#1 |
Member#: 193569
Vehicle:2006 Wrx CGM Last Minute Motorsports |
i have an 05 wrx that i just swapped my buddys 02 wrx motor into... motors in great shape, etc.... the fuel pump will not kick on whatsoever. I replaced the pump with another W255... i feel the relay under the dash kicking on, i checked all the harness connections and connectors, theyre all in good shape, and the ignition powers everything else on, just not the fuel pump. any suggestions??? oh yeah and at the fuel filters everythings dry, theres no fuel in the lines so the motor is 100% not gettin fuel.
thanks
#2 |
NASIOC Manufacturer
Member#: 87358
TXIC
Time to grab a volt-meter! Check to see if you are getting power at the plug near the gas tank. The relay might be switching, but it's possible something else is interrupting the connection.
#3 |
Member#: 193569
i had the volt meter out. i was getting 6 volts at the pump through the plug on the top cover. or something along those lines. apparently theres a relay for the fuel pump in the trunk passenger side as well...i was trying to find it..no luck. so im thinking i got a ground issue or a pcm issue.. since all the fuses are good. im thinking about running power and ground jumper wires along the interior like the harness is and splicing it with an accessory wire so the pumps only on in the key on position. easier than chasing a wire for a break or something.
#4 |
Member#: 59388
RMIC
Vehicle:2003 WRX - Hybrid I do my own stunts |
Whenever I need to disconnect the fuel pump, I always disconnect the big brown wire harness below the glove box (next to the door).
Make sure your friend didn't disconnect this and not tell you. |
#5 |
Member#: 193569
nah man...its all connected.. wtfffffffffff
#6 |
Member#: 151045
Vehicle:2013 Subaru STI CBP |
Fuel pump controller would be another item to check. Located behind trunk liner on passenger side.
Edit: The service manual has more info on reading the voltages on the controller terminals; what to expect, etc. Check all your fuses as well (SBF-5 is power to the fuel pump controller). The ECU dictates the fuel pump duty cycle. If it is sending 0% for some reason the pump will not cycle. Last edited by Haelan; 06-06-2010 at 12:27 AM. |
#7 |
Member#: 145105
Vehicle:2007 WRB WRX Limited |
SikSilvrSuby: any updates?
I'm having similar problems ![]() |
#8 |
Member#: 130374
SCIC
Vehicle:2000 rSTi BRP |
I'm with 96accord on this one. Any updates? I know it's been a few months, but I have the same problem (6v at the plug and the pump doesn't turn on) and wanted to know if you got it working.
#9 |
Member#: 214779
NESIC
Vehicle:2004 wrx Mr. San Remo |
bad ground after the pump. if your getting power to the pump its most likely a ground issue.
| Thread Tools | |
| Display Modes | |
| Car Wont Start... Fuel Pump Not Priming... Any Ideas? | dug-e-fresh | Factory 2.0L Turbo Powertrain | 10 | 08-09-2011 03:35 PM |
| fuel pump not turning on. | azn2nr | Subaru Conversions | 16 | 07-07-2006 07:23 PM |
| Fuel Pump not turning on | chinoWRXL | Factory 2.0L Turbo Powertrain | 19 | 12-09-2005 12:51 PM |
| fuel pump not priming/ecu not on? | attitude | Engine Management & Tuning | 16 | 06-24-2005 12:16 PM |
| Friends fuel pump not turning on? | kaos200 | Normally Aspirated with bolt-on Forced Induction Powertrain | 11 | 03-14-2004 10:25 PM |
