcome to the North American Subaru Impreza Owners Club Sunday February 7, 2016
Old 03-29-2009, 06:53 PM   #1
subadrew99
Member#: 204755
Default EJ25 SOHC vs DOHC
Hey just wondering what the pros and cons are to the SOHC EJ25 and the DOHC EJ25.
subadrew99 is offline   Reply With Quote
Old 03-29-2009, 07:46 PM   #2
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
The DOHC were known to have head gasket difficulties.
Edit: For the 2.5rs ones of course
Smoke is offline   Reply With Quote
Old 03-29-2009, 08:30 PM   #3
GrundleJuice
Member#: 165749
MY05-07(08-09?) SOHC's have great intake manifolds
GrundleJuice is online now   Reply With Quote
Old 03-29-2009, 10:49 PM   #4
Back Road Runner
Member#: 60082
2004 Forester STI
There some dyno graphs floating around directly comparing the DOHC and SOHC engines. Cobb also wrote some tech articles a few years back discussing both engine types. You can't find them on Cobb's site now, but Archive.org's Wayback Machine can give you them from older, stored pages. I know there's been various discussions on both engines. My impression is that the SOHC is basically superior, but there may be cases arguing both ways. With some modifications, the SOHC engine has no problem with top end power.
Back Road Runner is offline   Reply With Quote
Old 03-30-2009, 01:38 AM   #5
PA-Outback2000
Member#: 161832
2000 Outback Limited
da risin smoke... 2.5rs, aka N/A's, have the SOHC, not DOHC. i have a 2000 2.5L and had the HG changed at around 110,000 miles.
SOHC are fine within the normal 6500rpm redline, but the DOHC flow more b/c they have 2 camshafts doing the work of one. there really isn't anything "wrong" with the SOHC, but i don't think it would be worth it to change to a DOHC if u r currently running a SOHC.
i am keeping the car SOHC throughout all the mods i plan on doing.
PA-Outback2000 is offline   Reply With Quote
Old 03-30-2009, 02:15 AM   #6
subadrew99
Member#: 204755
I have the choice between a 98 and 99 2.5rs so I'm just weighing out the pros and cons between the two. Basically I'm just wondering which is better performance wise and which is more reliable and overall which is better
Old 03-30-2009, 08:09 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
You've never seen the 96 Outback with an EJ25D or 98RS with the EJ25D, or any of the few 99RS' that also got the DOHC heads?
The difference between the DOHC and SOHC is not all that great. SOHC has more torque while the DOHC has more top end pull. The difference is so small that it could boil down to port design or just a matter of ECU tune that was put on the car. Nothing really to do with the number of cams or anything like that.
The SOHC is simple to work on, where the DOHC requires a bit more attention to detail during timing belt changes or headgasket changes. I would go with a SOHC motor for that reason alone.
Jay
Old 03-30-2009, 11:15 AM   #8
subadrew99
Member#: 204755
Thanks for the info that was what I was looking for
Old 03-30-2009, 05:43 PM   #9
PA-Outback2000
Member#: 161832
99rs switched back to SOHC for N/A's. my bad about the others.
Old 03-31-2009, 02:29 AM   #10
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Jay
I'm with you on that one, thats why I stuck with SOHC heads. Those graphs have to be here somewhere. Those alone made my mind up for me.
~Josh~
my woman wants me to put this in.......... she loves it......
ballitch is offline   Reply With Quote
Old 03-31-2009, 09:28 AM   #11
STiluv55
Member#: 206102
1999 2.5 RS
Jay
I see you have spoken of a tune. Do you mean aftermarket performance tune or the stock one? Would a tune be worth the money if you had CAI short ram and full exhaust with high flow cat on a SOHC N/A? Or would the increase in hp you get from the tune be so little it's a waste of money?
STiluv55 is offline   Reply With Quote
Old 03-31-2009, 04:44 PM   #12
Storm
Member#: 5218
96L Most Over-
Developed Beater
I meant the OEM tune on the ECU. Even the base timing is more advanced according to the SOHC FSM ('00). If you have the means to do it, an optimized tune is ALWAYS worth it. There is a substantial amount left on the table compared to the stock maps.
Jay
Old 03-31-2009, 04:52 PM   #13
VWVancouver
Member#: 14507
Hey guys, I'm looking at getting a 2003 or 2004 Forester. Just wondering when the head gasket was upgraded? Was is 2004 they fixed the problem? TIA.
VWVancouver is offline   Reply With Quote
Old 03-31-2009, 08:19 PM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
It was updated well before then. It will be a SOHC EJ25 and should hold up just fine.
Jay
Old 04-01-2009, 08:30 PM   #15
VWVancouver
Member#: 14507
Thanks Jay.
Old 04-01-2009, 08:58 PM   #16
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The 2.5 DOHC has larger intake ports, larger intake manifold runners. The exhaust however is a tad choked where the valve guide support is compared to the 2.5L SOHC. The 2.5L SOHC has decent intake ports, straight shot, but smaller intake manifold runner. Also the SOHC runs a higher compression ratio compared to the DOHC. This gives it more power to start.
If they ran the phase2 shortblock on the DOHC heads, that'd make more power than the SOHC no doubt. If BOTH where fitted with an after market turbo, the DOHC would make more TOP END power because of the better flowing heads and intake manifold. I see a good amount of SOHC turbo's RS's fall off in power above 6000rpms all the time and it falls fast unlike the USDM WRX/STi where the intake manifold is larger. What also plays a roll is the camshafts too.. but... if you ever seen the intake manifold, and heads of the SOHC/DOHC NA and WRX/STi DOHC you'll know wassup.
BOTH motors has leaks of their own kind. The DOHC with overheating issues, the SOHC with oil leak issues.
Old 04-02-2009, 01:28 AM   #17
subadrew99
Member#: 204755
to do a swap from DOHC to SOHC would you need to do a complete wiring harness swap?
Old 04-02-2009, 04:40 PM   #18
Storm
Member#: 5218
96L Most Over-
Developed Beater
Not really.......but the (lack of) EGR and IAC becomes an issue as the DOHC used an externally mounted solenoid. Depending on the year EJ25 you use, the IAC will be a 3 wire solenoid (but still not compatable), or 6 wire stepper motor which is just out of the question.....unless you're good at building microcontroller circuits. Only certain year and emission spec. SOHC motors got an EGR system too.
Otherwise, the motor will start and run fine off the EJ25D ECU.....it'll just have a permanent CEL.
Old 04-02-2009, 05:02 PM   #19
bubba2533
Member#: 175483
13 WRX 5-Door
Some EJ25D motors had EGR
or did you mean EJ25 SOHC didn't have EGR? (what you said is kind of confusing)
bubba2533 is offline   Reply With Quote
Old 06-04-2010, 08:51 PM   #20
calgearhead
Member#: 133745
1998 Lifted Outback
Green + Dirt
Sorry to drag this back from the past but as Storm mentioned about the DOHC to SOHC swap on a Phase one (1997) ride, it will run and drive fine without an ECU swap or anything but with a perma-CEL.
calgearhead is offline   Reply With Quote
Sohc Vs Dohc Ej25 BlckBeautyVTEC Southern California Impreza Club Forum -- SCIC 3 09-22-2006 05:33 PM
EJ25 - SOHC vs DOHC 2.5rsDOHC Normally Aspirated Powertrain 8 08-04-2004 12:38 PM
EJ25, SOHC to DOHC Honkey3k Normally Aspirated Powertrain 7 07-22-2004 03:03 PM
Subaru EJ25 SOHC & DOHC head components (valvetrain, cams etc) iON Performance Inc Vendor 'For Sale' Classifieds 21 03-09-2004 03:34 AM
EJ25 SOHC to DOHC and back again? JoShYo Normally Aspirated Powertrain 16 11-14-2003 12:24 PM
